#162 (permalink) | |
![]() Tried to go for: Front: Camber -1.3 , Toe 0 Rear: Rear -1 , Toe 0 How does this look? What is SAI? It looks off. (as for the camber on the right rear, we got it close enough, but will be doing it again next week because I realized that the rubber bushing on my skunk2 camber arm was torn and wasnt able to adjust it because it would change as the suspension moved anyway) It was a pita to align this thing.. haha. It tracks perfect, and turns better now. Will be better once I finally get that bushing replaced and redo that wheel. Last edited by dannyd86; 07-13-2008 at 01:24 AM. |
#165 (permalink) | |
S52 > K20
Robert
it wont.. toe kills tires.
![]() Mod+Pic thread Quote:
#167 (permalink) |
well my shop reinstalled my camber arms on the other set of holes this time. only now instead of having -1.5F -2.0R, the best they could adjust is -1.5F -0.5R. dont get whats up with my arms/car why i cant get -1.0R like i want.
wonder how -0.5R will handle compared to -2.0R... |
#171 (permalink) |
Louder than 4 F404-GE-400
You should be fine as long as you put a little spirit into your turning. If you drive 100 miles a day on the freeway, you might see some extra inside shoulder wear, but it won't be much. Think of it this way, -1 in the rear is what it is set at from the factory. Are you running camber bolts in the front? If you are, they can slip and thats probably what the tech is referring to. Get some nylon locking nuts and some locktite. It will be tought to get off, but should help with the slipage. Camber plates can slip too but their is nothing I know of to prevent it.
You know what the sun's all about when the light go out. Last edited by Sirbelch; 07-30-2008 at 02:02 AM. |
#172 (permalink) |
Well, I just don't want to decrease the wear dramatically, if its gonna be like only 500 miles shorter life-span, its not a big deal, I drive my car mostly local anyways. Will the new settings be harder to control? Sorry for all the questions, thanks in advance.
#173 (permalink) | |
the tires will deterioate faster if you push hard around all the corners but who does that really? |
| Tein S-techs w/ SPC camber kit | Si_yoc | Suspension and Brakes | 3 | 04-12-2007 08:02 AM |
| s tech tein spring, need a rear camber kit? | ronjancivicsi | Suspension and Brakes | 4 | 04-06-2007 10:25 PM |
| Cheap camber kit? | 06RALLYREDSI | Suspension and Brakes | 50 | 03-14-2007 07:25 AM |
| i got away without camber kit. | darna | Suspension and Brakes | 13 | 12-10-2006 01:08 PM |
| Comptech vs SPC camber kit....need pics | 06Fg2 | Suspension and Brakes | 8 | 12-07-2006 10:18 PM |
