Old 05-27-2008, 09:50 PM   #361 (permalink)
Hot Stockness
flamewing's Avatar
Scott
once I learned to drive at the cars limits I will be looking to improve my stock setup. I was curious if lowering a car really made a big difference or not
Flamewing's got the Stockness so hawt it'll make you booty go SMACK
flamewing is offline   Reply With Quote
Old 05-27-2008, 09:52 PM   #362 (permalink)
Do 1 season of AUTOX then start modding....A good Autox driver almost always makes a good track driver....A good track driver almost never makes a good Autox driver
Old 05-27-2008, 10:00 PM   #363 (permalink)
Hot Stockness
flamewing's Avatar
Scott
cool good to know. I will need better tires if I am looking to Auto cross
Old 05-27-2008, 10:27 PM   #364 (permalink)
Hot Stockness
flamewing's Avatar
Scott
so in basic autox I will gain the needed driving skills? I can do basic driving but I feel like my cornering and braking skills aren't what they need to be.
Old 05-27-2008, 10:33 PM   #365 (permalink)
Louder than 4 F404-GE-400
Paul
Yes it will
Old 05-27-2008, 10:37 PM   #366 (permalink)
Hot Stockness
flamewing's Avatar
Scott
cool I was dreading the idea of spending a few grand on driving lessons. I am still willing to do it but if I can gain the skill else where I might look into said options
Old 05-27-2008, 11:02 PM   #367 (permalink)
Paul
No place cheaper than Auto x.
Old 05-27-2008, 11:08 PM   #368 (permalink)
Hot Stockness
flamewing's Avatar
Scott
cool that works
Old 06-20-2008, 07:54 AM   #369 (permalink)
Hi friends. This question doesn't necessarily relate to suspension tuning directly, but it does relate to the handling of the car. I'm thinking about buying some lightweight 17x8 wheels and probably a 225 tire to go with that.
The wheel comes in a variety of offsets and I was wondering what the pros and cons are of going with a 38 offset in the front and a 42 offset in the back?
I'm assuming that the lower offset in the front would affect the geometry in a negative way by itself, but the overall differences in offset front and back would cause the car to move away from understeer.
The difference in offset is minimal so the effects may also be negligible. I would prefer to just keep the offsets and widths the same for all four corners and just buy a thicker rear sway, but I'm a bit hesitant to do any welding/reinforcement of the endlink brackets, plus I might as well exercise the offset options.
chunky is offline   Reply With Quote
Old 06-20-2008, 04:12 PM   #370 (permalink)
Paul
Go with a 235 tire on an 8" wheel, it will fit.
The lower the number is for the offset, the further out the wheels will be. This increases track width which will increase grip but will wear your wheel bearings faster.
Having less offset in the front than the rear will lessen understeer but you will lose the ability to rotate your tires. What you could do is get 42 all the way around and then by 5mm spacers for the front. This way, you can have your offset difference and still be able to rotate your tires. Do you plan on autox or racing?
Old 06-21-2008, 08:14 PM   #371 (permalink)
I've just realized that I've been hitting the "Go Advance" button instead of the "Post Quick Reply" button. Car will be tracked at a small track locally. I don't think the speeds are any higher than say a autox event.
I've researched the tire sizes for 235 tires and it seems that the fitments have either a significantly smaller or larger circumference. The car will be daily driven so I'm not sure if I should go with the smaller circumference tires for the performance benefits.
Comments, suggestions?
Old 06-21-2008, 08:48 PM   #372 (permalink)
Paul
A 235/40/17 tire is smaller than stock. This make make your final final drive ratio short and help with acceleration. I run that size wheel/tire all day every day. The smaller diameter combined with the lower weight, really helped the car out in acceleration.
You might hit 65 on an auto x course in our cars.
Old 07-13-2008, 09:59 PM   #373 (permalink)
My tech was cool enough to give me the before and after alignment specs for my Si HFP suspension. Might make a good baseline analysis, so if anyone is interested let me know and I'll post them up.
vaek is offline   Reply With Quote
Old 07-24-2008, 08:35 AM   #374 (permalink)
kai boi
how do i get rid of a coiling sound? i just dropped my car and when ever i turn the wheel it the spring make noise. so how can i fix that?
fg2jap is offline   Reply With Quote
Old 07-25-2008, 02:59 AM   #375 (permalink)
mbringle's Avatar
Michael Bringle
My Tein Flex seem to be making a little creaking noise I can hear when turning at slow speeds or going over speed bumps. The Honda guys said it was the springs (front) but everything was tight. This weekend I will take the wheel off and double check and try to find what is causing it.
-Mike
07 SSIP
http://www.CygnusX1.net/Civic
mbringle is online now   Reply With Quote
Old 07-25-2008, 03:06 AM   #376 (permalink)
mbringle's Avatar
Michael Bringle
Im looking at 17x8 with 225/45/17 too. But I will probably get a 45 offset, the RPF1, which are 15.2lb. I am dropped 1 inch so I am worried about rubbing. What are you looking at that had the 42 and 38 offset?
-Mike
07 SSIP
Old 07-25-2008, 03:25 AM   #377 (permalink)
Paul
Get a 235/40/17 on that 17x8. I have that same size with that same offset dropped even more with no rubbing. The tires are the most important part of the suspension. The more rubber, the better the suspension.
Old 07-25-2008, 03:44 AM   #378 (permalink)
eugenekim.net's Avatar
captain obvious
pic performance fg2 coilovers... thoughts on them?
Old 07-25-2008, 06:13 PM   #379 (permalink)
Paul
pic performance? is that the brand?
Old 07-25-2008, 06:27 PM   #380 (permalink)
Moose's Avatar
YUP - pretty good for an off-shorre company ... the designer actually took the time to design / build a decent setup with good performance ... they offer various off-the shelf spring rates that are aggressive and track oriented ...
NOT for FG's though
picperformance.com Redirect
FYI - He participated in the Shock Dyno free for all on HT
Moose
Moose is online now   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/43130-suspension-theory-chat-thread.html
Suspension and Brakes - 8th Generation Honda Civic Forum This thread Refback 03-02-2008 04:32 AM
NC Chat/Meet thread ley South 12960 10-19-2008 04:08 AM
Austin Chat thread ethlar Texas 2061 10-19-2008 03:13 AM
The South's BS and Chat Thread ethlar South 47 09-27-2008 01:01 PM
SoCal Chat Thread ayenoc California South 4811 06-18-2008 10:31 PM
What is a chat thread without CHAT?! LikWidv1 8thcivic.com Site Questions/ Problems 65 10-25-2007 05:11 PM
