Old 06-15-2007, 04:27 AM   #1 (permalink)
Obsidian6's Avatar
Progress RSB w/ stock EX front?
So I'm looking to upgrade the very very small 11mm rear bar on my ex coupe. But I want it done right. Easy answer is of course just getting the progress RSB and using it in conjunction with the 25.4mm front bar in the EX.
however, I have heard that one would need to upgrade the endlinks with something like this.
now what I'd like to know, is how would a setup like that handle? Mind you, my car is bone stock right now, but I do plan on getting the HFP suspension. I don't want to go too over the top because this is my DD and I would like a small bit of comfort to remain.
Will it handle well with the stock front and the progress rear? ( and eventually with the HFP suspension too. )
thanks!
Obsidian6 is offline   Reply With Quote
Old 06-15-2007, 07:48 PM   #2 (permalink)
SI front sway bar
Sorry...Next post
Jay Kincannon is offline   Reply With Quote
Old 06-15-2007, 07:49 PM   #3 (permalink)
Si front sway bar
IMO..All suspension/handling aftermarket modifications for the 2006-2007 Civics are designed for the Si version, except the HFP items by Honda. Having said that, the Progress rear sway bar is no exception. Therefore I think you should install the Si front sway bar with Si bushings, etc. to bring your EX up to par with the Si suspension. Side note. When you do get the HFP sport suspension, make sure it is for the non-Si version.
Old 06-16-2007, 01:45 AM   #4 (permalink)
Andrei'sCivic's Avatar
Andrei
My LX had the 17mm solid oem Si rear sway bar and the stock sway bar up front. It definetly helped, but I felt the rear end was a little twitchy. Like if I hit a long gradual curve at 70mph and I continued to push on the gas progressively I was afraid the rear end would spin out. I then installed the Carbing front upper strut bar and the car felt more neutral, more balanced unlike before oversteer started to creep up on me in the high speed curves.
-I would definetly tell you to get the Si front sway bar, if you are going to go with the Progress rear sway bar.
Andrei'sCivic is offline   Reply With Quote
Old 06-17-2007, 01:55 AM   #5 (permalink)
Obsidian6's Avatar
Thanks for the tip, I will keep that in consideration then. I guess what I'll do is get the HFP suspension first, along with the 17s they offer. then figure out the swaybar situation.
so if i go the route of the Progress rear bar, I should definitely upgrade the front to the Si setup correct?
So would it be advisable then to start with a full SI set then go with the progress later?
Old 06-17-2007, 04:35 AM   #6 (permalink)
Andrei
You could do what i did... Just get the rear Si sway put in. Later you can get the front one put in. Then you can get the progress sway bar in the rear with the si one up front. However if you noticed that thread that one guy posted... he had a progress sway bar in the rear of his Civic EX and his endlink broke off the bracket which is welded to the lower control arm. So just wait with the rear progress bar.
Old 06-17-2007, 11:00 AM   #7 (permalink)
Obsidian6's Avatar
ah. yes I would not want that to happen lol. I'll start small with the Si bar then lol.
I did hear however that it was advisable to get the whole front stabilizer assembly for the Si setup, over just getting the bar.
Old 06-18-2007, 11:31 AM   #8 (permalink)
Mike A
I did the SI front and Progress rear on my 07 LX Sedan, and I am very happy with the results.
dallas_mike is offline   Reply With Quote
Old 09-17-2008, 05:20 AM   #9 (permalink)
I have SI front and SI rear on my DXG. I like it, car is rock solid. Understeer is higher, so if you want all round performence then do what i did.
BUT if u want higher limits get progress Rear and SI or LX front.
pks17 is offline   Reply With Quote
Si Front & Rear Sways on an EX Sedan iVTEC Suspension and Brakes 231 09-15-2008 05:21 PM
What are Stock EX Rims/Tires worth? In Concert Wheel And Tire Upgrades 10 03-29-2006 09:03 PM
