#21 (permalink) | |
#23 (permalink) | |
2007 Taffeta White Si Coupe
i just find my stock car tend to understeer in general, what can be done to make it oversteer a bit to balance the natural understeer? if u recommend negative on the front...isn't that bad for the tires? i don't have lots of $ to buy tires hence i try to avoid negative or positive camber...
#24 (permalink) |
I eat my r6
nice drop man.
FG Squad Member #382 Tampa Crew Member #315% Tint///JDM FD2 Shift knob///JDM Red H emblems///Injen CAI Join the forum where you can exercise freedom of speech and say what you want -----------> http://tampastreetracing.lefora.com/forum/ |
#26 (permalink) | |
#28 (permalink) | |
#29 (permalink) | |
Louder than 4 F404-GE-400
Stock Front camber is about 0 degrees and rear is about -1 degrees. If you want something cheap to change the balance, Get 4 camber bolts for the front, 2 per side an about 30 bucks a pair at corsport. Put them in, go to and alignment shop and tell them to max out negitive camber and positive caster in the front but tell the shop it HAS TO BE EVEN ON BOTH SIDES or your car will pull to one side. If you drive you car with spirit often enough, you won't notice too much inside shoulder tire wear. If that is not enough oversteer for you, and you can afford it and can wait a little while for them to come out, (they should be 600-700 for the set) I'd say get some after market dampers (shocks) from Koni or KYB or Tokico. I like Konis and will have some custom ones soon. Dampers make the biggest difference in handling. Then, if that is not enough, get some Ground Control springs for 400. You can get any spring rate you want with GC springs. If you call them and give them an idea of what you want and already have, they will give you something good if you don't already know the spring rates that you want. Then, if that is still not enough, get a rear sway bar. Then if thats not enough, get a smaller front sway bar from a DX/LX/EX. I think that will just about cover it. Ohhhh one more thing. Only do one mod at a time so you get a feel for what the car is doing. |
#31 (permalink) | |
I'm assuming you are refering to cabmer bolts? One bolt will only get you about -1 degree of camber and 2 bolts will get you -2 degrees. Here is a little DIY on the camber bolts. DIY (sort of) SPC Camber Bolts Install |
#34 (permalink) | |
But remeber that the stock ones dont adjust at all!!! The SKUNK2 are adj. +-3 degree and they are also 25% lighter, better built, and have the poly bushings to have a better feel...
#35 (permalink) |
True true. But if you don't have 250 bucks to spend ... Also adding rear negitive camber without increasing front negitive camber is only going to make the car have more understeer than it already does. I have the silver skunk 2's. I don't like any thing gold and soon i will be rid of my crapy Tein Flex's (with gold rear spring purches) for RSM Custom Koni Coilovers.
#36 (permalink) | |
#37 (permalink) | |
#38 (permalink) | |
thx 4 tips. my car is typically 95% for daily use which is driven at legal speed limit. 5% track & autocross few times per year, and the odd time taking a right turn corner a bit faster (where i mostly find the understeer). n i'm planning on lower on tein basic also, i don't plan on getting a smaller front sway either. i guess a few negative camber won't hurt either assuming it won't wear out my tires too quickly. so by just playing with tire pressure or camber to creat more oversteer. would u recommend -1 in front, and 0 in back? (i assume negative camber gives grip, so by having more grip in front and less grip in back will make the tail slide out more?!?!) thx again
#39 (permalink) |
I have always perfered handling over straight line before I came on this site. I thought I knew a lot of stuff until i met Highrev1. He opened my eyes and now I see that i knew nothing, almost, and now i am a handling junkie that is out to spread the would of the Handling God.
I would not recomend 0 degrees of camber in the back. It takes a skilled driver to handle that lack of grip in the back on the track and on the street that can get you in trouble. You want the back to stick, but you want the front to stick more. I'd say AT LEAST -1.5 in the front and -1 in the rear. I run almost -2 in the front and -1.25 ish in the rear. Teins suck. I had Tein SS for a year and now Tein Flex for 4 months and i'm getting rid of those. With off the shelf coilovers, the manufacture keeps cost down by putting cheap dampers in them. The damper is the most expensive part of the suspension and has the biggest effect on handling. Dampers control roll, dive squat, and how the car reacts to bumps. Springs just keep the car off the ground. If you want something better than Tein, or any off the shelf coilover for under 2000, get some Koni Yellows and some Ground Control springs (made by Eibach). Bothe Koni and Eibach make dampers and springs for F1 Teams, thats how good their products are. Tein cant say that. Buddy club can't say that. Megen, Apex, ARC ... |
#40 (permalink) | |
They retail for $316.54... Here the link of the seller I bought mines from at ONLY $190 out the door with FREE shipping!!!http://cgi.ebay.com/ebaymotors/SKUNK...spagenameZWDVW Now remeber u have to choose the right color... Check out he score at 99.8% positive!!! |
| TEIN Basic, Super Street, FLEX Coilover and S-Tech/High Tech Spring Sale | Excelerate | Excelerate Performance | 39 | 07-11-2008 12:12 PM |
| Tein Basic Damper | NHBP07 | Suspension and Brakes | 7 | 05-17-2007 12:51 AM |
| Anyone know anything about the tein basic full coilovers | hedwards | Suspension and Brakes | 9 | 05-01-2007 01:10 AM |
| Tein SS vs Basic | Max2.0 | Suspension and Brakes | 2 | 03-27-2007 09:34 AM |
| Tein Basic vs. Tein SS? | duy2006si | Suspension and Brakes | 2 | 04-18-2006 01:46 AM |
