Old 06-26-2007, 10:52 PM   #1 (permalink)
Hondacivicsi23's Avatar
Michael
Front lowering springs no rear?
Ok, this might sound dumb but...I was curious... Would it be possible to just change your front springs and leave your rear stock. That way you would have say a 1.4 in drop in the front so your car has the agressive stance where it is tilted foward? If this is possible would you still need a rear camber even though your springs in the rear are still the same?
I ask this because my subs are very heavy and the back is very low. People ask if my car is lowered all the time. But, if I get lowering springs I dont want the car to be tilted back more than it already is. Yes, I know some companies have the springs that are lower in the front than the back like tein 1.4 f 1.5 b.. there is much more than a .1 difference from the front springs and the rear springs on my car already so thats not ganna help much.
Hondacivicsi23 is offline   Reply With Quote
Old 06-27-2007, 01:13 PM   #2 (permalink)
Michael
No input from anyone??
Old 06-27-2007, 01:17 PM   #3 (permalink)
Supreme Pizza!
Izzy's Avatar
Lowering springs are usually stiffer than OEM, so your rear won't sag as much. But, just getting front springs is doable, probably not advisable though. You'll end up with a rather twitchy back end since they're "looser" on the back. Your camber will not have to be adjusted.
Old 06-27-2007, 01:28 PM   #4 (permalink)
RWatters's Avatar
You can do it.
It'll look really, REALLY retarded if you ever take those subs but you can do it.
From a performance standpoint, it's probably about the worst thing you could do to the car suspension-wise outside of cutting/heating the springs.
RWatters is offline   Reply With Quote
Old 06-27-2007, 05:29 PM   #5 (permalink)
Jardiniboy's Avatar
Jasten
Get eibach springs then change only the fronts. Then after if you don't like it you can change the rear springs.
Old 06-27-2007, 07:11 PM   #6 (permalink)
GALAXY~SI's Avatar
Kurt
this is how it would look here you go
S-techs in the front Oem in the Rear
last one stock but its a good pic damn
GALAXY~SI is offline   Reply With Quote
Old 06-27-2007, 08:27 PM   #7 (permalink)
Louder than 4 F404-GE-400
Paul
My $.02. It would make your car push like a dump truck because lowering the front will shift even more weight to the front than there already is. Now its about a 61/39 F/R weight distribution, doing that would make it like 66-69/34-31 F/R. It might look cool, but who cares about looks if you can't back it up with performance. I do belive, thats one of the definitions of rice. Or, you could just get rid of the 200+lbs of subs in the trunk and get better gas mileage and handling and acceleration to boot.
People with lowering springs... How are you stock struts holding up? DumbasSi Suspension and Brakes 41 09-02-2007 09:43 AM
Megan H-Brace and lower rear brace Review 604_ep3 Suspension and Brakes 38 03-21-2007 01:32 AM
2006 Civic Summary from Temple of VTEC shoptb Driving Experience 4 01-11-2006 02:40 AM
