Important info for all those with aftermarket sways! - Page 15 - 8th Generation Honda Civic Forum
View Poll Results: Has this happened to you? (Only vote if you fall into the following categories)
Yes, with a Progress rear sway bar 37 9.74%
Yes, with another aftermarket rear sway bar 5 1.32%
No, but my stock end links broke 15 3.95%
It won't ever happen to me because this thread really scared me! 323 85.00%
Voters: 380. You may not vote on this poll
LinkBack (7) Thread Tools Display Modes
Old 05-09-2008, 11:55 PM   #281 (permalink)
Six eyes
J-Ro's Avatar
Jason
Crap, that sucks. What part broke? The bar bracket to the mount? Or the mount to the frame? Because the mount to the frame would be far worse
I'm so JDM, my girlfriend is Japanese.
私はあまりにもJDMなので、私の彼女は日本人です。
Old 05-09-2008, 11:59 PM   #282 (permalink)
mO 64 StAnG 06's Avatar
Not sure by your description, but it was the part there the end link connects to the frame. The same area where yours broke in the pic.
Is it imperative to get this fixed ASAP or is it fine for a while? I've got no money to get it fixed or a mig to do the fix myself.
mO 64 StAnG 06 is offline   Reply With Quote
Old 05-10-2008, 09:15 PM   #283 (permalink)
Six eyes
J-Ro's Avatar
Jason
Oh okay, sorry I was thinking where the bar mounts up to the underbody of the car.
Your car isn't going to spontaneously combust or anything, but it definitely hurts your cornering ability, so you'll want to get it addressed when you can. Unfortunately since it already broke, Highrev's reinforcing plate isn't going to help you; you'll have to get it welded... so while you're at it, you might as well weld in a few additional washers.
Old 05-10-2008, 10:12 PM   #284 (permalink)
Sure they will...If just the exterior hole ripped out he can bolt them up and utalze those as the final hole
Old 05-11-2008, 11:12 PM   #285 (permalink)
Six eyes
J-Ro's Avatar
Jason
Oh yeah. Brainfart!
Old 05-12-2008, 03:43 PM   #286 (permalink)
where can i get Highrev's reinforcing plate?
cto424 is offline   Reply With Quote
Old 05-12-2008, 03:48 PM   #287 (permalink)
Josh at Excelerate...
Old 05-12-2008, 04:17 PM   #288 (permalink)
^^thank you
Old 05-12-2008, 04:19 PM   #289 (permalink)
illusionstwice's Avatar
The original --> "J" <--
uh i hate seeing this thread. I think I am going to hold off on the install of my progress rear swaY.
All paid jobs absorb and degrade the mind.
*Aristotle*
illusionstwice is offline   Reply With Quote
Old 06-27-2008, 11:57 PM   #290 (permalink)
C2Kmaster's Avatar
Dain
Hi guys I just read through some of the posts on this little thread and can honestly say thank god I found it, cause I would have been clueless about the tear out problem with the progress rear sway bar. I was just looking into getting the bar for my FA5, which is totally stock, and I am definitely appreciative to all for helping me make the more educated decision about getting the sway bar. A little question I have is, I would like to get the reinforcements for the endlinks mounting points. I saw that stated just three posts up I can get them from Josh at Excelerate but I am not sure of how to get ahold of him or let him know that I would like to purchase a set. I am wondering how the car will handle after I put the bar on with the reinforcements with the stock suspension. I had a del sol that I installed an oem rear bar from a vtec del sol, mine was an si w/o a rear bar. I noticed that when turning, the rear felt like it wanted to basically rotate. Also the back seemed to be more planted to the road when pushed, around a tight reference corner. I'm just having a difficult time finding parts for the car that I want to modify the car with because of so many debates for just about every part for our cars. Having more positive feedback for a part would give a much easier decision, for god sakes I was just going to do a coilover setup and a sway bar setup like most would do for a suspension mod, but now I am unsure if I want to go that route cause of so much speculation as to weather or not it even makes as big of a dif as it did on all the old civic chassis. Sorry for so much in a little space but I'm just overwhelmed with what to do first and if I should even do anything at all. All help is much appreciated.
C2Kmaster is offline   Reply With Quote
Old 06-28-2008, 10:20 AM   #291 (permalink)
wallytiburon's Avatar
Wally
A lot of older cars didn't even come with rear sway bars. It's not imperative to have one but as it's been stated it does affect handling and stability.
