View Poll Results: Has this happened to you? (Only vote if you fall into the following categories)
Yes, with a Progress rear sway bar 25 8.33%
Yes, with another aftermarket rear sway bar 3 1.00%
No, but my stock end links broke 15 5.00%
It won't ever happen to me because this thread really scared me! 257 85.67%
Voters: 300. You may not vote on this poll
LinkBack (7) Thread Tools Display Modes
Old 06-14-2007, 07:46 PM   #81 (permalink)
Originally Posted by Highrev1
Price is gonna depend on how many people want em. I would say like 30-40bucks shipped, that is just an inital estimate, obviously less with more people.
I don't want to have 5 sets sitting around my garage
I'm game...You making them out of solid gold or platinum?
blue1 is offline   Reply With Quote
Old 06-14-2007, 07:47 PM   #82 (permalink)
Titanium of course
or carbon fiber.
Old 06-14-2007, 08:17 PM   #83 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
Titanium of course
or carbon fiber.
Will it come in Wrinkle Red as well?
Old 06-14-2007, 08:18 PM   #84 (permalink)
Andrei'sCivic's Avatar
Andrei
Endlinks are the same on all trims however ( http://www.hondanews.com/categories/957/releases/2778 ) claims that the Si has: (over the non si Civic)
Heavy duty front wheel hub and bearings
Heavy duty front and rear lower control arms
Andrei'sCivic is offline   Reply With Quote
Old 06-14-2007, 08:27 PM   #85 (permalink)
Storm's Avatar
Good find. Thanks
Storm is offline   Reply With Quote
Old 06-14-2007, 09:18 PM   #86 (permalink)
Frightened inmate #2
J-Ro's Avatar
Jason
^ Earlier in this thread, I forget where, I posted my findings from hondapartsdeals.com. The Si and non-Si part numbers for the LCA are different, but I realized today that that is likely due to the different hub/knuckle design. From blueroadster's pics, the endlink bracket looks exactly the same.
Coles Notes: If I had an Si, I'd be playing it safe and welding or getting Highrev's brackets.
Winter projects:
| cabin sound dampening | Tein SS/EDFC | red-stitch steering wheel | two-tone seats/doors | LED dash conversion | CAI Install |3-way speaker install | powdercoated valve cover | complete interior CF overlay
Old 06-14-2007, 09:28 PM   #87 (permalink)
caveman74's Avatar
Kevin
I will have to keep an eye out on mine.
caveman74 is offline   Reply With Quote
Old 06-14-2007, 09:48 PM   #88 (permalink)
Andrei
Originally Posted by Storm
Good find. Thanks
Thanks. Then again that same website said that the Civic Si had dual piston calipers up front. I got those front brakes and they look like they have one piston for each caliper.
Old 06-14-2007, 10:23 PM   #89 (permalink)
bluetroll's Avatar
NBP Si
i'd be interested in these.
bluetroll is offline   Reply With Quote
Old 06-14-2007, 11:01 PM   #90 (permalink)
wannapar3's Avatar
Highrev1, I would be interested in a set.
I inspected mine yesterday and so far no problems. No early signs of stress.
No paint cracking or metal out of shape. But why take a chance, adding a little support could be just what is needed.
wannapar3 is offline   Reply With Quote
Old 06-15-2007, 08:58 AM   #91 (permalink)
bluetroll's Avatar
NBP Si
my point exactly.... spend a little for the extra peace of mind!
Old 06-15-2007, 09:13 AM   #92 (permalink)
J-Ro's Avatar
Jason
If anyone has any ideas on this, please let me know too:
Progress rear swaybar rattling
^ It's really starting to piss me off
Winter projects:
Old 06-15-2007, 10:45 AM   #93 (permalink)
Storm's Avatar
So according to this, you had installed the bar incorrectly(without the adapter pieces) before it broke?
Can we add a choice to the poll for the people who have the Progress bar installed, and haven't had any problems? I feel that this will give us objective results?
Old 06-15-2007, 11:01 AM   #94 (permalink)
Well...this would def. explain the tear out you got. It appears they move the bar down with the adapter plates, sitting it in stock position would DEF. add stress to the endlink mounting location, and the weakest part brok first.
Guess this just means don't install the bar without the adapter kit.
Old 06-15-2007, 11:09 AM   #95 (permalink)
iomatic's Avatar
The original shear looks like the force was pulled toward the front, not up and down as would be the normal force driven by the control arms. Does anyone else see this? Or am I off base?
iomatic is offline   Reply With Quote
Old 06-15-2007, 11:11 AM   #96 (permalink)
brdhouse's Avatar
Bill
THis is also another reason why the stock endlinks are good if your concerned about somthing like this, they are generally weaker and will break first.
So just for my own peace of mind... we're talking about the flat brackets that come with the progress RSB, correct (in the middle, not at the endlinks)? I did not use those brackets on my Si coupe, based on some advice in another thread. since there are apparently differences between the Si and non-Si mounting locations, have I installed it correctly on my Si?
brdhouse is offline   Reply With Quote
Old 06-15-2007, 11:13 AM   #97 (permalink)
It does but look at the endlink after the fix, you can see there is pressure in that area, and that is clearly the weakest part that little extra bit of metal on the outer edge.
SI=no bracekts
non si = brackets needed.
Old 06-15-2007, 11:32 AM   #98 (permalink)
J-Ro's Avatar
Jason
Are you sure that's not just my welding skills (or lack thereof)?
I considered the fact that the original mounting location might have had something to do with the break. But I have trouble wrapping my mind around that, considering that the difference in the location between then and now is only about 1/2". And as iomatic said, it is a front tear out.
The fact that the bar was originally incorrectly installed certainly didn't help the situation, but I think the fact that the bar is simply much stiffer than the original bar is the bigger player here.
Winter projects:
Old 06-15-2007, 12:41 PM   #99 (permalink)
iomatic's Avatar
So let's clarify -- Sis are probably fine without reinforcement, yes?
Old 06-15-2007, 12:58 PM   #100 (permalink)
Storm's Avatar
I haven't heard of any si's having problems. I have had zero problems with mine. And also other trims, if they used the adapter pieces. To get accurate results though, we need to know if this was an isolated case resulting from not using the adapters.
No offense to J-Ro, I'm just looking for the facts. I would like to see another choice on the poll. Something like:
I installed my bar properly, and have had no problems.
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/43284-important-info-all-those-aftermarket-sways.html
06 Civic Rear Swaybar Reinforcements This thread Refback 02-22-2008 12:55 PM
06 Civic Rear Swaybar Reinforcements This thread Refback 01-29-2008 09:51 AM
Sway Bar reinforcement brackets. - 8th Generation Honda Civic Forum This thread Refback 01-29-2008 08:22 AM
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 05:25 AM
Rear Sway Bar - ClubSi This thread Refback 12-13-2007 05:12 PM
Rear Sway Bar - ClubSi This thread Refback 12-13-2007 05:10 PM
Rear Sway Bar - ClubSi This thread Refback 12-13-2007 05:08 PM
