Old 05-31-2007, 09:26 PM   #1 (permalink)
laughoutlloyd8's Avatar
Question Another Alignment Question**
I took my car into a tire shop to try and get an alignment. I have my car lowered on sportlines. The guy told me that without camber kits, all he can do is fix the toe for $69. Is it that important, can I drive my car for about a couple months and buy the kit down the road or fix it asap?
appreciate any comments
laughoutlloyd8 is offline   Reply With Quote
Old 05-31-2007, 09:30 PM   #2 (permalink)
Dave
Get it quick cuz in a couple months then you will need tires. ASAP!!!!!
gsrsiguy is offline   Reply With Quote
Old 05-31-2007, 10:59 PM   #3 (permalink)
Louder than 4 F404-GE-400
Paul
I went like 8000 miles without a rear camber kit with only slight tire inside wear at -2.5. So get it at some point, but you don't hafta rush.
Old 05-31-2007, 11:01 PM   #4 (permalink)
Do you want to acutally handle better? Then get a camber kit front and rear. Read the suspensions sticky in this area too that will give you an idea of what you may or may not want to do with your alignment. :)
\/\/ Beat you too it
Old 05-31-2007, 11:01 PM   #5 (permalink)
Soup-R-Charged!
ImTheVoiceOfGod's Avatar
Corsport Fanboi
Getting the kit will also improve handling greatly.
EDIT^Beat me to it.
ImTheVoiceOfGod is offline   Reply With Quote
Old 05-31-2007, 11:25 PM   #6 (permalink)
Thanks guys.
Old 05-31-2007, 11:25 PM   #7 (permalink)
Soup-R-Charged!
Corsport Fanboi
No prob, good luck.
Old 06-01-2007, 08:35 PM   #8 (permalink)
NitrousG35's Avatar
Wild VTEC'n Bill
Generally, when you drop a car more than 1/2 inch, it is a good idea to get a camber kit to get things back to spec. Your tires will be happy too!
Old 06-01-2007, 09:14 PM   #9 (permalink)
you get alot more camber in the back than the front when you lower the new Civic. You don't need to do anything in the front for camber to get it back to stock... but you do for the rear. But if you are looking for performance, then get the fronts and not the back. The rear is good for performance when lowered...but the tires will wear faster.
Chris at RedShift
RedShiftChris is offline   Reply With Quote
Reputable Alignment Place in Baltimore mishima8 Mid-Atlantic 9 05-10-2007 12:33 PM
Alignment in the Dealer? kicker_jace Civic Coupe And Sedan 8 04-26-2007 03:42 PM
Service Manual Alignment Specs? Goose Suspension and Brakes 8 12-08-2006 06:18 PM
good alignment shops in the southbay? junsu California South 1 11-30-2006 08:01 PM
fg2 alignment? subieguy83 Suspension and Brakes 0 04-04-2006 08:34 PM
