#41 (permalink) | |
63.7% Bostonian.
You could always get them plated, but could be a pain in the ass if you don't reguarly have parts plated. At work we regularly have parts plated in bright zinc and yellow chromate.
. Si away for the winter ![]() Winter projects: - LED taillights (following in Nomar's footsteps) - two-tone seats - misc electrical stuff - audio overhaul - random powdercoating Quote:
#42 (permalink) |
I may not do anything as that will up the price I am hoping to get these things sold for like 20 bucks....Now that I think about it, Get out the old can and spray em down, or go buy a can of underbody spray and use that. This will help keep the cost down for you guys and for me
#43 (permalink) | |
Webby's Minion
#47 (permalink) | |
I am the Juggernaut!!!
#48 (permalink) | |
#57 (permalink) | |
-Someone check the Si and non Si control arms. Maybe that welded peice of metal which conects the endlink to the control arm is thicker, better reinforced on the Si control arms, than on the non Si control arms. I bet the Si has heavier lower control arms, which one can infer is because its using thicker steel or aluminum, whatever. |
#58 (permalink) | |
Webby's Minion
#59 (permalink) | |
63.7% Bostonian.
^ Yes, however I had a brief look at Yodums' LCAs when we met up a few Fridays ago, and the brackets on the Si's definitely look different. Honda's drawings are the same (Si LCA vs. non-Si LCA), but their part numbers are different.
However, if they all have the potential to break (as it seems currently) then it may be a moot point. Best just to reinforce them all I think. And yes, Andrei, the break point on mine was the bracket on the LCA (a "tear-out" on the mounting hole), but that bracket is part of the LCA. But it still makes sense to get aftermarket endlinks... if you reinforce the LCA bracket, that means that something else becomes the "weak link." Would it be the endlink? Who knows, but for $55, I'm willing to upgrade those too and play it safe.
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/47299-sway-bar-reinforcement-brackets.html
| Sway Bar reinforcement brackets. - 8th Generation Honda Civic Forum | This thread | Refback | 12-18-2007 06:45 AM | |
| Si Rear Sway Bar on CSX | iluvmycsx | Suspension | 23 | 11-13-2008 09:13 AM |
| Roll Call! Who with a non-Si has upgraded the rear anti sway bar? Si bar fits LX? | Andrei'sCivic | Suspension and Brakes | 13 | 07-01-2008 05:07 PM |
| Problem with the Progress Sway Bar on an 07 SI Sedan. | SIis4ME | Civic SI | 7 | 04-17-2007 03:34 PM |
