Old 05-22-2007, 03:54 PM   #1 (permalink)
reaper702's Avatar
dc5 ITR brembo kit
i was wondering if ppl could provide input on what would be necessary to make the dc5 type r brembo kit work on an fg2.
most kits i see for sale come with the brembo rotors, brembo calipers, pads, and brake lines.
so i know some brackets are needed and what about the distribution of the brake force? does that come into play here?
reaper702 is online now   Reply With Quote
Old 05-22-2007, 03:56 PM   #2 (permalink)
brthorner's Avatar
Brian
Are you aware that there already is a Brembo BBK available for the FG2?
brthorner is offline   Reply With Quote
Old 05-22-2007, 04:00 PM   #3 (permalink)
reaper702's Avatar
didn't know it was officially out already, but i bet it is like 1500-2k . you have a link btw?
Old 05-22-2007, 04:00 PM   #4 (permalink)
brthorner's Avatar
Brian
The slotted part number is 1A2.6022A. The drilled part number is 1A1.6022A.
Old 05-22-2007, 04:01 PM   #5 (permalink)
brthorner's Avatar
Brian
http://www.brembo.com/CatalogoHPGT/T...=NoModifyGuest
Old 05-22-2007, 04:02 PM   #6 (permalink)
brthorner's Avatar
Brian
It's actually more like $2,300...
Old 05-22-2007, 04:05 PM   #7 (permalink)
reaper702's Avatar
even worse, used itr brembo kits go for around 800 and save almost 2/3
Old 05-22-2007, 04:06 PM   #8 (permalink)
reaper702's Avatar
thnks for the link btw, +rep
Old 05-22-2007, 04:13 PM   #9 (permalink)
brthorner's Avatar
Brian
Check this out...some guy on eBay is selling the calipers from an EVO VIII for less than $400. That's 2 x 4-piston front Brembo calipers + 2 x 2-piston rear Brembo calipers.
http://cgi.ebay.com/ebaymotors/BRAKE-CALIPERS-BREMBO-MITSUBISHI-LANCER-EVOLUTION-EVO-8_W0QQcmdZViewItemQQcategoryZ33563QQihZ002QQitemZ1 20122247225QQrdZ1QQsspagenameZWDVW
If I had any idea what it would cost to custom fabricate mounting brackets to make them work on an FG2, I'd buy them! I believe the rotors that work with these calipers are 330x32mm up front and 300x22mm in the rear.
Old 05-22-2007, 05:31 PM   #10 (permalink)
TampaSi07's Avatar
Those are great kits if you like absolute overkill.
TampaSi07 is offline   Reply With Quote
Old 05-22-2007, 11:08 PM   #11 (permalink)
reaper702's Avatar
please explain yourself...
Old 05-22-2007, 11:10 PM   #12 (permalink)
There great for the track to dissipate heat and not experience brake fade but under street driving conditions they are overkill.
Can your stock brakes/tires envoke ABS? If yes then you are at the max that you will brake. TIRES 4 small contact patches if those are MAXED then it almost doesn't matter what you do elswhere.
Old 05-22-2007, 11:21 PM   #13 (permalink)
TampaSi07's Avatar
We spent the other day bedding in pads with R compound tires. We used Carbotech AX6 pads on stock rotors with Motul RBF600 and Goodridge lines. We then ran a simulation and experienced ZERO fade (unlike the nearly complete fade I was able to produce after just a couple of minutes on the stock setup on street tires). So instead of spending $2300 you can spend under $400 and get performance suitable for tracking on R compounds not to mention street tires. Carbotech does not recommend running the AX6 on the street, but if you can live with the dust (non corrosive dust unlike Hawk HP+) there is really no reason not to.
Also, think of how much unsprung rotational weight you are adding to each corner of the car? My guess is that you are adding at least 15lbs/corner not to mention you are forced to run 18" wheels minimum also adding to the weight. In the end you end up with a worse riding, worse handling, slower car for $2300! But the ricers will sure think it looks "balla yo!"
Old 05-22-2007, 11:36 PM   #14 (permalink)
Black_civic_Si's Avatar
me and boy install a set of jdm dc5 brembo on his car awhile ago, down fall of having them can't source the rotor and it is bank for them (rotor). Her the pick of them when we install them.
Black_civic_Si is offline   Reply With Quote
Old 05-23-2007, 12:19 AM   #15 (permalink)
jay3151's Avatar
Juan Carlos
u cant find the rotors replacements?
i had a difficult time tryin to find a pair of pads for my friend RSX-S w the ITR/brembo suspention setup
jay3151 is online now   Reply With Quote
Old 05-23-2007, 12:56 AM   #16 (permalink)
the rear pad use oem fg2 rear pad and the front is 350z w/ brembo application.
Old 05-23-2007, 12:59 AM   #17 (permalink)
also earlier today i found a website that carry them, but never heard of thm before. Here the link,http://www.boomplustoys.net/jdm_rsx3.shtml
Old 05-23-2007, 02:33 AM   #18 (permalink)
reaper702's Avatar
i'm almost positive that was an rsx you guys put the brembo kit on correct?
Old 05-23-2007, 09:03 AM   #19 (permalink)
jay3151's Avatar
Juan Carlos
thanks we ended up getting project MU pads
Old 05-24-2007, 06:48 PM   #20 (permalink)
yes it is a rsx type-S, but you need alot of jdm parts to install the jdm brembo on the car.
S2k Brembo Kit on Si possible? siddraj21 Suspension and Brakes 22 05-30-2007 04:33 PM
Brembo 13" Brake Kit FG*SQUAD Nick Suspension and Brakes 30 05-21-2007 05:43 AM
Plan on getting DC5 ITR rims for my 06si...what else do I need? duy2006si Wheel And Tire Upgrades 7 03-08-2007 02:36 AM
DC5 ITR rims on 06si... duy2006si Wheel And Tire Upgrades 10 09-30-2006 12:01 AM
brembo bbk kit boostedg35 CorSport 1 05-06-2006 07:25 PM
