#141 (permalink) |
jason
lude
The prelude does not take a insert(inserts are mainly used for strut cars) were the strut is cut open, all the guts are taken out and the insert is slid inside and either held in from the bottom with a bolt or there is a sleeve welded to the top of the oe body and threaded for a gland nut to hold everything in.
The prelude is a shock car, front is a 8041-1232sport and the rear is a 8041-1155 sport which has external rebound adjustment. The insert is what will be used on the front of the 06+civic |
#143 (permalink) |
Koniman now an insert for the OTS konis for the FG...I thought that you guys were gonna do a whole housing and that was the delay as there are 5 or 6 different housings for this car throughout the world???
#149 (permalink) | |||
Paul
now doesn't it. I just told a man that works for a company what they were making, again, |
#153 (permalink) |
Yeah, thats the mustang donor setup
We have gotten a couple of sets of those already. But obviously only D/A. We did just find an OTS single adjustable koni option for the front and rear. I just gotta test them and then they will be out. Get on Im's I will show YOU the shock dynos of them, since you can just get them from work anyway
#155 (permalink) |
Track Day Camber Settings
Greg,
Read all 8 pages. Still not sure about settings. What are your recomended camber settings for Track Days. I have an 08 Si sedan. Also recommended front camber bolts and rear adjuster. Watkins Glen April 29th |
#156 (permalink) |
mmmmmmmmmm...The Glenn I love it there...For a track day setup, things change. what tires will you be running...Whos that with PDA? I want to go..
I was up there and got to walk the track that was cool as ****..![]()
#158 (permalink) | |
Thanks!! |
#159 (permalink) |
Eitherway the limiting factor will be those stock Michilen's. I killed those in one day
The scalloped and were ruined I would still stick to say -1.75 front and -1 rear 0 toe all around. Those tires don't like too much heat..::o
#160 (permalink) | |
Peter
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/41081-suspension-variables-definitions.html
| Suspension Theory - Honda FIT Forums | This thread | Refback | 02-24-2008 03:22 PM | |
| Sticky?: Suspension Theory - Honda FIT Forums | This thread | Pingback | 02-23-2008 02:18 PM | |
| Suspensions!!! ¨Ò¡ 8th Civic - Civic FD Thailand Community | This thread | Refback | 01-09-2008 09:36 AM | |
| Civic FD Thailand Community > Suspensions!!! ¨Ò¡ 8th Civic | This thread | Refback | 01-07-2008 10:51 PM | |
| Suspension and Brakes - Page 50 - 8th Generation Honda Civic Forum | This thread | Refback | 12-31-2007 11:19 PM | |
| Suspensions!!! ¨Ò¡ 8th Civic - Civic FD Thailand Community | This thread | Refback | 12-18-2007 10:20 PM | |
| Suspension and Brakes - 8th Generation Honda Civic Forum | This thread | Refback | 12-13-2007 05:34 AM | |
| Which suspension best for Sedan: Si Coupe Suspension or HFP? | mikeymike | Suspension and Brakes | 17 | 02-24-2009 02:36 PM |
| 1999ish Integra Type R suspension vs. HFP suspension | Illinoisone | Suspension and Brakes | 3 | 02-09-2008 10:05 PM |
| are sedan suspension and coupe suspension interchangeable? | iqbbang | Suspension and Brakes | 0 | 05-27-2007 07:59 PM |
