#2 (permalink) | |
- Mark 2008 Honda Civic SI (stock) 2006 Honda Civic EX (sold) |
#11 (permalink) |
I guess the only way to be sure is to measure the diameter of the SI's front rotor, including the caliper. Can any SI owners help ? Thanks in advance....
It'll be great if the Si's front brake kit can fit the 16" rim, cos I'd want to keep the rims when I do the upgrade. Below are the parts which I intend to order from Hondapartsdeal. Anything I missed ? Part No Description Qty Req 44300-SDA-A52 BEARING ASSY., FR. HUB 2 (NSK) 44600-SDA-A10 HUB ASSY., FR. 2 45018-SVB-A01 CALIPER SUB-ASSY., R. 1 45019-SVB-A01 CALIPER SUB-ASSY., L. 1 45022-SVB-A02 PAD SET, FR. 1 45251-SVB-A50 DISK, FR. BRAKE 2 45255-SVB-A01 SPLASH GUARD, FR. (16") 2 90107-SM4-000 BOLT, CALIPER MOUNTING 4 90113-SM1-005 BOLT, WHEEL 10 90681-SDA-A00 CIRCLIP, SPECIAL (INNER) (86) 2 93600-06014-0H SCREW, FLAT (6X14) 4 93892-05012-08 SCREW-WASHER (5X12) 6 01463-S2A-000 CALIPER SET 2 51211-SNG-010 KNUCKLE, R. FR. 1 51216-SNG-010 KNUCKLE, L. FR. 1 |
#12 (permalink) |
Besides bigger front rotors (SI - 16", EX - 14"), the SI has bigger pistons (54mm) and calipers too. Also, I found out the bearings, wheel hub, front knuckle and lower arm of the SI are different from EX's (by checking part numbers). Honda probably made the SI's brakes and suspension links beefier than the EX, to take on the extra power.
#17 (permalink) | |
| speed limit in the ex coupe | leviathan18 | Civic Coupe And Sedan | 66 | 02-27-2008 03:57 AM |
| Just another EX Coupe | Retread | Introduction & Pictures | 10 | 05-06-2006 12:00 AM |
| EX Auto Sedan w/ Navi in Atomic Blue | NorahCRV | Driving Experience | 5 | 04-21-2006 09:07 PM |
| My 06 Coupe | rex | Garage | 18 | 10-21-2005 10:38 PM |
