| View Poll Results: Has this happened to you? (Only vote if you fall into the following categories) | |||
| Yes, with a Progress rear sway bar |
37 | 9.74% |
| Yes, with another aftermarket rear sway bar |
5 | 1.32% |
| No, but my stock end links broke |
15 | 3.95% |
It won't ever happen to me because this thread really scared me!
323 | 85.00% |
| Voters: 380. You may not vote on this poll | |||
LinkBack (7) | Thread Tools | Display Modes |
#22 (permalink) |
Is there a possibility that your other suspension / wheel mods may have put extra stress on the mount or maybe corrosion from salted roads? I can't find any other instances where this has happened on an 8th gen.
I am super curious as to what caused this failure since I have an EX with the Progress rear sway. Thanx for the info & 'heads up' |
#23 (permalink) | |
Six eyes
![]() Join Date: Apr 2006
Jason
I'm so JDM, my girlfriend is Japanese. 私はあまりにもJDMなので、私の彼女は日本人です。 |
#24 (permalink) |
Hmm if this becomes a common problem I am sure some sort of "Stregthener" could be made so this doesn't happen. Somthing that emulates the same shape of that connecting bracket and bolts onto it From both sides so everyone doesn't need to get it welded.
#26 (permalink) | |
#27 (permalink) |
Andrei
I heard on the other Civic forums that 7th gen Civics with lower tie bars/rear upper strut bar combined with sway bars of 19mm and larger have experienced broken rear subframes and some other suspension/chassis components?
Do you think what happened to J-Ro with the endlinks breaking off the lower control arm is just as likely on the Si? On www.hondaautomotiveparts.com it shows that the Si control arm and the non Si one have different part numbers, however the part number for the plastic cover that goes over a certain part of the rear lower control arm shares the same part number. Besides the parts look completely identical in the diagrams. |
#33 (permalink) |
Is my understanding correct that it wasn't the endlinks that failed but part of the car frame? If that is true anyone want to buy a brand new bar for cheap? I never installed my Progress rear sway bar. It's been my closet for about 5 months. I'm lazy and now I'm way to to ever put it on.Someone reassure me.
#35 (permalink) | |
Six eyes
Jason
You are correct. If it's any consolation, if you have access to a welder, you can reinforce it pretty easily.
#38 (permalink) |
Six eyes
Jason
^ Yeah, thanks Mike. I probably should have clarified. I imagine the LCAs would be the same, but I don't know.
*EDIT* Here are the LCA p/n's: SI: 52370-SVB-A02 020 ARM, R. RR. TRAILING 52371-SVB-A02 021 ARM ASSY., L. RR. TRAILING ![]() EX: 52370-SNA-A04 020 ARM, R. RR. TRAILING 52371-SNA-A04 021 ARM, L. RR. TRAILING ![]() Same images (exact same address), but different part numbers, so no guarantee that the LCAs are the same. ***Sorry about the image size... I don't know why they came out so huge
I'm so JDM, my girlfriend is Japanese. 私はあまりにもJDMなので、私の彼女は日本人です。 Last edited by J-Ro; 06-12-2007 at 01:42 PM. |
#40 (permalink) | |
Six eyes
Jason
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/43284-important-info-all-those-aftermarket-sways.html
| 06 Civic Rear Swaybar Reinforcements | This thread | Refback | 02-22-2008 01:55 PM | |
| 06 Civic Rear Swaybar Reinforcements | This thread | Refback | 01-29-2008 10:51 AM | |
| Sway Bar reinforcement brackets. - 8th Generation Honda Civic Forum | This thread | Refback | 01-29-2008 09:22 AM | |
| I need brakes/Sways - ClubSi | This thread | Refback | 01-11-2008 06:25 AM | |
| Rear Sway Bar - ClubSi | This thread | Refback | 12-13-2007 06:12 PM | |
| Rear Sway Bar - ClubSi | This thread | Refback | 12-13-2007 06:10 PM | |
| Rear Sway Bar - ClubSi | This thread | Refback | 12-13-2007 06:08 PM | |
