LinkBack (7) Thread Tools Display Modes
Old 06-21-2008, 11:59 PM   #221 (permalink)
Dustin
stock camber: 0 in front -1 in rear.
what if i set rear to 0?
how would that affect my handeling?
im just curious if that would help increase tire wear. w/o sacraficing to much handling.
this would be combined with hfp suspension.
Slipp is offline   Reply With Quote
Old 06-22-2008, 12:47 AM   #222 (permalink)
Louder than 4 F404-GE-400
Paul
You are better off leaving the rear alone and adding negative camber to the front. No camber in the rear could make the car twitchy when cornering.
Old 06-28-2008, 11:04 PM   #223 (permalink)
tuner student's Avatar
Location: stationed in Newburgh NY/ born and raised in orlando, fl
Andrew
wow alot of good info. def gonna have to read through it again to get it all. beaware northeasters, at meets i may be asking alot of explanations lol. i'm more of a hands on person to person learner.
USMC
Northeast 8thcivicfest 09: Pic Thread
tuner student is offline   Reply With Quote
Old 06-28-2008, 11:09 PM   #224 (permalink)
Micah's Avatar
micah
question, would i want a high coilover rate if i were to be more of a racer than a street driver??? cuz every corner i come to, i take it fast not slow....i want somethin to handle tremendously not good...what brand should i look at?
Micah is offline   Reply With Quote
Old 06-28-2008, 11:39 PM   #225 (permalink)
Paul
06 Civic Susp Packages If you are serious, look at their race packages.
Old 07-06-2008, 02:39 AM   #226 (permalink)
Originally Posted by Sirbelch View Post
Those 2 things are almost impossible to have at the same time. If you want to go fast, you need to give up comfort.
Although these do come close.
click here
Don't get the Tein SS.
HFP is great
Lowering springs really aren't going to improve performance.
Have heard of BC, but I don't think any reviews have been done.
Hey folks. I just joined the forum after searching the net for good suspension info on the FG. Picked my car up this past december and am currently running the HFP suspension.
I previously had the SS-P on my em2, and while initially I was satisfied with its performance, I found that its staying power was a bit in question. Much like someone described previously, the coilover starts getting really loose and takes longer and longer to settle after hitting bumps. I put about 15,000 miles worth of driving on them (mixed highway, street, and auto cross) so I'm not sure I should be complaining about how long they lasted, but you can expect that you will need to commit funds to having them refreshed on a per year basis by Tein, and unless you have a spare suspension/techinical knowledge/cheap mechanic this could be more than some people are willing to do. I also never lowered the car more than 2" (cept right before I took the coils off), and when I did the handling was adversely affected.
With that said I really like the HFP suspension, although I can't tell how good the performance is with the MXM4s I'm stuck riding on (Man these tires are terrible). The suspension seems bouncy, but I'm hoping better grip will fix what I percieve as some twitchiness over undulating surfaces. Any thoughts folks?
Man there some really great info here. I've joined a few other forums, but the techinical info can be lacking at times.
vaek is offline   Reply With Quote
Old 07-09-2008, 09:46 PM   #227 (permalink)
07 Figi Blue Si's Avatar
Lance
Rear swaybar, end links, LCA bracket reinforment DONE RIGHT!
07 Figi Blue Si is offline   Reply With Quote
Old 08-01-2008, 09:34 AM   #228 (permalink)
dave218809's Avatar
David
lowering a FG
i have a FA and just put some 18s on it. I want to lower it but im not sure how low to put it. I want it to look good but i dont want any problems with rubbing or anything like that.
dave218809 is offline   Reply With Quote
Old 08-01-2008, 02:28 PM   #229 (permalink)
Paul
The stiffer the springs, the lower you can go without rubbing.
Old 08-02-2008, 02:24 PM   #230 (permalink)
lazyrichi3's Avatar
richie
i was wondering, if i get the HFP, do i still need a camber kit? front and/or rear? and wats the drop on it to be sure?
lazyrichi3 is offline   Reply With Quote
Old 08-02-2008, 05:08 PM   #231 (permalink)
Paul
drop is about .8-1 inches depnding on who is measuring.
Camber kits: for tire ware, no. For much better handling, front camber is a must. You would not believe what -1.5 degrees up front does for handling.
Old 08-02-2008, 05:23 PM   #232 (permalink)
lazyrichi3's Avatar
richie
so the drop is not noticable right?
Old 08-03-2008, 09:56 AM   #233 (permalink)
Threecamels's Avatar
Puddin Tame
"so the drop is not noticable right?"
The drop is noticable, just not as much as other manufactures. Go get out a tape measure and actually look at the difference between 1" and 1.4", it's not that much.
Threecamels is offline   Reply With Quote
Old 08-05-2008, 12:05 AM   #234 (permalink)
dave218809's Avatar
David
.4 inches might not be much but on i car it can be a good bit, i think that that .4 inches lower can make the car look a lot better
Old 08-05-2008, 01:00 PM   #235 (permalink)
Puddin Tame
Are you accusing me of not caring about looks?
I painted my brake-calipers and my Progress Sway-bar red.
Old 08-05-2008, 09:14 PM   #236 (permalink)
dave218809's Avatar
David
i not accusing u of anything, i was just sayig that .4 inches might not be much but on a car height it can be a good bit
Old 08-05-2008, 09:21 PM   #237 (permalink)
Paul
we have the slowest car in our class and are mid pack in handling. Why on earth would you want to spend money trying to look good instead of spending money on closing the gap?
Old 08-05-2008, 09:36 PM   #238 (permalink)
dave218809's Avatar
David
because i want my car to look good to, and i dont know about the slowest in our class ive beat cars that r in our class
Old 08-06-2008, 05:09 AM   #239 (permalink)
Puddin Tame
And looked good doing it!
Old 08-06-2008, 11:25 AM   #240 (permalink)
dave218809's Avatar
David
haha ya i did
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/41081-suspension-variables-definitions.html
Suspension Theory - Honda FIT Forums This thread Refback 02-24-2008 02:22 PM
Sticky?: Suspension Theory - Honda FIT Forums This thread Pingback 02-23-2008 01:18 PM
Suspensions!!! ¨Ò¡ 8th Civic - Civic FD Thailand Community This thread Refback 01-09-2008 08:36 AM
Civic FD Thailand Community > Suspensions!!! ¨Ò¡ 8th Civic This thread Refback 01-07-2008 09:51 PM
Suspension and Brakes - Page 50 - 8th Generation Honda Civic Forum This thread Refback 12-31-2007 10:19 PM
Suspensions!!! ¨Ò¡ 8th Civic - Civic FD Thailand Community This thread Refback 12-18-2007 09:20 PM
Suspension and Brakes - 8th Generation Honda Civic Forum This thread Refback 12-13-2007 04:34 AM
Which suspension best for Sedan: Si Coupe Suspension or HFP? mikeymike Suspension and Brakes 17 02-24-2009 01:36 PM
1999ish Integra Type R suspension vs. HFP suspension Illinoisone Suspension and Brakes 3 02-09-2008 09:05 PM
are sedan suspension and coupe suspension interchangeable? iqbbang Suspension and Brakes 0 05-27-2007 06:59 PM
