springs bad?
hey im not really very knowledgable on the topic of suspension, but i heard that if one gets performance springs without upgrading the struts etc, the struts and/or other parts may brake due to the different springs
does anyone know wat im talking about? thankss thanks |
#6 (permalink) | |
Taken from the suspension bible:
![]() Notice the shock travel is about 4"? That distance is cut down in half when you lower your car.
"All springs "Bounce" its in their nature. Dampers Control the springs Occilations (bouncing). So if your car is bouncing, its not the springs fault its the dampers fault. To stop them from making the ride bouncy you need the proper damper (shock)."
As you can see without a proper damper lowering springs can do more harm than good. You are limiting suspension travel, and hampering the way your dapmers control the sprign and the ride. You will hear people say "Oh I pust springs on my car and the other day I blew a shock" EH it DOESN"T happen that way. They don't just last so long then go one day, They slowly degrade over time. The day you drive your car off the lot they start to degrade. You probably will never tell that they are getting worse unless you replace them with new ones and then say wow this is different. Handling and ride will change with new shocks and you will be able to tell how bad your present one were. "So, do your self a favor. if you are rideing on OEM dampers with lowering springs now, pick up some quality performance dampers when they come out. THey are well worth it... given that your dampers will do more for your cars overall performance then springs alone ever could." |
[quote=Highrev1]"So, do your self a favor. if you are rideing on OEM dampers with lowering springs now, pick up some quality performance dampers when they come out. QUOTE]
Custom koni's are, so are custom Moton's. And one OTS damper I forget which company. But for the most part your right no good options out right now.
#11 (permalink) | |
The transition is what potentially hurts performance. An abrupt change from a lower to higher spring rate can cause an unexpected loss in traction, esp. under quick weight transfer. This, however, depends on how severe the spring rate ramps up. Heck, the '98 ITR in Japan had progressive rate springs to the rear (2.5-4.5 kg/mm or 140.0-252.0 lb/in). I agree that correct dampening along with the right springs will always be better than just springs. But that isn't to say certain lowering springs won't benefit handling. Getting a coilover isn't necessarily the "better" setup, and springs aren't necessarily "bad." |
#13 (permalink) | |
#14 (permalink) |
AKI Not trying to be a dick here Its tuff to tell Sacasam especially mine, online, I am a pisser I know
![]() Notice here they give two numbers one for inital spring rate and one for compress 06+ Civic Si 2/4dr Spring Rates and Drop Guide both the transion and the fact that there isn't a set rate and it is ALWAYS changing, that is what makes them less of a performance spring. Spring rates aren't that import, the wheel rates are what is the key to handling/traction. FIrst firgure out the motion ration of the suspension, its like .95 up front or so and the rear is about .6. Front wheel rate 190 Rear wheel rate 138 This means the rear spring should be about 70% stiffer. Most companies aren't like this on many setups because there are other things that influence wheel rates. Also they need to sell these to JoeSMOE/public and they are used on the street mostly and want to set your car up for understeer for Lawsuit reason :) Back on topic....... There is plenty of "credence" to it The stock dampers suck, they are barely good enough for the stock springs. Personally I've already had my stock ones replaced by the dealer as have alot of other members on the site. So if you change to an aftermarket spring the chance of ruining your dampers is increased. I am not expressing that any car wont handle better then stock with just performance springs on stock dampers, I'm saying that if you were to only change out one part, Springs OR dampers, that you'd see a bigger gain in handling by swaping out the dampers Then you would with just changing springs. Its not ideal to do just springs. IMO is worth waiting for companies to come out with any decent damper "Ok, the amount of traction a tire makes is determined by how much weight is placed on that tire. Meaning, as more weight is applied to the tires contact patch, the more grip that tire has. However! as weight is applied to the tires contact patch, the rate in wich traction is gained is reduced. Meaning the tire gains traction at a lower and lower rate as weight is applied. Example (Fake tire) Tire A has 50LBS applied to the contact patch and makes 150 "Units" of traction. A 1 To 3 Ratio (Weight Vs Traction) If 100 LBS is applied to the tire, it now makes 250"Units" of traction. A 2.5 To 1 Ratio. So you see that even though the tire makes more traciton, it is at a lesser rate. now if you extrapolate this out, there will be a point where the amount of weight applied to the tire exceeds how much traction it can make. that is the point of saturation, and the tire begins to slide. You can see how controling weight is very important to the handling of a car. Where it goes, how fast it gets there, how smoothly it gets there ect.... Handling is all about controling weight. And what controls weight transfer the Low speed damper valving, it alters the speed in which weight is transfered around the chassis during a turn." Quoted from a wise man
#15 (permalink) | |
#16 (permalink) |
Well considering we have "coilovers" from the factory
They aren't bad I am just not a fan of the "pre-built" coilovers at ALL. Most people know that :) I would much rather "piece" my suspension together pick my springs pick my valving, pick my bushings etc..If your never going to use it why get it...No need to spend money where it isn't going to be used, A TRULEY good suspension won't be used on the street by any means. I am glad to see there are more than just Fanbois on this site |
| Understanding Springs and Coilover? | kenken3686 | Suspension and Brakes | 15 | 01-30-2008 07:21 PM |
| Review: Megan Racing Springs (Prototype Model) | shglbmx | Suspension and Brakes | 6 | 09-19-2007 12:36 AM |
| H&R Sport springs? | Airwolf | Suspension and Brakes | 34 | 12-15-2006 08:53 PM |
| Any Springs will fit? | hoanger | Suspension and Brakes | 11 | 06-07-2006 01:15 AM |
| Looking for Tien S-tech springs in Vancouver | Rpm2 | Suspension and Brakes | 8 | 05-15-2006 09:06 PM |
