Old 05-02-2007, 06:05 PM   #1 (permalink)
JDM06SI's Avatar
chris.
problems removing rear spring on fg2
im not sure where the top bolts are for the rear springs or if there is even any... should i just compress that spring down until it just slides off or what anyone no what to do....
JDM06SI is offline   Reply With Quote
Old 05-02-2007, 06:10 PM   #2 (permalink)
In It To Win It
Mikey6p's Avatar
Mukey
there is nothing really holding them in....just lean down on the lower control arm, and pop the spring out. You don't need a compressor.
Originally Posted by firmhonda
Sometimes, when I hit that "delete" button, I fap uncontrollably. When I'm done I dress as a king and force my girlfriend of 6 years to start calling me "Master" while making some of the lesser people in my neighborhood rub my face with velvet while feeding me delicacies from all over the world from a crystal bowl engraved with the numbers of all the posts I've deleted within the last 36 hours. It's a fine life indeed.
Mikey6p is online now   Reply With Quote
Old 05-02-2007, 06:15 PM   #3 (permalink)
RWatters's Avatar
If you need more space to get them out you can unhook the endlinks from the sway bars to get it to drop a little more. That's what I had to do on the 2 Si's I've lowered.
RWatters is offline   Reply With Quote
Old 05-02-2007, 06:22 PM   #4 (permalink)
In It To Win It
Mikey6p's Avatar
Mukey
I forgot about that....makes it a lot easier.
Old 05-02-2007, 07:19 PM   #5 (permalink)
PoLiShPrInCe's Avatar
make sure to loosen the brake lines first... dont want to risk damaging those when u push down on the lca
PoLiShPrInCe is offline   Reply With Quote
Old 05-02-2007, 07:39 PM   #6 (permalink)
hondaonchrome's Avatar
Lonny
I just had my freind put his weight on the rotor and then just pulled it out,Pull from the bottom its easier.
hondaonchrome is offline   Reply With Quote
Old 05-02-2007, 09:55 PM   #7 (permalink)
Black_civic_Si's Avatar
just remove one bolt from the stock camber kit..here the pic, and this what i did to install mine lot easier.
Black_civic_Si is offline   Reply With Quote
Old 05-02-2007, 10:38 PM   #8 (permalink)
strCIVIC's Avatar
putting the stock springs is a B*tch!!lols... but yeah just take out the bolts from the suspension and the endlinks... to make it easier... when i was putting back my stock springs in the rear.. i used my stock jack and put it ontop the control arm and just raised it up while the whole control arm goes down...
strCIVIC is offline   Reply With Quote
Old 05-02-2007, 11:28 PM   #9 (permalink)
once you take the rear stock struts out, then go ahead take the bolt off from the stock camber kit. Should come out or pop out, i didn't need to take off the endlinks off
Old 05-03-2007, 10:06 PM   #10 (permalink)
JDM06SI's Avatar
chris.
koo i got it springs look awesome i ended up just taking sway bar out and it was a lot easy to get the compresser in there i couldnt push it down enough so i ended up just using compressor and they slipped right out.. thz for help guys
Si Front and Rear Sways on DX/LX/EX cojaro Suspension 92 07-28-2008 05:41 PM
Do I need a spring compressor for sedan rear spings? wrxsti03 Suspension and Brakes 11 04-22-2007 03:35 AM
s tech tein spring, need a rear camber kit? ronjancivicsi Suspension and Brakes 4 04-06-2007 11:25 PM
noise from rear neuspeed race spring visconti Suspension and Brakes 2 02-14-2007 09:15 AM
changing only rear spring? CivicWithNav Suspension and Brakes 6 05-16-2006 05:53 PM
