LinkBack (7) Thread Tools Display Modes
Old 09-29-2007, 08:10 PM   #101 (permalink)
Louder than 4 F404-GE-400
Paul
DON'T put non HFP springs on the HFP suspension. The dampers are valved to work perfectly with with the springs. So changing them is going to defeat the purpose of getting better handling out of the car. If you really want to hanlde better, looks sould be of no concern. Remember, you can't see the what the car looks like when you are driving, you can only tell how it feels. The Si suspenion can pull .9g on some sticky rubber and even more with a good alignment. I would call that pretty good.
Sirbelch is offline
Old 10-02-2007, 03:11 PM   #102 (permalink)
smokenrowboy's Avatar
FMInterf00ler0_o
sorry if i missed it reading the article, but do front and rear lower tie bars affect handling considerably? im no longer interested in a sway bar because of the recently discovered endlink problem, and h-braces dont do much
smokenrowboy is offline
Old 10-02-2007, 06:47 PM   #103 (permalink)
fiji-blew's Avatar
wat eizz dis end link problem?
fiji-blew is offline
Old 10-02-2007, 10:10 PM   #104 (permalink)
eugenekim.net's Avatar
captain obvious
it's a spelling problem
In June 08, I'm doing a 545 mile bike ride from San Francisco to Los Angeles to help raise money for people living with HIV/AIDS and I need help, all of your help. http://www.aidslifecycle.org/5664
eugenekim.net is online now
Old 10-02-2007, 10:16 PM   #105 (permalink)
HR1!!!!!
Highrev1's Avatar
Greg@Redshiftmotorsports.com
I didn't get the question....
Originally Posted by Hondata View Post
We are working on a programmable system for the Civic.1) It is our TOP priority. We have purchased two Civics for this reason.More calls however, cannot make the development proceed at a faster rate, so please be patient.
Dinner meet at my Resturant
Willwood BBK For Sale
Highrev1 is offline
Old 10-02-2007, 11:03 PM   #106 (permalink)
You'll only die tired
Redleg06Si's Avatar
Joe
Important info for all those with aftermarket sways!
Post Whore #2 (Da Deuce)
<INJEN> <GREDDY> <P2R><Eibach><DCSports><TSW>
Originally Posted by akai6 View Post
Although I guess you could be the Male total Package
Redleg06Si is offline
Old 10-02-2007, 11:10 PM   #107 (permalink)
Paul
The tie bar will help with feel a little, it won't help handling (quantitatively), but should increase your confidence in your driving skills because you think it is supposed to help so you drive the car harder than you ever did before which makes you think that the tie bar works.
Sirbelch is offline
Old 10-05-2007, 07:01 PM   #108 (permalink)
aki
aki's Avatar
Resident Si Sedan Hater
Hypothetically, a tiebar reduces body twisting and increases rigidity. But if you look at the front tie bar it's across the firewall section of the frame which seems pretty rigid already. Something tells me it won't make that much of a difference.
aki is offline
Old 10-05-2007, 11:28 PM   #109 (permalink)
-=[P1NGP1NG]=-
P1NGP1NG's Avatar
Ping Ping
any idea on the mugen type-r sports suspension ?
thanks...
P1NGP1NG is offline
Old 10-06-2007, 12:10 AM   #110 (permalink)
HR1!!!!!
Highrev1's Avatar
Sure here is all theinformation you will need
Highrev1 is offline
Old 10-06-2007, 12:12 AM   #111 (permalink)
Paul
Those seem to be some ok dyno curves. Revy, your thoughts on the curves?
Sirbelch is offline
Old 10-06-2007, 03:16 AM   #112 (permalink)
HR1!!!!!
Highrev1's Avatar
It appears as if they almost reduced rebound on the rear dampers on the mugen setup compared to the stock dampers. Other than that they appear to be slightly more aggressive, although the mugen fronts have what appears to be more low speed valving, I think it is after 3 here and I am waswted
Highrev1 is offline
Old 10-06-2007, 05:09 AM   #113 (permalink)
Paul
So, with the more low speed damping in the front they will have more roll resistance than the stock type r suspension. Also, with the lower mid to high speed damping and compression front and rear, they would be a little nicer on the butt on the big bumps of the streets.
