Old 12-20-2007, 07:27 PM   #61 (permalink)
He gets them out of the Factory Slip bolts...Not the factory mounting bolts. Honda allows up to 2 of their factory slip bolts to be used in order to keep the suspension within factory spec. There different that just the regular bolts...
Old 12-20-2007, 07:28 PM   #62 (permalink)
Louder than 4 F404-GE-400
Paul
Were do these slip bolts you speak of bolt up too?
Old 12-20-2007, 07:48 PM   #63 (permalink)
Right where the Factroy bolts mount the strut to the knuckle...There replacment bolts that are slighly thinner than the stock ones...No cam on the just a smaller bolt.
Old 12-20-2007, 07:58 PM   #64 (permalink)
Paul
He can be taught!!!! Thanks
Old 12-28-2007, 01:47 PM   #65 (permalink)
s0opa_Si's Avatar
PYT
great info! i will definately use the specs that were recommended in the first post of this thread! as far as alignment what can i tell them?
s0opa_Si is offline   Reply With Quote
Old 12-28-2007, 01:59 PM   #66 (permalink)
What do you mean what can you tell them...Tell them to set it to what I suggested, but camber kits are needed for this adjustment..
Old 01-10-2008, 10:53 AM   #67 (permalink)
Good info Highrev1
Do you have any opinions about Eibach's Prokit springs? I want to lower my Si conservatively without breaking my wallet. I know lowering/raising a suspension will change the geometry, but after reading this post it looks like I wouldn't need a camber kit with the Pro springs. Just an alignment job.
I do long commutes so treadwear is important to me. Any advice would help.
RBFG is offline   Reply With Quote
Old 01-10-2008, 10:59 AM   #68 (permalink)
I would get camber kit front and rear. Then get a nice alignment.
Old 01-13-2008, 07:13 PM   #69 (permalink)
mikey5x's Avatar
Michael
AFter how much of a drop would you suggest a camber kit - would 1.5" warrant one...
mikey5x is offline   Reply With Quote
Old 01-13-2008, 10:24 PM   #70 (permalink)
Even at stock height I suggest one.
Old 01-16-2008, 09:54 PM   #71 (permalink)
nelsonr31's Avatar
Originally Posted by Highrev1 View Post
Stock bolts have no adjustment....Lower mount should produce more adjustability..Its just a pivot remember..
Would you suggest using the lower mount as opposed to the upper mount for the front camber bolts? Just wondering cause SPC says top mount, I know it's just pivot points. Would a set of 4 be better then 2 or do you really only need 2?
nelsonr31 is offline   Reply With Quote
Old 01-16-2008, 10:06 PM   #72 (permalink)
Paul
4 will give you a larger adjustment range than 2. At 70 bucks for 4, why not?
Old 01-16-2008, 10:23 PM   #73 (permalink)
nelsonr31's Avatar
If i were to use 2 what would be the better mounting location, upper or lower or does it really matter? SPC says upper, can anyone suggest otherwise?
Old 01-16-2008, 10:47 PM   #74 (permalink)
buddy skunk = deaf :p
St Jude
ryryninja's Avatar
ry²
Thanks for all the help Greg.
Front is set at -1.1
Rear is set at -1.0
Couldnt get the last .1 but still good car feels awesome!
|126K Miles|^Click Pic to go to Build Thread ^|
|Crabs³ Meet INFO|hmm boostssss or rimps
ryryninja is online now   Reply With Quote
Old 01-18-2008, 06:46 PM   #75 (permalink)
quikhondadude's Avatar
marc
whats a good camber kit? i know theres a couple kinds so what do u recommend?
quikhondadude is offline   Reply With Quote
Old 01-18-2008, 07:01 PM   #76 (permalink)
Paul
The rear SPC kit is easier to adjust than the Skunk2 but I have heard that the SPC kit can slip.
Old 01-23-2008, 11:19 PM   #77 (permalink)
27IVTEC's Avatar
Jones
So if I go with the Eibach Pro kit, will I need a camber kit?
27IVTEC is offline   Reply With Quote
Old 01-23-2008, 11:24 PM   #78 (permalink)
Read page One it is suggested.....
Old 01-23-2008, 11:29 PM   #79 (permalink)
27IVTEC's Avatar
Jones
I have seen people that used these springs without a camber kit because it only drops 1". So if I dont get a camber kit how will my handling be effected?
Old 01-23-2008, 11:42 PM   #80 (permalink)
IMO..It's not about springs...Its about being able to adjust your alignment settings...Though maybee needed for tire wear why not have real control over your suspesnion for handling features?
Tein S-techs w/ SPC camber kit Si_yoc Suspension and Brakes 3 04-12-2007 08:02 AM
s tech tein spring, need a rear camber kit? ronjancivicsi Suspension and Brakes 4 04-06-2007 10:25 PM
Cheap camber kit? 06RALLYREDSI Suspension and Brakes 50 03-14-2007 07:25 AM
i got away without camber kit. darna Suspension and Brakes 13 12-10-2006 01:08 PM
Comptech vs SPC camber kit....need pics 06Fg2 Suspension and Brakes 8 12-07-2006 10:18 PM
