View Poll Results: Has this happened to you? (Only vote if you fall into the following categories)
Yes, with a Progress rear sway bar 16 7.48%
Yes, with another aftermarket rear sway bar 1 0.47%
No, but my stock end links broke 12 5.61%
It won't ever happen to me because this thread really scared me! 185 86.45%
Voters: 214. You may not vote on this poll
LinkBack (7) Thread Tools Display Modes
Old 07-11-2008, 07:28 PM   #301 (permalink)
Artem
Originally Posted by J-Ro View Post
With the higher rate on the dampers, your swaybar isn't doing as much work, so if anything, you're safer than me :)
Well thats good to know, but regardless, should I still upgrade the endlinks and reinforce the connecting points?
infiniti_4_life is offline   Reply With Quote
Old 07-11-2008, 07:47 PM   #302 (permalink)
63.7% Bostonian.
J-Ro's Avatar
Jason
I think the connecting points are more of a concern than the endlinks, but if you've already got the endlinks, you might as well throw them on. As long as they don't rattle
Si away for the winter 96 Intrepid in action
Winter projects:
- LED taillights (following in Nomar's footsteps)
- two-tone seats
- misc electrical stuff
- audio overhaul
- random powdercoating
Originally Posted by dentrecords' fridge
I have seen all my hopes and dreams inside your bum.
Old 07-20-2008, 09:43 AM   #303 (permalink)
This is not funikh!!!11
xheartcore_boyx's Avatar
Addy
So,i have a 07 EX with stock suspension, got my 22mm progress sway bar,with the parts above(anything missing?),am i going to be safe if i ask the body shop to use everything supplied ?
in other words,did the OP use the same parts in this pic?
Originally Posted by xheartcore_boyx View Post
..do the 17'' wheels fit well ? will the car get any slower or not as balanced ?!
Fail.
xheartcore_boyx is offline   Reply With Quote
Old 07-20-2008, 09:43 AM   #304 (permalink)
Addy
deleted.
Fail.
Old 07-20-2008, 04:07 PM   #305 (permalink)
63.7% Bostonian.
J-Ro's Avatar
Jason
^ Originally, I was not shipped those parts, and I had no idea they were supposed to be added into the case, but I did get it sorted out.
Winter projects:
- two-tone seats
- audio overhaul
Old 07-20-2008, 04:19 PM   #306 (permalink)
Addy
So,did you use them later in the install ? and still had the problem after wards ?
Fail.
Old 07-20-2008, 04:31 PM   #307 (permalink)
63.7% Bostonian.
J-Ro's Avatar
Jason
Yeah basically the bar was a royal bitch to install because I didn't know about the adapter kit, then about a month later I finally got the adapter kit, installed it. I think the LCA bracket broke sometime during that winter, which I repaired in the spring. Then I installed the Corsport endlinks which rattled for about another month, then got replacements from Corsport which still rattled, so I said screw it and went back to stock. Everything was right as rain after that. Until I sold the car
Winter projects:
- two-tone seats
- audio overhaul
Old 07-20-2008, 04:41 PM   #308 (permalink)
Addy
Damn you been though alot , just for that bar
So,hmm maybe you got bracket broken because the bar wasnt installed using the adapter at first ??
i have the bar and the kit and all...looked at this thread later that scared me out to the limit !
noone would buy the bar here....but if i install and something go wrong and weld it ... the car's price would go so low when selling the car..when it is getting checked and they see the welded part...
what would you do if you were me ??
Ex,stock suspension - will never upgrade or buy anything else for the car since im planning on getting a GTI next year.. -
Fail.
Old 07-20-2008, 05:14 PM   #309 (permalink)
63.7% Bostonian.
J-Ro's Avatar
Jason
Nah, someone else made the same suggestion... I ended up installing the bar basically the same way, I just had to do some customization along the way. Along with some newly-invented swear words.
If you don't want to weld, just use High-rev's strengthening brackets. They're completely reversible.
Winter projects:
- two-tone seats
- audio overhaul
Old 07-20-2008, 05:16 PM   #310 (permalink)
Addy
Ok,so i wonder if the bar would make a difference with the stock EX suspension?
is installing it worth the risk ?
Fail.
Old 07-20-2008, 05:19 PM   #311 (permalink)
63.7% Bostonian.
J-Ro's Avatar
Jason
Absolutely! For the price, it's a great mod.
Winter projects:
- two-tone seats
- audio overhaul
Old 07-20-2008, 05:33 PM   #312 (permalink)
Addy
70$ for a piece of metal from highrev ???? O___O
Fail.
Old 07-20-2008, 07:03 PM   #313 (permalink)
63.7% Bostonian.
J-Ro's Avatar
Jason
Meh, can't help ya there
Winter projects:
- two-tone seats
- audio overhaul
Old 07-20-2008, 07:13 PM   #314 (permalink)
Addy
I bet you cant lol
Thanks for all the help man , they shall bring the repping system back ASAP!
Fail.
Old 07-21-2008, 10:31 PM   #315 (permalink)
63.7% Bostonian.
J-Ro's Avatar
Jason
^ No worries!
Winter projects:
- two-tone seats
- audio overhaul
Old 10-02-2008, 01:40 PM   #316 (permalink)
sucks!
I was just putting some more grease on my sway bar cause i dont think i put enough on when i installed it and it squeaked like a bia. well i jacked up the car and started undoing the bolts and i looked up at the passanger side end link and the bracket had cracked like this post said it might i just say for all of you who put a new sway bar on go ahead and reinforce the brackets however you can i wish i would of when i did mine now i have to go get it all welded up and fixed...
sk8freestyle is offline   Reply With Quote
Old 10-21-2008, 05:33 PM   #317 (permalink)
WHOcaREs05050
Whocares05050's Avatar
Good info. I just got my sway, and endlinks will be here this week. Ill be reenforcing mine asap.
Whocares05050 is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/43284-important-info-all-those-aftermarket-sways.html
06 Civic Rear Swaybar Reinforcements This thread Refback 02-22-2008 01:55 PM
06 Civic Rear Swaybar Reinforcements This thread Refback 01-29-2008 10:51 AM
Sway Bar reinforcement brackets. - 8th Generation Honda Civic Forum This thread Refback 01-29-2008 09:22 AM
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 06:25 AM
Rear Sway Bar - ClubSi This thread Refback 12-13-2007 06:12 PM
Rear Sway Bar - ClubSi This thread Refback 12-13-2007 06:10 PM
Rear Sway Bar - ClubSi This thread Refback 12-13-2007 06:08 PM
