Old 07-17-2007, 11:18 PM   #1 (permalink)
brake fade
I went to shannonville motorsports on Sunday and had a blast on the track.
However, my brakes turned into mush after 4 laps of 4k track. I would let them cool for 20 minutes and then try again.
The car brakes amazingly, with great feel - but they were heating up so bad. Smelled/looked like i was frying a cat on my discs.
So what can I do for a reasonable price to reduce this problem? I don't really want better brakes, I just want them to not heat up as fast.
funke is offline   Reply With Quote
Old 07-18-2007, 12:53 AM   #2 (permalink)
I eat my r6
FijiPhil's Avatar
Phil
better brakes. lol sorry but you would need new pads and rotors i think. You could go for a big brake kit and stand on those brakes all day.
FijiPhil is offline   Reply With Quote
Old 07-18-2007, 01:00 AM   #3 (permalink)
Louder than 4 F404-GE-400
Paul
^^^You really dont need all that. Get some higher temp pads, stainless steel brake lines, and a break fluid with a higher boiling point that the stock fluid, like a DOT 5.1. That should hold off the heat enough for you to have some fun without brake fade. But if you want brakes you can hammer all day, you got to get bigger rotors and bigger hats with bigger pads and a bigger master cylinder. (Brakes will break your bank (sorry couldn't resist))
Old 07-18-2007, 01:07 AM   #4 (permalink)
This is a 12.2" wilwood kit that cracked the rotor no brakes are indestructable, especially on the track.
Old 07-18-2007, 01:11 AM   #5 (permalink)
thanks Sirbelch,
Can i just get bigger rotors without the calipers? Will he larger diameter disc help cooling?
Old 07-18-2007, 01:15 AM   #6 (permalink)
Originally Posted by funke
thanks Sirbelch
Boy I feel like poop now. I taught him eveything he knows About true suspension tuning
THis link will help
http://www.teamscr.com/grmbrakes.html
Old 07-19-2007, 08:19 PM   #7 (permalink)
Paul
THis link will help
You did not teach me everything i know, just a lot about suspensions.
Old 07-19-2007, 08:21 PM   #8 (permalink)
Expect a PM
Old 07-19-2007, 09:02 PM   #9 (permalink)
Paul
we own the suspension and brake threads.
Old 07-19-2007, 09:09 PM   #10 (permalink)
For good reason...people know that a "pre-built coilover" won't keep up with a seperate setup and have no facts to back that up even if they were to say it did. ANd we know the black art of suspension tuning. :)
Old 07-19-2007, 09:18 PM   #11 (permalink)
AND YOU ARE THE MAN!!!!
Old 07-19-2007, 10:18 PM   #12 (permalink)
Paul
Did you just call yourself the man? Can you even do that?
Old 07-19-2007, 10:20 PM   #13 (permalink)
That was YOU!!! I hit quote instead of edit...Thursdays are my drinking nights.
Old 07-20-2007, 08:16 AM   #14 (permalink)
HondaScott's Avatar
Scott Varnhagen
I've only tracked my car once so far this year (been busy karting) BUT the time I did I used some HFP pads and I got very little fade.
When I say very little, I mean that I could tell the pads were heated up and needed a little extra force on the brake pedal, but they stayed pretty linear and I never thought I was going to die because I couldn't slow down. Also, no damage was done to my rotors. It is AMAZING the difference that a set of brake pads can do on a weekend track car. I doubt you will boil your fluid as it is so new, but it never hurts to have a higher boiling point fluid.
Scott
HondaScott is offline   Reply With Quote
Old 07-20-2007, 08:19 AM   #15 (permalink)
Jardiniboy's Avatar
Jasten
Dang that rotar is ______. Speechless. That thing got pushed to actually over the limit.
Old 07-21-2007, 04:36 PM   #16 (permalink)
what should i look for when buying pads?
also, it'd be nice if they aren't too squeaky
Minor Brake Upgrading 604_ep3 Suspension and Brakes 5 02-26-2007 01:13 AM
Brakes (06' Si) Parts-list: Torredo Suspension and Brakes 3 12-07-2006 02:59 AM
How Many Experience Brake Fade....???????? F.I.A.T Forced Induction And Nitrous 17 11-24-2006 10:22 AM
brake - heads up. sickyute Suspension and Brakes 19 11-23-2006 03:37 PM
