#201 (permalink) | |
as always, i recommend the forum stickies because they themselves are a wealth of information as well. happy learning! |
#203 (permalink) | |
#204 (permalink) | |
Louder than 4 F404-GE-400
No problem. I to do it every chance i get for everyone with in my scope of knowledge. If you want a ridiculous set up, contact Highrev1 of RedShift Motorsports and ask about the custom set ups. I have had Tein SS and Tein Flex and am now getting the Double Adjustable Custom Koni Coilovers from RSM. I can't wait. They are going to be the best suspension ever (well for me anyways). |
#206 (permalink) |
Don't all cars actually have two roll centers? One for each end of the car?
My guess would be that since each car has two roll centers, lowering each one independently of the other would be fine as long as the amount of drop is appropriate for the type of suspension (i.e.: double wishbone, live axel, etc.). I think that the biggest concern in lowering the car would be to make sure that you don't upset the balance between the two. You wouldn't want the rear of the car fighting with the front of the car. Just my overly simple guess. I'm hear to learn, but it's fun to take a stab in the dark. |
#207 (permalink) |
8thcivic Sponsor
"The geometric roll center of the vehicle can be found by following basic geometrical procedures when the vehicle is static. However, when the vehicle rolls the roll centers migrate. It is this movement of roll centers that vehicle dynamicists seek to control and in most cases limit. The rapid movement of roll centers when the system experiences small displacements can lead to stability problems with the vehicle. The roll center height has been shown to affect behaviour at the inititation of turns such as nimbleness and initial roll control."
Basically if you lower your car too much and the front control arms get angled up you are killing your roll centers...By doing this you are severly hurting transitional turns. Don't get me wrong lower can be good if it is done properly but too low and you have to correct the roll center back up otherwise the car won't handle well in transitions. 2 basic solutions..First Just don't go TOO low. This is not just becuase of the roll centers but for numerous reasons..I would Gregstimate it to about 1.5" But only real testing will give a hard proven number....The second solution is what alot of the RSX guys did and get longer ball joints...You can read more here http://forums.clubrsx.com/showthread.php?t=373563
BUY MY CIVIC |
#208 (permalink) | |
Jesus Christ. There is so much wrong with this I don't know where to begin. 1. Centrifugal force doesn't exist 2. Narrowing the contact patch of your tires doesn't make you faster (lol) 3. "Reducing resistance" between your tires and the road CERTAINLY doesn't make you faster (LOL!) Next time before you try to sound smart, 1. make sure you are smart, 2. make sure your logic is logical. The signal to noise ratio here is disgusting. |
#209 (permalink) |
8thcivic Sponsor
Easy there killer......
Lucas and TOxin I want you both to be nice now....Don't want this thread closed!!!Where was that posted??
BUY MY CIVIC |
#210 (permalink) |
It was back on pg. 15; I shouldn't have bumped it up. I was just reading through this thread trying to find the hidden nuggets and that one made my head explode.
I guess he was just trying to foster discussion, so I apologize. I just hate hate hate when folks spread ignorant misinformation in w/ the good info that posters like you and belch are posting, because you know a lot of the n00bs don't know what noise to filter. |
#211 (permalink) |
8thcivic Sponsor
Hey I post up ALOT I mean ALOT of BULLSHIT!!!
So once in a while even the initated are allowed to mess up Toxin hope to see you around here more....Lucas ![]()
BUY MY CIVIC |
#212 (permalink) | |||||
#214 (permalink) |
8thcivic Sponsor
GOSH darnit both of you this is a suspension theory chat thread NOT about drag racing I hate DRAG!!!!!!
TOXIN I see you replying be nice you are the NEWB!! THen we can move on guys...
BUY MY CIVIC |
#215 (permalink) |
8thcivic Sponsor
So who wants to discuss the Wheel rates on our cars???
BUY MY CIVIC |
#216 (permalink) | ||||
HighRev: look at my reg date homie. noobness = knowledge, not f'n post count, c'mon man, that's weaksauce. |
#217 (permalink) |
8thcivic Sponsor
Ok fine now DONE!!!!!
Wheel RATES who wants to BEGIN???? Yodum's Want to begine I see you there AKI I know you know your SHiat you could start the discussion!!! SOMEOne!!! :)Well I am leaving work now so EVERYONE BEHAVE IN MY THREAD....Especiallly YOU YODUMS!!!!
BUY MY CIVIC |
#218 (permalink) | |
Resident Si Sedan Hater
2) Well at least for the front tires it does. Dragsters use skinny tires up front. 3) This is true. You want to maximize friction. Hence lower PSIs used to have more contact patch. |
#219 (permalink) | |
but indeed...enough about traveling in a straight line - boring!! ![]() |
#220 (permalink) |
8thcivic Sponsor
Lets dicuss our wheel rates....
![]() "Figure 1 shows the relevant parameters involved in calculating the wheel rate based on knowledge of the spring rate. Wheel rates are useful to know as they make it possible to compare rates between chassis' with differing suspension layouts. Wheel rate is also nice in that it gives one a better feel for the front to rear rates on a single car when the two axles have differing motion ratios (L1/L2, see below). It might be helpful to think of wheel rate as the effective spring rate when the spring is actually installed onto the car. " Wheel Rate = F2/dw = k1(L1/L2)² Wheel Rate = Spring Rate x (Motion Ratio)²
BUY MY CIVIC |
