#21 (permalink) |
For a fairly detailed debate about chassis bracing look here. any one put a strut towerbar on an si?. Also even in post 84 on the thread you gave the designer even says it won't make your suspension stiffer. Just some food for thought.
Biggest improvment would be TIRES. 1. Tires 2. Proper alignment (not an OEM one!) 3. Dampers 4. Springs 5. Anti-roll bar or bars, depending on your springs. 06BlackSI you can IM me if you would like
#22 (permalink) | |
Paul
The "slammed look" and good handling can not be in the same sentence. If you over lower the car, you will lose suspension travel and ruin the suspension geometry of the car especially in the front. |
#23 (permalink) | |
I agree that tires are the best improvement as they are the one and only aspect of the suspension that makes contact with the road... the car's handling is limited by the limits of the tire. I will IM you highrev to figure out some handling recommendations for a daily driver... |
#26 (permalink) | |
Michael Bringle
Where would lighter rims fit in that list? I drawing up my list on how much money gets allocated to each item. The car will be a street driven daily driver that really likes to turn hard. I will probably go with Tein Flex because of how much I liked them on my Supra. But the other parts are still up in the air. Like saving the money and extra weight of chassis bracing and putting that to lighter rims or better tires instead.
#27 (permalink) |
Way down unless you are serious about competition reducing unspring weight will help but not a necessary thing to do. So if anything I would say wider wheels with a good set of tires and don't worry about the weight of them SOOO much but don't get some concrete shoes either
#32 (permalink) |
Thanks...theres a couple of guys around here who know and some who think they know...Make sure any advice you get is from those that are in the know...
#34 (permalink) | |
50 LOW
Also, I'd really like to have my alignment done on my stockers, would it make a difference if your wheel/tire radius/circumference is different? Thanks. |
#35 (permalink) | |
I get a new set of tires I get a new alignment....Tires aren't cheap and just want to ensure proper specs and wear...IMHO
#36 (permalink) | |
"Godfather of Suspensions"??? Dear God man, you've gone mad... Just kidding. BTW everyone, you can trust Greg. Also, I am someone in the "KNOW" as many of you know... And if he ever comes back online here, SWRT is a true genius. Anthony "Mario" Crea NNJR-SCCA |
#38 (permalink) |
If you lower your car doesnt the camber increase in the rear?
Is it limited by metal or something? Like can it go to inifinity negative camber in rear? Also, why doesn't a performance oriented car come with its own camber kit? Does the SI come with one? I dunno? I think S2000 does. I dont have my SI yet waiting on the 08's but I'm thinking to stick with my tired and true combo with all my Hondas. H&R sports, with Koni yellows. DD. |
#39 (permalink) |
You'll only die tired
![]() Join Date: Mar 2006
Joe
running 225/40/18 and considering getting either the S Tech or H Tech springs.....will I have any rubbing issues with either of these set ups.....suspension noob
http://img.photobucket.com/albums/v1...res/redleg.jpg Post Whore #2 (Da Deuce) <INJEN> <GREDDY> <P2R><Eibach><DCSports><TSW> |
#40 (permalink) | |
If you look at the OEM spec's, Honda has setup these specs to pretty much allow for NO camber up front. And about -1 degree in the rear. Why? So your car understeers. This is so the car is safe for you to drive without the waggin the tail all over the place. This also does not allow for good turn in or a "fun" car to drive. Koni's are truly a great damper....I would suggest the Ground controls though they are slightly more aggresive and are ride height adjustable Redleg06Si-I don't know I would say no depending on the offset but a search would result better answers than that...
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/41081-suspension-variables-definitions.html
| Suspension Theory - Honda FIT Forums | This thread | Refback | 02-24-2008 03:22 PM | |
| Sticky?: Suspension Theory - Honda FIT Forums | This thread | Pingback | 02-23-2008 02:18 PM | |
| Suspensions!!! ¨Ò¡ 8th Civic - Civic FD Thailand Community | This thread | Refback | 01-09-2008 09:36 AM | |
| Civic FD Thailand Community > Suspensions!!! ¨Ò¡ 8th Civic | This thread | Refback | 01-07-2008 10:51 PM | |
| Suspension and Brakes - Page 50 - 8th Generation Honda Civic Forum | This thread | Refback | 12-31-2007 11:19 PM | |
| Suspensions!!! ¨Ò¡ 8th Civic - Civic FD Thailand Community | This thread | Refback | 12-18-2007 10:20 PM | |
| Suspension and Brakes - 8th Generation Honda Civic Forum | This thread | Refback | 12-13-2007 05:34 AM | |
| Which suspension best for Sedan: Si Coupe Suspension or HFP? | mikeymike | Suspension and Brakes | 17 | 02-24-2009 02:36 PM |
| 1999ish Integra Type R suspension vs. HFP suspension | Illinoisone | Suspension and Brakes | 3 | 02-09-2008 10:05 PM |
| are sedan suspension and coupe suspension interchangeable? | iqbbang | Suspension and Brakes | 0 | 05-27-2007 07:59 PM |
