Old 06-17-2007, 02:02 PM   #1 (permalink)
How to adjust Toe?
sorry for posting a new thread, but nobody is replying to my other thread. my question is does anyone here know wich exact bolt adjusts the toe? i think im gona try to mess with it , and then go get another alignment.
NJ-SIsedan is offline   Reply With Quote
Old 06-17-2007, 02:49 PM   #2 (permalink)
8thcivic Sponsor
Don't touch it let it be adjusted when you get an alignment. Isn't somthing you can do by sight you need alignment equipment.
Or you can be brave and do it yourself.
http://www.negative-camber.org/jam14...alignment.html
Old 06-17-2007, 02:52 PM   #3 (permalink)
CZ-75's Avatar
Brian
This is the whole point of an alignment.
CZ-75 is offline   Reply With Quote
Old 06-17-2007, 03:29 PM   #4 (permalink)
yea thats what i thought, but the honda dealer did it half ass so i think. my total toe is .76
RR- .49
RL- .28
i just need to know the bolt to adjust it
Old 06-17-2007, 04:47 PM   #5 (permalink)
night shift whore
pineapple's Avatar
simply hawaiian
you may make it worse... but if honda did it, take it back tell them to redo it.
you can find me at www.stuntlife.com it's my old home
pineapple is offline   Reply With Quote
Old 06-17-2007, 04:58 PM   #6 (permalink)
They adjust it to "within spec". If you want to set to exactly zero then you have to specify that.
yeos is offline   Reply With Quote
Old 06-17-2007, 08:48 PM   #7 (permalink)
Brian Bartley
RR- .49
RL- .28
This is NOT within Honda spec.
Here is the Honda specs:
Honda spec for toe on all 2006 - up civics except hybrid:
Front: -0.04in. - 0.04in.
Rear: 0.02in. - 0.08in.
Total toe Front: -0.08in. - 0.08in.
Total toe Rear: 0.04in. - 0.16in.
Brian
06S2k07Si is offline   Reply With Quote
Old 06-17-2007, 08:54 PM   #8 (permalink)
Brian Bartley
What are your rear camber specs after the alignment?
Brian
Old 06-17-2007, 09:01 PM   #9 (permalink)
Brian Bartley
Ok I just found the rear specs that you listed -1.9.
Im assuming at this time that the geometry may dictate that the more neg camber you have the more toe you will have.
I do not know for certain.
Try to remove some of the neg camber to get it to around -1.0 or less. Take out the top outter most bolt of the Skunk2 kit, thread out the end a few turns and re-install the bolt. Be sure to do exactly the same turn count on both sides. then get the car re-aligned.
The Honda dealer SHOULD know how to do this.
Brian
Old 06-17-2007, 10:54 PM   #10 (permalink)
yea i dont think they would redo it. being that the car is lowered. ?
Old 06-18-2007, 07:49 AM   #11 (permalink)
Brian Bartley
Is there another Honda dealer in your area that you could go to?
You are gonna tear up your tires quite quickly with your current alignment.
Brian
Old 06-18-2007, 10:43 AM   #12 (permalink)
XSRCivic's Avatar
You don't have to take it to a Honda dealer to get it done. Any experienced alignment shop can hook you up. I brought my old civic to Ford to have it done. They have a highly expensive computer assisted device. Just because its a Honda doesn't meen other places won't know how to work on it. Get your ish fixed before you end up spending a few $100 on some new tires.
XSRCivic is online now   Reply With Quote
Old 06-18-2007, 12:30 PM   #13 (permalink)
Brian Bartley
...agreed...
Brian
How do I adjust headlight aim?? Thayer Lighting, H.I.D.'s, & Neon 48 09-29-2008 11:02 AM
Suspensions!!! Highrev1 Suspension and Brakes 242 09-25-2008 01:11 PM
Adjust your settings! Toxis Water Cooler 9 02-06-2007 07:24 PM
TOE Thread whitecivicsi Water Cooler 28 11-17-2006 05:41 AM