Its 2 am out here and im drinking too. 3.5 shots of jack on the rocks in 45 minutes.
Sirbelch is offline
Old 10-11-2007, 12:48 PM   #114 (permalink)
djthomi's Avatar
Tommy
Nice write-up, thanks!
djthomi is offline
Old 01-12-2008, 12:49 PM   #115 (permalink)
Piotrush's Avatar
Peter
Great thread!
I'm looking for similar handling as I had on my prelude SH; OTS konis, 400F/450R GC, ST 25mm rear bar, strut braces. Originally started with the 450 springs in front, but I was much happier when I moved them to the back.
Thing is that I think the GCs were overkill for what I needed. I was lowered about an inch, never got corner balanced, once I found my ride height I kept it that way till I traded th car in...so over 2 years. I didn't even adjust the shocks too often.
On my Si, I already have the PS2 tires and I'm contemplating 2 setups:
1) HFP suspension + alignment + maybe rear anti roll bar (if I need more rotation).
2) OTS Konis with stock springs + alignment + rear anti roll bar (I'm guessing it wont rotate enough w/o it since I'll be using stock springs). I'll also be able to lower the car a tiny bit with the various circlip positions, I assume.
I'm just thinking that doing the whole GC/Koni combo is overkill since this car might only see some auto-x/HPDE action, which will be strictly for fun, not competition. Any comments or feedback on my 2 choices from the suspension gurus greatly appreciated.
Piotrush is offline
Old 01-12-2008, 06:54 PM   #116 (permalink)
Paul
^^^Are the OTS konis for your lude an insert? Koni's site says they are inserts, sites that sell them say they are a full shock ready to bolt in. My friend is going to get them.
Did you like the ride on your lude with the OTS konis/GC combo? If you did, why not get them again for the Si? Even though you aren't looking to really compete in any auto xes, I bet you will have more fun with the OTS konis/GC combo then the other two you have listed. Going fast is fun. Going faster is more funner.
Waking up dead inside of my head will never never do, there is no med, no medicine to take.
I've had a chance to be insane, asylum from the falling rain. I’ve had a chance to break.
Sirbelch is offline
Old 01-21-2008, 03:03 AM   #117 (permalink)
Rems07si's Avatar
Remy
Hey im looking for a suspension kit that rides close or better then stock over bumps and pot holes but fits 18s with no gape can someone help me please I just don't have the money or time to find out the hard way by buying like 3 kits to find the right one no what I mean.
Rems07si is offline
Old 02-04-2008, 08:44 PM   #118 (permalink)
DigitalAnalog's Avatar
Great thread!
DigitalAnalog is offline
Old 02-04-2008, 09:34 PM   #119 (permalink)
friedk's Avatar
Gtoooo
friedk is offline
Old 02-27-2008, 06:14 AM   #120 (permalink)
captain obvious
greg, what do u think of pic performance coil-overs?
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/41081-suspensions.html
Suspension Theory - Honda FIT Forums This thread Refback 02-24-2008 02:22 PM
Sticky?: Suspension Theory - Honda FIT Forums This thread Pingback 02-23-2008 01:18 PM
Suspensions!!! ¨Ò¡ 8th Civic - Civic FD Thailand Community This thread Refback 01-09-2008 08:36 AM
Civic FD Thailand Community > Suspensions!!! ¨Ò¡ 8th Civic This thread Refback 01-07-2008 09:51 PM
Suspension and Brakes - Page 50 - 8th Generation Honda Civic Forum This thread Refback 12-31-2007 10:19 PM
Suspensions!!! ¨Ò¡ 8th Civic - Civic FD Thailand Community This thread Refback 12-18-2007 09:20 PM
Suspension and Brakes - 8th Generation Honda Civic Forum This thread Refback
