Old 11-04-2008, 07:34 AM   #201 (permalink)
I miss all the meets.
07k20z3ftw's Avatar
Mitch
how are you guys acheiving more than -.20 camber in the front with the spc bolts? when my car was aligned we could dial in more than -.20 camber in the front..? do i need two sets of bolts?
07k20z3ftw is offline   Reply With Quote
Old 11-07-2008, 08:00 PM   #202 (permalink)
i have a fg1 on 18" wheels and want to put tein s-tech on. on the website it says only 1.14" front and 0.83" rear. do you think i could get away without using any camber kit?
help anyone?
808TWFG1 is offline   Reply With Quote
Old 11-12-2008, 07:56 AM   #203 (permalink)
07k20z3ftw's Avatar
Mitch
bumpppp...?
Old 11-14-2008, 10:33 PM   #204 (permalink)
hatch's Avatar
Eric
I just went and got an alignment today. Stock Si Sedan suspension BTW. I bought the SPC front kit and didn't get anything for the rear. When I got my results back the guy said the rear was at -2.0 and that there was no adjustment. Was his equipment messed up? Or am I just reading the factory specs wrong in the OP? I didn't think it was supposed to be that much in the rear stock.
He dialed in -1.6 in the front.
hatch is offline   Reply With Quote
Old 11-15-2008, 07:38 PM   #205 (permalink)
nickk20fg's Avatar
JDM Nick
where can i buy a camber kit nd who is da best
nickk20fg is offline   Reply With Quote
Old 11-19-2008, 01:10 PM   #206 (permalink)
3 stars and a sun, 1 love
gOzP's Avatar
LUV 4 LYF
I have a question.
I just recently ordered Tanabe Springs DF210 and I am ordering the front camber kit.
What if i don't have the rear camber kit? WHat will happen will it destroy something inn my car?
My friend told me as long as i get my car aligned and wheel rotated i dnt have problem..
Answers are appreciated. THanks!
gOzP is offline   Reply With Quote
Old 11-19-2008, 01:17 PM   #207 (permalink)
Kitties rule, dogs drool.
xheartcore_boyx's Avatar
Addy
Yes i think that you will another set on bolts, i was advised to order two sets for that reason, they are on their way btw, not installed.
xheartcore_boyx is offline   Reply With Quote
Old 11-19-2008, 02:52 PM   #208 (permalink)
Kansas Chainsaw Massacre
ErichPryde's Avatar
Erik
with one set of bolts, I managed to get -1.6 degrees of camber up front. several questions- which bolt did you replace on the front suspension? and is your car at the stock ride height?
the rear isn't adjustable... but you haven't lowered your car? that sounds to be a bit much, but it could very well be right. I'd recommend that you purchase a rear camber kit.
Originally Posted by gOzP View Post
I have a question.
no, it won't destroy anything, you'll simply have a lot of negative camber. as long as you rotate your tires frequently, you should be mostly okay. IF you are purchasing a camber kit to actually make your car handle better, I'd strongly recommend getting a rear camber kit at this time.
K24 Powered.
ErichPryde is offline   Reply With Quote
Old 11-19-2008, 10:26 PM   #209 (permalink)
paolo2k2's Avatar
JPK
^^and pump up the air pressures!!
paolo2k2 is offline   Reply With Quote
Old 11-19-2008, 11:59 PM   #210 (permalink)
ErichPryde's Avatar
Erik
that helps... until the tires heat up so much that the pressure goes up even more and the back end can't get any purchase on the road surface to speak of.
K24 Powered.
Old 11-20-2008, 07:38 AM   #211 (permalink)
07k20z3ftw's Avatar
Mitch
erichpride, im dropped on skunk2 lowering springs/stock struts for now. and i have spc front camber bolts, one on each side, but i cant get it aligned more than -.20 in the front
Old 11-20-2008, 12:36 PM   #212 (permalink)
paolo2k2's Avatar
JPK
i just pump up my air pressures to lessen camber wear
Old 11-21-2008, 01:10 AM   #213 (permalink)
08_Civic's Avatar
Bboy
I'm a noob at this but So if I lower my car 1.5 in front and rear. And I order my Camber kit (both Front and Rear). Would I need to do the aliment before or after I put in the camber kit? And I see So many Camber kit and some are adjustable and How would I know how to adjust it to? The front that is. I hear the rear cant be adjusted.
08_Civic is offline   Reply With Quote
Old 11-21-2008, 01:12 AM   #214 (permalink)
buddy skunk = deaf :p
St Jude
ryryninja's Avatar
ry²
You get more adjustment if you put the camber bolt in the lower hole.
|126K Miles|^Click Pic to go to Build Thread ^|
|Crabs³ Meet INFO|hmm boostssss or rimps
ryryninja is offline   Reply With Quote
Old 11-30-2008, 02:52 AM   #215 (permalink)
dorkiedoode's Avatar
Kevin
alright guys i don't if this have been ask before, which im sure it probably has. so spare the flames and tell me to go and read the thread. i just need a quick opinion from all the suspension expert out there. i should be on my HFP kit next week. therefore the drop is not aggressive enough to use camber kits. but, i want to put a camber kit in anyways since i have all the front and the rear sitting at my desk now. so my question is what you guys think i should adjust my camber setting to when i get it align? i was thinking 1.5front and 1.25 rear but im not sure if that is good for HFP drop? i looking for something to get the most handle out of the HFP kit and not destroy tires.
dorkiedoode is offline   Reply With Quote
Old 11-30-2008, 02:56 AM   #216 (permalink)
ErichPryde's Avatar
Erik
your camber settings are somewhat independent of the drop. changing your camber will improve your handling regardless of whether or not your car is lowered... those camber settings look good and shouldn't cause you any issues.
K24 Powered.
Old 12-04-2008, 08:16 AM   #217 (permalink)
nickk20fg's Avatar
JDM Nick
can i adjust the stock rear camber kit myself or does it need a special tool
Old 12-06-2008, 04:40 PM   #218 (permalink)
Kevin
thanks bro. im going to go set it this weekend.
Old 12-14-2008, 01:49 AM   #219 (permalink)
Kevin
Bump.
Old 12-15-2008, 11:47 AM   #220 (permalink)
Kevin
Does anyone know if I can run with camber up front and oem back? Cause I only have the bolts in the front and I want to set it -1.5 front and oem back. Will that destroy my handling without the rear camber kit?
Tein S-techs w/ SPC camber kit Si_yoc Suspension and Brakes 3 04-12-2007 08:02 AM
s tech tein spring, need a rear camber kit? ronjancivicsi Suspension and Brakes 4 04-06-2007 10:25 PM
Cheap camber kit? 06RALLYREDSI Suspension and Brakes 50 03-14-2007 07:25 AM
i got away without camber kit. darna Suspension and Brakes 13 12-10-2006 01:08 PM
Comptech vs SPC camber kit....need pics 06Fg2 Suspension and Brakes 8 12-07-2006 10:18 PM
