Old 05-22-2007, 01:26 AM   #1 (permalink)
DeDonDeRosa's Avatar
Sportlines and 18's??? rubbing??? help
ok im lookin to sportlines on my si with a set of 18s but im worried about rubbing. what size tire should i put on the wheels. anyone running 18s with sportlines??? any probs. please let me know what to do thanks
its on an si.
DeDonDeRosa is offline   Reply With Quote
Old 05-22-2007, 02:01 AM   #2 (permalink)
Chris
u shouldnt have any problems, i had 18s and a tein drop on my old car and everything was fine.... a little rub never hurt anyone... rubbin is racing!
streetmachine02 is offline   Reply With Quote
Old 05-22-2007, 03:54 AM   #3 (permalink)
JeShUa's Avatar
i can has lower?
get 18 x 7.5 +45 and 225/40 tires you'll be fine
JeShUa is online now   Reply With Quote
Old 05-22-2007, 04:35 AM   #4 (permalink)
Jardiniboy's Avatar
Jasten
If you're worried about rubbing just roll your fenders, or strech your tires.
Old 05-22-2007, 07:41 AM   #5 (permalink)
Tom
first off ..stretched tires is LAME ASS
here is what i would recommend based on experience
i have found that with Tein S-techs (similar to the eibachs as far as drop goes) and 225 40 18" tires (the most common size tire used on 18s) .. you will rub on bumps ... the plastic fenderwell liner rubs a bit .. some have said that eventually it rubs away a little plastic and stops .. but thats up to you if you want to do that
the alternative .. depending on how wide you go for wheels is to run a 215 40 18 tire ..
i have 18x7.5 wheels +45 offset running with 215 40 18 and have had NO rubbing issues whatsoever...
*DISCLAIMER* - the above comments are in reference to S-techs installed on a SI sedan* ... results for the coupe maybe different
however originally on the hfp 18" wheels - which are 18x7 +45 .. i ran a 225 40 and did have rubbing ...
2006exsedan is offline   Reply With Quote
Old 05-22-2007, 10:44 AM   #6 (permalink)
huevosrancheros's Avatar
x2
huevosrancheros is offline   Reply With Quote
18X8 5-114.3 40HS....with eibach sportlines and 215 40 18s... japspecjohn Wheel And Tire Upgrades 5 05-13-2007 04:55 AM
S-Tech or Sportlines? Hndasiguy Suspension and Brakes 8 05-29-2006 05:55 PM
sportlines and 18's pdiddy2386 Suspension and Brakes 2 05-19-2006 12:25 AM
