Old 06-17-2007, 11:11 PM   #1 (permalink)
andywho's Avatar
andy
Question ground control
does anyone on this site have ground control setup? i'm looking for adjustable ride height.
andywho is offline   Reply With Quote
Old 06-17-2007, 11:21 PM   #2 (permalink)
PM Toxis I know he got a set of em I dunno if he installed them though.
Old 06-18-2007, 08:13 AM   #3 (permalink)
andywho's Avatar
andy
no one eles have ground controls?
do anyone know were i can get them?
Old 06-18-2007, 12:14 PM   #4 (permalink)
Ground Control has a set available for the stock shocks. Part number is #4536.01. :)
AdvancedPersonalConcept is offline   Reply With Quote
Old 06-18-2007, 07:37 PM   #5 (permalink)
andywho's Avatar
andy
thanks i might go with these and upgrade to koni yellows
Old 06-18-2007, 07:39 PM   #6 (permalink)
andywho's Avatar
andy
can i order them? does anyone know what kind of springs come with them??
Old 06-18-2007, 07:43 PM   #7 (permalink)
civsnake's Avatar
English Classassin
The ground control kit currently available is matched to the stock shocks. When Koni releases the sport dampers, ground control will make a new setup with stiffer spring rates to match the harder dampers.
civsnake is offline   Reply With Quote
Old 06-18-2007, 07:59 PM   #8 (permalink)
andywho's Avatar
andy
so should i wait to get the ground control till koni comes out with there yellows?
and whats the make of the springs for the ground control that is available now?
Old 06-18-2007, 08:09 PM   #9 (permalink)
THeir Eibach springs, as long as the damper housing is the dame diameter as the stock ones then the aftermarket dampers should work with new springs on the standard kit. We don't know this yet until konis are released.
With any luck they will be the same and all you will need to do is replace the springs which is fairly inexpensive.
To be for sure though I would wait.
http://www.8thcivic.com/forums/showthread.php?t=34269
Old 06-18-2007, 08:14 PM   #10 (permalink)
Louder than 4 F404-GE-400
Paul
Uhhhhhhh, don't you have koni's on your car Highrev? Do you sell the GC coilovers on your site too? (plug for you :)
Old 06-18-2007, 08:18 PM   #11 (permalink)
I did, but mine were a totally custom setup. Double adjustable and inserts for the front stock strut housings. Reall trick setup
Fixed
Old 06-18-2007, 10:59 PM   #12 (permalink)
Paul
did you paint them yello then? cause i could have swore that in the pick you showed me they were yellow. How come you dont have the GC on your car yet? I was gonna wait for the full GC coilovers but i'm weak and couldn't wait.
Old 06-18-2007, 11:10 PM   #13 (permalink)
Yeah Koni's are yellow. They came that way see in the pick that extra was welded on and then re sprayed by koni.
Why don't I have koni's. Well we ran in G-Stock with the car last year to see if it could be competitive against the mini coppers and NOPE I guess I don't have them cause I am just toooooo busy on here helping you to install them I will get them as soon as my moton's come in I wish I will get em I am just waiting cause as it sits now the car is not terrible and I am still able to have fun with it, unless the A/C is on. Although I do complain daily about how the car is :) I will do somthing Stupid suspension wise very soon You won't be dissappointed
Old 06-19-2007, 12:56 AM   #14 (permalink)
Toxis's Avatar
Even Women Aren't Safe
I have the GC's for stock struts on now. They're nice seeing it's Eibach springs but I'm not happy with how they fit. The rears seem too short. If I lift the car off the ground say on a lift or to adjust something/install the rear sway or whatever, the rear springs pop out of placement and it's a royal pain to get them back where they sit flush. I get a lot of noises right now but it's getting better since they're breaking in (been on for 3 weeks or so now). I do have to say that I'm not happy with how high the rears go. Literally at it's highest setting, there's not even half a finger's gap. So adjustable up front yes. Rears can only go tucked really.
Toxis is offline   Reply With Quote
Old 06-19-2007, 01:02 AM   #15 (permalink)
dt07Si's Avatar
Dave
Hmmm interesting. It's nice to finally here some input on them.
dt07Si is online now   Reply With Quote
Old 06-19-2007, 01:12 AM   #16 (permalink)
Toxis's Avatar
the ride is rougher than stock by quite a bit. It really gets bouncy at times. Another FYI.
Old 06-19-2007, 09:32 AM   #17 (permalink)
andywho's Avatar
andy
damn. did you ever thought about getting any other aftermarket springs toxis? it might help with the bouncing issue and the rear tucking
Old 06-19-2007, 03:11 PM   #18 (permalink)
Rolow's Avatar
Do you know what the spring rates are?
Sounds like your not happy with the spring rates that came in your kit. Looks like the GC site lists them at $60 a set. If you plan on buying new struts you might want to wait before buying new spring rates.
Any pictures of you set up?
Rolow is offline   Reply With Quote
Old 06-19-2007, 04:40 PM   #19 (permalink)
Paul
A stiffer spring rate (doesn't sound like what you want but...) might get the back end a little higher off the ground.
Old 06-19-2007, 04:43 PM   #20 (permalink)
Paul
What are you gonna do? tell me tell me tell me. How do you plan to take out dem Mini's? I've read else where that they are tought little buggers.
Automatic Climate Control threads merged dpnvektor Do It Yourself Articles 178 10-07-2008 07:15 PM
ground control? jb07si Suspension and Brakes 3 04-05-2007 03:48 PM
Ground Control Coilovers? pdiddy2386 Suspension and Brakes 6 01-13-2007 04:37 PM
Intalling cruise control in a LX sedan Bicudo2 Do It Yourself Articles 8 06-08-2006 10:01 AM
05 Si Ground Control Coil-Overs Groundcontrol Suspension and Brakes 2 05-24-2006 01:34 AM
