#381 (permalink) | |
![]() Join Date: Jun 2006
captain obvious
how do u feel these are compared to the pro-c's? |
#382 (permalink) | |
The Dynos are posted on his site under "Information/shock dyno .... for EH/EK/Teg / WRX ... I have direct linked to it here http://picperformance.com/dyno.pdf I was not aware that he has a FG/FD application ...the web-site does not talk about it. Not having used or seen his fd/fg SETUP I cannot comment on it ... BUT if it is up to the same standards as his EG/TEG coil-overs we may have another good option for the more track oriented enthusiast Moose Last edited by Moose; 07-25-2008 at 10:16 PM. |
#383 (permalink) | |
captain obvious
#387 (permalink) |
... air shocks... like from back in the 70's? the ones with the tube that run to the back bumper to boost them up.... hmmm idk
i noticed all the 8thgen civics coming back from the beach were dumpy in the rear... theyré all soft unless you go aftermarket... and when you say springrate do you mean preload?? or am i thinking of occcupied sag like on race bikes... |
#388 (permalink) |
Louder than 4 F404-GE-400
Spring rate and preload are to very different things.
Spring rate - The amount of force required to compress the spring. Ex 500 lbs/in - It takes 500 lbs of force to move the spring 1 inch. Pre-load - Pre compressing the spring when its on the car in order to change droop travel.
You know what the sun's all about when the light go out. |
#389 (permalink) | |
which in turn changes ride height... correct??... |
#391 (permalink) | |
8thcivic Sponsor
![]() "Think about it for a moment. Springs as we all know are rated in LB/IN (KG/cm) meaning a given spring will compress X"'s per LBS applied to that spring. simple right? so.... Have you altered how much weight is being applied to that spring by altering the height of it? if not then how can the spring compress any more or less at any ride height along the collars adjustment range? Remember, the upper hat is attached to the dampers pistion (which is a moving part), so when you raise or lower the spring perch (not the bottom perch) you end up changing the dampers stroke range rather then compressing the spring(unless you completly top out the damper). IN reality, the only thing you've done by adjusting the lower collar is adjust the shocks stroke range, something that can also be done by shortening the damper." A ZZ quote ![]() Now there is a way to arrange the weight of the car around its suspension to make it equal to all corners and thats corner weighting the car. But in that instance the weight of the car is shifted onto the spring to compress it. Understanding Corner Weights A HELPER SPRING Now a helper spring is somthing complety different, and the N+ don't have them so this is just for my own good feeling to try to educate the forum. All that is a flat spring that takes up room so the springs don't have slop in them when they are not under load. These helpers compress completly flat basically they are there to keep thing nice and tight, keep noises down too, as you can read from the article TUV requires them. Helper Springs
#392 (permalink) |
.... hmmm i guess i deal with motocross suspension way too much lmao...
i can never seem to find a perfect balance of the suspension on the bike, there are too many variables spring rate various rates of valving dampening compression rebound oil wheight preload loaded sag ...ect ect... so to simplify the fg is there a package coilover set that seems to be all-around good with decent ride comfort...? i thought skank2 2 way adj. coilovers or tein 2 way adj. coilovers or should i just go height adj only? is it worth the money to be able to adj. dampening? |
#394 (permalink) |
I don't have any problems rubbing on my daily drive with 225/40-18's mounted on 18x7" wheels with a +45mm offset at stock height on my Si. I bought a used set of 17x7.5" Kosei K1 wheels with a +45mm offset and mounted 225/45-17 Azenis for auto-x. The Azenis are not the tire of choice anymore and I am considering mounting some 235 or even 245 series Direzzas on the Kosei's. Will a 5mm or 10mm wheel spacer be enough to avoid any rubbing? People seem to be having success with 235/40-17's and would keep me in VTEC better than the 235/45-17's. 245's provide a larger cross section, but at the limit of camber, weight of the tire, and the weight of the wheel spacer if I need one.
I am at stock height right now and after reading all 20 pages of this thread I can say that I would get Koni yellows and either the Eibach ProKit or Progressive springs. The RedShift Motorsports coilovers aren't really necessary for my purposes. How will this affect rubbing with the Direzzas? The car is being prepped for STX, so I might have 245s only in the front. Last edited by cincy94max; 09-12-2008 at 09:19 PM. |
#395 (permalink) | |
#396 (permalink) |
Please help with this recipe. HFP suspension on my LX sedan already installed. I'd like to put in 17x8 +35 enkei RPF1 with 225 45 17 tires. From what I've read, most people do a 215 45 for an 8" wheel, or a 225 40. I think I'd rather have the 45 sidewall, but I'm pretty sure I'll rub with a 45 sidewall. What if I put 1.5 degrees camber in front and adjust the back to about 1 degree? Or, someone just tell me what tire size to run with that drop, wheel, and camber. LOL All I plan on doing is suspension and wheels, so I really want to get this right. Any help would be much appreciated.
#397 (permalink) | |
#398 (permalink) | |
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/43130-suspension-theory-chat-thread.html
| Suspension and Brakes - 8th Generation Honda Civic Forum | This thread | Refback | 03-02-2008 03:32 AM | |
| NC Chat/Meet thread | ley | South | 12679 | 10-06-2008 11:50 PM |
| Austin Chat thread | ethlar | Texas | 1835 | 10-06-2008 08:31 PM |
| The South's BS and Chat Thread | ethlar | South | 47 | 09-27-2008 12:01 PM |
| SoCal Chat Thread | ayenoc | California South | 4811 | 06-18-2008 09:31 PM |
| What is a chat thread without CHAT?! | LikWidv1 | 8thcivic.com Site Questions/ Problems | 65 | 10-25-2007 04:11 PM |
