Old 08-05-2007, 02:05 AM   #1 (permalink)
2000civic's Avatar
Robert
Before I buy the HFP suspension.......
I have a question. My plan is to buy the HFP suspension , then a little while down the line throw some ground control springs on it. I have heard that the ground control springs are height adjustable, also that you can pick your own spring rate.
So my question is, if I pair the ground control springs with the HFP shocks, will the shocks blow? My thoughts were since I only want 1/4 to 1/2 inch lower than the HFP kit, and I can pick a higher spring rate to compensate for the shorter springs, my shocks should be cool right? I am not to familiar with suspention as you might be able to tell, I am hoping this will work. My last car I just put springs on, and the shocks went to hell. Any thougts?
2000civic is offline   Reply With Quote
Old 08-05-2007, 03:22 AM   #2 (permalink)
RiceBowL54's Avatar
Gio
Its always best to pair struts and springs that are made to be used together, but not too sure about that combination.
For $600ish (hfp suspension) + $200 (springs).. might as well get aftermarket coilovers: Function/Form Type II, Tein Basics for that amount of money.
RiceBowL54 is offline   Reply With Quote
Old 08-05-2007, 05:02 AM   #3 (permalink)
price does not equal coilovers being a better solution
read around a bit more on this forum and you'll see what i'm talking about...
or just do a search for posts by "highrev1" or "sirbelch" - (top two guys that come to mind that know what they're talking about)
...you could even check the sticky's
LucasBlack is offline   Reply With Quote
Old 08-05-2007, 05:04 AM   #4 (permalink)
2000civic's Avatar
Robert
Yea I have just heard bad things about pre built coil-overs. I was planning on going with the function/form, or the buddy club. I will more than likely go for the function/form, I have heard good things about them. I just thought of this the other night, and was wondering how effective it would be.
Old 08-05-2007, 05:49 AM   #5 (permalink)
Louder than 4 F404-GE-400
Paul
Well 2000civic, did you know that Ground Control makes custom springs? They can make you a spring that matches any damper. So, in theory, they could make you an adjustable spring that best matches the damper in the HFP suspension. However, I do not know how much that would cost. You would have to call them and ask. They are really friendly people and i'm sure that they would be more than willing to help you out. The damper in the HFP suspension is what really improves handling. I would also be willing to bet the the damper in the HFP suspension has a better shock dyno curve than that of a similarly priced damper that is in a coilover set up. So, i think that the HFP/GC set up would be better than a off the shelf coilover set up. But, If you can wait, one of the aftermarket damper companies (Koni, Tokico, etc) will make a better damper than the HFP suspension with adjustablity to boot. If you pair that damper with the GC springs, you will have an even better suspension than the HFP/GC spring combo or an off the shelf coilover system. But in the end, its up to you, and i'd say that the HFP/GC combo would be just fine and i'm sure you could sell the HFP springs to some one. However, I would still wait until Highrev1 gives his opinion.
Old 08-05-2007, 11:57 PM   #6 (permalink)
2000civic's Avatar
Robert
Thank you for the responce. Yes I found out that they do make custom springs for dampers. That is what brought up my original thougt of pairing the two together. I would like to wait for aftermarket dampers, but to be honest, I am not really going to be autocrossing. It will simply be a set up for DD, and spirited driving. So I think the HFP damper will be good for me. I just want more of a drop than the HFP offers, so I would go for ground control. I figured if in the future I really get into autocrossing and this set up does not due I can always upgrade.
Old 08-06-2007, 06:22 AM   #7 (permalink)
Paul
^^ You all so got to take in to account what your budget is. If aftermarket dampers and coilover springs is all you can afford, does it make sence to buy the HFP suspension, GC springs, AND then aftermarket dampers? Even if you just want a DD, you would get the same ride with better perfromance with aftermarket/coilover setup than you would with HFP dampers and GC coilovers. I'm about to buy my THIRD suspension setup because i didn't know what I wanted in the first place and my car is and will be a DD for the next 4-5 years. I'm just the kind of guy that want the best handling i can get with in my price range. I moved my some of my straight line performance budget to the twisty budget because i didn't get it right the frist time. If none of that makes any sense its beacause i've been drinking for the last 7 hours, its my saturday.
Old 08-07-2007, 07:30 PM   #8 (permalink)
2000civic's Avatar
Robert
I got you man. I have decided just to wait. In the end it will be worth it, I just get very impatient somtimes.
Old 08-07-2007, 08:33 PM   #9 (permalink)
unbreakable's Avatar
id suggest bilstein dampers+ HnR springs = FTW
unbreakable is offline   Reply With Quote
Old 08-07-2007, 08:36 PM   #10 (permalink)
CivicBeater's Avatar
Eric
HFP kit on the way to my house FTW!
CivicBeater is offline   Reply With Quote
Old 08-07-2007, 08:38 PM   #11 (permalink)
2000civic's Avatar
Robert
They make dampers for our cars? Are they adjustable?
Old 08-07-2007, 11:24 PM   #12 (permalink)
Paul
i think they make custom dampers for the car. honda93 has some rear bilsteins.
Unbreakable, is this what you are running?
HFP Front Underbody Spoiler ONLY! iluvcivic Inside and Out 34 04-30-2008 05:12 AM
Comptech Springs / HFP Struts installed... blue rocket Suspension and Brakes 32 05-08-2007 05:28 PM
Guys, where to buy HFP lip kit online? dsg2003gt Inside and Out 14 03-22-2007 07:53 PM
Honda Announces New 2006 Civic HFP Packages Kabs Civic SI 2 11-01-2005 05:07 PM
