Old 05-25-2007, 12:54 AM   #1 (permalink)
DeDonDeRosa's Avatar
Eibach sportline question?? cutting the bumpstops???
ok just got my sportline kit today, and it says you have to trim the rear bumpstops. why is this??? do i really have to take out the shock and do this? i saw on 8thgen, there was a debate on doing it and not doing it. what should i do?? is it really necessary
we put a set of neuspeed race springs in my buddys si which lowers its 2 inches all around and didnt have to cut the bump stops. i dont see why u gotta do it with these ?
DeDonDeRosa is offline   Reply With Quote
Old 05-25-2007, 02:50 AM   #2 (permalink)
INstalling lowering springs shorten the strock on the stock shocks. SInce the stock shocks is not meant for springs, it'll bottom out if you dont cut the bumpstops everytime you ran over a small dip.
C2AUTOSPL is offline   Reply With Quote
Old 05-25-2007, 07:21 AM   #3 (permalink)
how come for example the neuspeed springs which are a 2.0 in drop which is larger than these they dont say to cut the bump stops
Old 05-25-2007, 07:24 AM   #4 (permalink)
1stk20z3's Avatar
Casey
i wouldn't cut them if u hit a bump it will bottom out like a bitch!
1stk20z3 is offline   Reply With Quote
Old 05-26-2007, 11:50 PM   #5 (permalink)
jwon985's Avatar
I have sportlines on my 06 sedan... the shop didn't cut the bumpstops...
haven't bottomed out for a couple months... and i drive through some rough areas...
jwon985 is offline   Reply With Quote
Old 05-27-2007, 02:23 AM   #6 (permalink)
Will06SI's Avatar
Will
I cut the front with my sportlines it says to do it i havent had any problems at all i didn't cut the rears because i didn't want to drill like it says to do you need more travel when the car is lower so def cut the front atleast.
Will06SI is online now   Reply With Quote
Old 05-27-2007, 02:26 AM   #7 (permalink)
anyone know why??
Old 05-27-2007, 02:28 AM   #8 (permalink)
Caper's Avatar
It dosen't even say to cut the fronts... The Si has more of a bottoming out problem in the rear.
Caper is offline   Reply With Quote
Old 05-27-2007, 11:21 AM   #9 (permalink)
mattsbobo's Avatar
Who watches the Watchmen?
I dropped my Si on Skunk 2 springs, didn't cut anything, and haven't rubbed, or bottomed out yet.
Old 05-27-2007, 11:32 AM   #10 (permalink)
Will06SI's Avatar
Will
Your crazy i will scan the instructions it def says to cut the front its the front where you want more travel not the rear.
Old 05-27-2007, 02:30 PM   #11 (permalink)
i just dont under stand whats the point when other spring companys dont tell you to do so.
i think its just because eibach wants u to be safe going over large dips without bottoming out.
Old 05-27-2007, 02:49 PM   #12 (permalink)
Will06SI's Avatar
Will
Tein tells you 2 my buddy who helped me install them even said tein said to do it but must people just choose not 2 do it !
Old 05-27-2007, 08:19 PM   #13 (permalink)
Caper's Avatar
Just went to check the intructions... can't find them.
Old 05-27-2007, 09:48 PM   #14 (permalink)
adoBoy619's Avatar
Rollin
i cut all of mine. mine is good all around....i did have to take those flap things off though cuz i got some BIG dips leaving parking lots here and when that would hit the street, it torn off my fender... but now i have no probs
adoBoy619 is offline   Reply With Quote
Old 05-27-2007, 10:20 PM   #15 (permalink)
Dave
I have the eibach sportline and you definately have to cut them, Its a great suspension especially if you get the progress sway bar. It handles amazing but trust me CUT THEM or you will be sorry.
gsrsiguy is offline   Reply With Quote
Old 05-27-2007, 11:36 PM   #16 (permalink)
jballer187's Avatar
Jonny
My instructions are right in front of my face and dont worry it says nothing about front bumpstops (just rear). Not to sure what instructions he got?
jballer187 is offline   Reply With Quote
Old 05-28-2007, 03:08 AM   #17 (permalink)
iqbbang's Avatar
Tom Lim
i didnt cut mine, and i have no problems yet. would i bottom out easier?
iqbbang is offline   Reply With Quote
Old 05-28-2007, 04:48 AM   #18 (permalink)
Will06SI's Avatar
Will
It says it right on the front there is a picture of the bump stop then it says front bump stop trim 40mm to cut rear bump stop trim 40mm to cut !
Old 05-28-2007, 05:04 AM   #19 (permalink)
vegeta21's Avatar
i am lowered on sportlines as well and i definitely cut mine
vegeta21 is offline   Reply With Quote
Old 05-28-2007, 11:15 AM   #20 (permalink)
adoBoy619's Avatar
Rollin
if the directions say to do it then do it, im not a spring expert, so i go with what they say. thats they expertise
Eibach Sportline or Tein Stech ayenoc Suspension and Brakes 18 10-29-2007 11:42 PM
Eibach Sportline Question?? 06silvercivic Suspension and Brakes 1 03-20-2007 11:08 AM
front settled height of tein s. vs eibach sportline junsu Suspension and Brakes 11 01-02-2007 06:22 PM
Question about installing sportline Andysofiyah Suspension and Brakes 10 08-23-2006 02:06 AM
Sportline Eibach Springs Tim CorSport 2 04-11-2006 05:11 PM