That said, on the tiburon forums, it's a known issue that upgraded sway bars have a tendency to break the tabs on the struts (endlinks get mounted to the struts on the tiburon). A member on the forums just built new, stronger, thicker tabs that we weld back onto the stock location.
Personally I had new tabs welded on and upgraded my endlinks to fully adjustable KJBs so I couldn't complain any more. It's good to know that they break on civics too. I'll probably contact KJB for beefy endlinks and that tib member for new tabs that fit the civic.
-Wally
wallytiburon is offline   Reply With Quote
Old 06-30-2008, 10:39 PM   #292 (permalink)
07 Figi Blue Si's Avatar
Lance
Originally Posted by DumbasSi View Post
OUCH! Just be glad it wasnt the subframe where the swaybar bolts to the underside of the car. THAT would be ugly. I guess the LCAs are the weak point.
On the older 96-00 Civics, many people upgraded to a Type-R or big aftermarket bar. They were usually too stiff and tore the subframe apart. Now, companies like ASR make reinforcement kits to strengthen the subframe. Maybe the 06+ Civics need something similar to handle the stress of the stiffer bars.
See the Redshift RSB Support Brackets from Excelerate.
06 Civic Rear Swaybar Reinforcements
07 Figi Blue Si is offline   Reply With Quote
Old 07-08-2008, 07:44 AM   #293 (permalink)
Has anyone had a tear out with the Mugen bar over at King Motorsports? It's a little thinner than the progress bar.
vaek is offline   Reply With Quote
Old 07-08-2008, 09:10 AM   #294 (permalink)
Member # 4524
GlxyGry06Si's Avatar
i have had my rear sway bar on for about a year and did not upgrade anything and i have had no problems. i do take corners fast occasionally but for the most part i drive calmly. i do not autocross but i have a feeling thats why a lot of peoples brackets were breaking.
Originally Posted by TheIncident88 View Post
Sometimes I actually wonder if you are serious or just ******* with me. If it's the latter, then well played sir. If not, then I shall return my palm to it's previous position upon my face.
Old 07-08-2008, 05:26 PM   #295 (permalink)
This was a common occurance with 3rd gen non-type-r Integras that upgraded with a 98+ JDM Type-R rear sway bar. All you need is the reinforcement kit and everything will be fine, even with autocross and high speed lapping. There's no reason all you guys have to get scared of installing the Progress rear sway bar with the reinforcement kit. I highly believe this upgrade is necessary to help eliminate understeer that our FWD cars suffer from.
RX_AGENT is offline   Reply With Quote
Old 07-08-2008, 09:20 PM   #296 (permalink)
coo92705's Avatar
Allen Lim
i rallycross! hahaha my sway bar is noisy as hell
coo92705 is offline   Reply With Quote
Old 07-10-2008, 10:16 PM   #297 (permalink)
Lance
Which end links do you have?
Old 07-10-2008, 11:01 PM   #298 (permalink)
Talking
i always use suspension tecniques and never have any problems. and i thrash my car pretty hard sometimes.
bluebare915 is offline   Reply With Quote
Old 07-10-2008, 11:57 PM   #299 (permalink)
Artem
How much for the sway bar reinforcement brakets? I can't seem to find a price. Also, I have Tein Flex Coils with stock endlinks and a progress sway bar. Since the Spring rate is so high, from what I've read, should I upgrade the endlinks? I have Corsport V2 endlinks laying in my garage. I haven't installed them cause I heard they rattle. Any thoughts on that as well?
infiniti_4_life is offline   Reply With Quote
Old 07-11-2008, 06:14 PM   #300 (permalink)
Six eyes
J-Ro's Avatar
Jason
With the higher rate on the dampers, your swaybar isn't doing as much work, so if anything, you're safer than me
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/43284-important-info-all-those-aftermarket-sways.html
06 Civic Rear Swaybar Reinforcements This thread Refback 02-22-2008 01:55 PM
06 Civic Rear Swaybar Reinforcements This thread Refback 01-29-2008 10:51 AM
Sway Bar reinforcement brackets. - 8th Generation Honda Civic Forum This thread Refback 01-29-2008 09:22 AM
I need brakes/Sways - ClubSi This thread Refback 01-11-2008 06:25 AM
Rear Sway Bar - ClubSi This thread Refback 12-13-2007 06:12 PM
Rear Sway Bar - ClubSi This thread Refback 12-13-2007 06:10 PM
Rear Sway Bar - ClubSi This thread Refback 12-13-2007 06:08 PM
