#2 (permalink) | |
See pics here: http://www.8thcivic.com/forums/showt...408#post866408 Brian Last edited by 06S2k07Si; 06-14-2007 at 07:22 AM. |
+rep!
Wow, nearly a full degree picked up from a 1" drop. That's quite a camber curve! My goal is -1.25 for the rear and -1.5 for the front. This should be a good compromise between tire wear and performance. I have the Ingalls bolts for the front so I should be good there and I guess I will get one of the rear camber kits as well. Thanks man! |
#5 (permalink) | |
If there isn't a whole lot of toe in/out (hence try for 0 toe), -2 deg isn't really THAT bad for tire ware. Toe tears up tires worse that neg camber. My car is a daily driver and I just wanted to have less neg camber...you don't NEED the kit...I'm just being anal! Brian Last edited by 06S2k07Si; 06-14-2007 at 09:18 PM. |
#6 (permalink) | |
If you plan to get a rear kit, look at the Skunk2 kit, the ends are threaded for adjustment. They aren't like the SPC or Comptech pieces that adjust with a cam that could possibly move over time. Brian Last edited by 06S2k07Si; 06-14-2007 at 09:21 PM. |
| SPC Camber Kit Rear | Civic_Si | CorSport | 41 | 10-14-2008 01:11 PM |
| s tech tein spring, need a rear camber kit? | ronjancivicsi | Suspension and Brakes | 4 | 04-06-2007 11:25 PM |
| List of problems with my LX Coupe 5sp. | vtecharry | Civic Coupe And Sedan | 220 | 03-11-2007 06:47 PM |
| 06+ Si Rear Camber Kit | Conrad.TDI | Suspension and Brakes | 0 | 09-13-2006 03:21 PM |
| sportline rear drop looks funny | bodydraggin | Suspension and Brakes | 13 | 07-30-2006 02:38 PM |
