#102 (permalink) | |
Paul
I think it would also be advantageous, in terms of braking, to run a stiffer front suspension to help resist to much weight going to the front tires and overwhelming the tires and losing traction. Also, a stiffer front suspension would keep some weight over the rear tires which will increase the over all grip of all 4 tires which will decrease stoping distances. |
#103 (permalink) | |
...hhhmmm..less compression equals not enough compliance for cornering traction? discuss amongst yourselves! :smile: |
#104 (permalink) | |
Paul
#106 (permalink) | |
#107 (permalink) | |
in a strange/somewhat artificial/can't-believe-i'm-using-this-as-evidence kinda of way, i can attest to that statement because of tuning i've done......on forza motorsport. i'm a huge dork.
#108 (permalink) | |
#110 (permalink) | |
Semi-Si Sedan Hater
One example: W/ FWD most people's goals are to get rid of dastardly understeer. Having softing front sways means the car rotates better in corners, and potentially gives more traction up front. Downside is that steering responsiveness goes down, and you have to turn in a little quicker. For some that trade-off is worth it, for others it isn't. You could also have a toe out to the rear--but the downside to that is it can impact straightline stability, making it more dangerous for a person not familiar with the limits of the car. There's no real one-size-fits-all because in part the "ideal" setting is what the driver is most comfortable w/ in pushing to the limit. Slight understeer is supposedly ideal (was it Carroll Smith who said that?), but some prefer neutral/slight oversteer, especially out of the exit of a turn. Last edited by aki; 08-20-2007 at 03:32 AM. |
#111 (permalink) | |
- overall, i think about it like this: a car that tends to oversteer more is a car that has an allowable range of rotation. now the driver then needs to determine how much of that range they feel is necessary for turn by turn. while a car that tends to understeer has a decidedly smaller allowable range of rotation. therefore i see this as a limitation to the necessities of rotation determined by the driver. |
#112 (permalink) |
Paul
FWD RWD AWD every car needs some rotation in order to handle at its best. Tires make the most amount of grip with a little bit of slip. With undsteer, only the front tire slip. With oversteer, the rear tires slip. With proper rotation (small amout of oversteer) all four wheels slip around an axis. Four wheels at their maximum grip level will ALWAYS grip more than 2, just ask anybody on a bike. Rotation is needed for a good handling car. Even the NASCAR boys know that "a loose car is a fast car," (to a point of course).
#118 (permalink) |
I was reading this site today and it said
"There is actually a formula to compute the fastest path and speed through any corner. It's 15gR = (mph)2, where R is the radius of the turn, and g is a measure of the grip of your tires." I thought that was pretty cool....You could in theory mapoput exactly max speed on a road course through each turn...and then try to accomplish that or even beat it But see then again I don't fully agree with this at all... |
#119 (permalink) |
Paul
I don't know if it the right equation, (nor would i, i'm not an engineeer) but i do know some engineers and this can be calculated. Of course this equation does not include wind speed/direction, temperature, type of car (and every part/dimension on said car). It is a simple equation for first year physics students. (thats still more than me, i've only had on semester some 8 years ago)
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/43130-suspension-theory-chat-thread.html
| Suspension and Brakes - 8th Generation Honda Civic Forum | This thread | Refback | 03-02-2008 04:32 AM | |
| NC Chat/Meet thread | ley | South | 12960 | 10-19-2008 04:08 AM |
| Austin Chat thread | ethlar | Texas | 2061 | 10-19-2008 03:13 AM |
| The South's BS and Chat Thread | ethlar | South | 47 | 09-27-2008 01:01 PM |
| SoCal Chat Thread | ayenoc | California South | 4811 | 06-18-2008 10:31 PM |
| What is a chat thread without CHAT?! | LikWidv1 | 8thcivic.com Site Questions/ Problems | 65 | 10-25-2007 05:11 PM |
