#62 (permalink) |
NBP Si
i just installed my progress rear sway bar on the weekend...
omg, the car handles great... in corners... the car doesn't understeer... it doesn't even have that pushing feeling... great mod! |
#63 (permalink) | |
2008 NFR S2000
#69 (permalink) | |
^^No prob my pleasure.
I am sure that was just a difference in either your mind, or the way you were driving the car. Even though I have no clue on the HFP damper valving, I find it hard that Honda would allow for their rear dampers to be valved so much that the car would understeer. They just can't do that do to liability reasons, especially in inclement weather people would be wrecking left and right (not meant to be a jerk) |
#71 (permalink) | |
Semi-Si Sedan Hater
Greg: Upgrading sway bars isn't necessarily a bad thing. A lot WRX drivers like to get stiffer rear sways (20mm from 17mm) since it comes with a lot of understeer off the lot, and also has smaller sways than in other regions. As for my planned setup, when I get my Skunk2 camber front/rear I'm planning on -1.2 up front and -0.8 to the rears to go along w/ my Eibach Pros--a bit less than your recommended setup just to minimize inside tire wear. This is my daily driver, afterall. Last edited by aki; 06-05-2007 at 04:49 PM. |
#72 (permalink) | |
I never said it was. I would much rather prefer to tune with spring and dampers rather then sway bars though.
#73 (permalink) | |
Brian
#74 (permalink) |
Springs bounce thats what they do the dampers control this bounce. You could run factory springs with a good shock such as the fsd and have a car that handles really well.
The konis would control the bounce perfectly, and the added valving would quell some body roll. |
#75 (permalink) | |
The Si does "oversteer" when taking a corner too fast; maybe that's what bluetroll meant instead.. |
#77 (permalink) | |
Andrei
:smile: - Cheater. You got a larger sidewall on your tires to better fill in the fender gap. You got 225/45/17 tires. That why it looks better. Your overall diameter is 24.97". While the stock tire on the EX (205/55/16) is a 24.87" overall diameter. And the Si Civic's have a 215/45/17 tire with an overall diameter of 24.61". - I went with a 225/40/18 tire with a 25.08" overall diameter this fills in the fender gap by a tenth of an inch, consequently it also raises the car a tenth of an inch. If every one were to keep there stock tires the non Si Civics would look lower with the HFP suspension kit.
#78 (permalink) | |
Andrei
Progress: rear anti sway bar= 22mm solid Compared to my stock 11mm rear anti sway bar the stock Si one is not flexible. (by hand) |
#79 (permalink) | |
NBP Si
yes, it used to understeer with 17mm RSB... now with the 22mm RSB, i can feel the rear end of the car come around quicker... it feels quite different, but i like it... you can really take the car to the limits. |
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/38479-pics-hfp-suspension-before-after.html
| pics of hfp suspension (before & after) - Page 5 - 8th Generation Honda Civic Forum | This thread | Refback | 01-07-2008 10:16 PM | |
| HFP Suspension Kit Pictures? | FIJIROB | Suspension and Brakes | 10 | 11-19-2010 11:59 PM |
| Which suspension best for Sedan: Si Coupe Suspension or HFP? | mikeymike | Suspension and Brakes | 17 | 02-24-2009 02:36 PM |
| HFP Suspension Does NOT Lower Car ? | Bombero | Suspension and Brakes | 23 | 05-08-2007 04:48 AM |
| HFP Suspension Kit...auto vs manual??? | DooD | Suspension and Brakes | 4 | 12-13-2006 09:32 PM |
| EP3's HFP wheels on Si...with Pics !!! | psc001 | Wheel And Tire Upgrades | 28 | 09-12-2006 03:20 PM |
