#41 (permalink) |
Louder than 4 F404-GE-400
The Skunk2s are bitch to adjust though. You have to take the tire off. Loosen the lock nut on the arms. Unbolt the arm from the suspension. Turn the bolt hole thingy. Reattach the arm to the suspenion. Tighten the lock nut. Put the wheel back on. Check the alignment. If it is wrong, repeat all above steps agian. If i knew that before i bought them, i wouldn't have.
#42 (permalink) | |
#44 (permalink) | |
2007 Taffeta White Si Coupe
#45 (permalink) | |
#47 (permalink) | |
http://www.8thcivic.com/forums/showt...48#post1251348
My current pics - Basics all stopped down. No camber kits yet :x.. waiting for the rims. Quote:
#48 (permalink) | |
Tein has lifetime rebuilding so i would go with them but after having the SS and Flex, i would recomend that you go with the Flex because it has a much better damper. Or you could get Koni Yellows and GC springs for 1200 (cost of SS) and have a MUCH better suspenion than an SS and Flex. The off the shelf stuff is fine for the steets. |
#51 (permalink) |
If you can give up some of the ride quality, Ground Control coil-overs with Tokico Illuminas was the best suspension set-up I ever had with regards to performance (Konis can be substituted.) Fairly firm ride, but the handling was magnificent for a daily driver.
#52 (permalink) | |
#55 (permalink) | |
#57 (permalink) | |
| TEIN Basic, Super Street, FLEX Coilover and S-Tech/High Tech Spring Sale | Excelerate | Excelerate Performance | 39 | 07-11-2008 12:12 PM |
| Tein Basic Damper | NHBP07 | Suspension and Brakes | 7 | 05-17-2007 12:51 AM |
| Anyone know anything about the tein basic full coilovers | hedwards | Suspension and Brakes | 9 | 05-01-2007 01:10 AM |
| Tein SS vs Basic | Max2.0 | Suspension and Brakes | 2 | 03-27-2007 09:34 AM |
| Tein Basic vs. Tein SS? | duy2006si | Suspension and Brakes | 2 | 04-18-2006 01:46 AM |
