| View Poll Results: Has this happened to you? (Only vote if you fall into the following categories) | |||
| Yes, with a Progress rear sway bar |
37 | 9.74% |
| Yes, with another aftermarket rear sway bar |
5 | 1.32% |
| No, but my stock end links broke |
15 | 3.95% |
It won't ever happen to me because this thread really scared me!
323 | 85.00% |
| Voters: 380. You may not vote on this poll | |||
LinkBack (7) | Thread Tools | Display Modes |
#181 (permalink) | |
Six eyes
![]() Join Date: Apr 2006
Jason
![]() I'd say the mounting plate is probably 14GA steel (0.0747"). I'd be interested in seeing an FEA stress distribution model out of sheer curiosity. It would be interesting to compare stock vs. regular washers vs. Highrev's washers vs. welded washers. <-- IMO that is the order of strength, from worst to best. *EDIT* Btw, MAD rep for you if you can do that. If you need any measurements or other help with the model, let me know. I've used ANSYS before, but no experience with anything else unfortunately.
I'm so JDM, my girlfriend is Japanese. 私はあまりにもJDMなので、私の彼女は日本人です。 |
#182 (permalink) | |
Maiku (m-ai-k)
did you seriously just ask that... u_u* |
#183 (permalink) | |
It won't make a difference to the mounting of the Endlink, all it will do is strengthen the bracekt more. |
#184 (permalink) |
i have no doubt that your product will outperform. unless the welds start breaking completely off. nothing against you but if the washers hold up id use them. if they dont, id be buying your product. you come from a track only background so i see the thought process you go through. good job and keep it up.
#189 (permalink) | |
Bill
I'll get crackin' on it today...if I need extra measurements I'll let you know. If we can...we might as well get this right on the first shot right?
#191 (permalink) | |
Six eyes
Jason
![]() The main issue I see is accurately modeling the forces involved, and how far to take the model, i.e. do you include just the bracket in the model, or do you include other things, such as the endlink, LCA, swaybar, etc. I would think that you would want to include the lower bolt of the endlink, since that is causing a force and a torque. Consequently, I would think that you would want to include the LCA, or at least constrain the bracket where it would connect to the LCA. The tough part with this is that there are a lot of irregular shapes and oblique forces that need to be taken into account. My last concern is how do we actually come up with a number for the force on the bracket? [/thinking out loud]
#192 (permalink) | |
Bill
Intially I see just testing the bracket for a baseline of what the metal *should* endure with the position of all of the bolt holes. Next would be to do it all over again in the assembly (i.e. the LCA and other parts to really simulate what is going on here). I've done a good amount of FEA analysis before so I should be ok to give us a decent answer on this; however, to ease the fears that my skills might come short...I have in house 2 FEA gurus that do nothing all day long but test the forces/stress/strain etc... on sub-oceanic ROVs all day long. I'm pretty sure we can get a *good* number.
#193 (permalink) | |
Brian
http://www.kormanfastbmw.com/tantiswa.htm Depends on how much thicker the replacement is over OEM. Rule of thumb I've heard is 80% is around the most you should go. If Eibach brings out a 20mm bar, then you're pretty good. |
#194 (permalink) | |
Six eyes
Jason
#198 (permalink) |
Semi-Si Sedan Hater
http://www.vtec.net/articles/view-ar...&page_number=4
Digging up an old thread, but I was reading TOV's Project Si articles and their rear sway did snap off while tracking at Willow Springs too. Supposed to be a vid, but can't find it. |
#200 (permalink) |
Six eyes
Jason
3-1/2 months on my welded-washer setup and it's still holding strong. The crappy part is most people don't have access to a welder.
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/43284-important-info-all-those-aftermarket-sways.html
| 06 Civic Rear Swaybar Reinforcements | This thread | Refback | 02-22-2008 01:55 PM | |
| 06 Civic Rear Swaybar Reinforcements | This thread | Refback | 01-29-2008 10:51 AM | |
| Sway Bar reinforcement brackets. - 8th Generation Honda Civic Forum | This thread | Refback | 01-29-2008 09:22 AM | |
| I need brakes/Sways - ClubSi | This thread | Refback | 01-11-2008 06:25 AM | |
| Rear Sway Bar - ClubSi | This thread | Refback | 12-13-2007 06:12 PM | |
| Rear Sway Bar - ClubSi | This thread | Refback | 12-13-2007 06:10 PM | |
| Rear Sway Bar - ClubSi | This thread | Refback | 12-13-2007 06:08 PM | |
