#121 (permalink) | |
Louder than 4 F404-GE-400
You know what the sun's all about when the light go out. |
#131 (permalink) | |
S52 > K20
Robert
Not enough to dial the car into autoX or track conditions.
For DD just use the stock settings. You will probably be ~ -1 with just bolts on stock.
![]() Mod+Pic thread Quote:
#132 (permalink) |
Spinning Triangles
really good info. My plan of attack is thus:
A) Learn to drive my car at it's limit, performance lessons so my limits are closer to the car's B) Get better performing tires C) Get Camber front and back and a solid allignment for the type of driving I will be doing mostly D) worry about shocks and springs and dropping after that. |
#133 (permalink) |
225/40/18 dropped on SKUNK2 Pro-S Coilovers, SKUNK2 Rear Camber arms, Ingalls camber bolts.
Approximate drop will be 1.25". How's this for my alignment specs? FRONT: 1.25 degrees negative camber, 0 TOE REAR: 1.25 degrees negative camber, 0 TOE NEEDS? Daily driver willing to live with minimal tire wear due to camber settings. Thoughts? Opinions? |
#135 (permalink) |
Need advice
Suspension:
Skunk2 Pro-C Sking 2 Rear Camber arms I bought a camber gauge and I began to set my camber today, (still need to go revise it) I have the following, Camber: F: -1.2 Passenger R: -1.5 / Drivers R: -2.5 (this is what I need to fix) I havent set the toe yet, I plan to take it somewhere for them to do that. I read that for the rear -1.2* is best, my question are as follow: is there a big difference between -1.2* and -1.5* ? does -0.3* have a large effect? I plan to set my car with zero toe in the rear, (I dunno about the front) and my camber -1.5* all around for DD, and then push the fronts to -2.5* for autoX
#140 (permalink) | |
I was responding to his post
Just fronts at stock height would be ok..set the front to -1.25 to1.5 degrees negative..Quote:
I knew that I was testing you! Not huge but I would prefer -1.5 or even -1.75
| Tein S-techs w/ SPC camber kit | Si_yoc | Suspension and Brakes | 3 | 04-12-2007 08:02 AM |
| s tech tein spring, need a rear camber kit? | ronjancivicsi | Suspension and Brakes | 4 | 04-06-2007 10:25 PM |
| Cheap camber kit? | 06RALLYREDSI | Suspension and Brakes | 50 | 03-14-2007 07:25 AM |
| i got away without camber kit. | darna | Suspension and Brakes | 13 | 12-10-2006 01:08 PM |
| Comptech vs SPC camber kit....need pics | 06Fg2 | Suspension and Brakes | 8 | 12-07-2006 10:18 PM |
