Old 05-05-2007, 12:50 PM   #1 (permalink)
civicracer32's Avatar
New HFP question!!! SI HFP or Standard HFP on EX coupe???
I have an EX coupe and here's my dilemma...
So i know there's 2 different setups. Both claim to lower each car about an inch.
We know that the Si is lower from the factory to start so here's the question. Would putting on the HFP supension for the Si drop the car even more than the HFP kit for the lx,ex?
Does anyone out there run the Si HFP on their lx or ex coupe?
I'm planning on putting the si sways on my car too.
Obviously, the lighter weight of the Ex in comparison to the Si will cause the suspension to be even stiffer.
Dave
civicracer32 is offline   Reply With Quote
Old 05-05-2007, 08:21 PM   #2 (permalink)
hmm that is a good question. i would suspect that using the si hfp would lower it more than the lx/ex hfp suspension.
exbauer is offline   Reply With Quote
Old 05-05-2007, 09:03 PM   #3 (permalink)
I would be willing to bet that shock valving is different between the two kits.
Old 05-05-2007, 09:06 PM   #4 (permalink)
ameuba10's Avatar
im not sure about the two being capatable...i mean they are different for a reason
ameuba10 is offline   Reply With Quote
Old 05-05-2007, 11:20 PM   #5 (permalink)
Moderator
iluvmycsx's Avatar
it also seems to be the same for the sedan 2 diferent part#
manual 08W60-SNA-100B
auto 08W60-SNA-100A
btw the manual is $120 cheaper
http://www.collegehillshonda.com/hon...erformance.htm
iluvmycsx is offline   Reply With Quote
Old 05-06-2007, 03:10 AM   #6 (permalink)
ironhead's Avatar
Hello I work for honda and I had alot of the same questions.So I looked this matter up 2 months ago for my 4dr si that I own.The hfp suspension is good for both models they have 2 part numbers but are in fact the same part.the suspension is only a 20mm drop so the difference is not huge .I just ordered my RAYS 18 INCH RIMS AND iM PUTTING THE SUSPENSION ON.tHE ONLY problem you will run into is that you can not run any wider of a tire than a 215..I had a 225 on my car and i hit a fender in the front a sheared off a clip on the inner wall liner.I was doing about 90mph.215 clearswhen using the suspension.Also if you want to see parts and options for your car I would go to cor sport usa .com .I sell hondas I really know.
ironhead is offline   Reply With Quote
Old 05-06-2007, 03:26 AM   #7 (permalink)
Moderator
iluvmycsx's Avatar
welcome to site thanks for the info
Old 05-06-2007, 05:13 AM   #8 (permalink)
OneSi's Avatar
i have 225/45/17... so you must be refering to 225/40/r18...because even a 235 will fit with a 17in
OneSi is offline   Reply With Quote
^SO-CaL SQUAD_UP!^ Dessa_8837 California South 292 10-26-2008 07:05 AM
Audio Question...EX coupe Stereo to LX sedan PugManTerror I.C.E., Electrical, Security, & Navigation 12 10-06-2006 06:18 PM
question about 2006 civic ex coupe with xm and navigation myhondacivic I.C.E., Electrical, Security, & Navigation 3 09-21-2006 01:57 PM
Need pics of 17" & 18" HFP on GG EX Coupe stevieray Wheel And Tire Upgrades 2 07-24-2006 08:44 PM
Question about price on Civic EX coupe? BigBucksT Civic Coupe And Sedan 45 05-25-2006 03:26 PM
