Old 04-26-2007, 12:53 AM   #21 (permalink)
Get some Bridgestone Re-01's or Falken Azenis the problem will be solved. :)
Old 04-26-2007, 12:54 AM   #22 (permalink)
kkim388's Avatar
Originally Posted by Sirbelch
No its a Coupe. This is also my second FWD VTEC powered honda. I've had a GSR. Come to think of it, the Si is easeir to get the ABS to kick in when compaired to the GSR. So Just get use to it. Don't give up your Si.
I want you to go out there and give me 20 (times up mountain) :) By then you'll have it down. Is this your first FWD on that road? I have Kumho ESCTA XT 235/40/17 if that helps. Your MX are supposed to be sticker i think.
LOL... no this is not my first FWD car. I've owned a GS-R, Integra Type R, 00 Civic Si, and presently have an NSX and a Honda FIT... just to give a small sampling of what Honda products I've had up and down that mountain. Euro cars include a Porsche 993, several BMWs, a MINI Cooper, etc... let's just say this SI is just one in a loooong line of cars.
And that's not including sport bikes CBRF2, F3, VTR... so I know all too well of doing my braking in a straight line. :)
This SI just feels too easy to get into the ABS which is why I posted.
Smooth braking?? Try not being smooth on the brakes while on a sport bike and you'll be on you ass in nothing flat.
The EBD intrigues me, though... I'll need to read up on it and see if it can be bypassed to test to see if that's the problem or not.
Kumho MX tires??? I've had the same brand/model tires on other cars and had never had a problem with the ABS kicking in prematurely.
kkim388 is offline   Reply With Quote
Old 04-26-2007, 01:21 AM   #23 (permalink)
Louder than 4 F404-GE-400
Paul
From your post i'm sure its not you and you are probibly a better driver than I. Maybe its just your car. Not all cars are the same. Good luck
Old 04-26-2007, 01:30 AM   #24 (permalink)
kkim388's Avatar
I was just trying to show that I'm not making this stuff up and I do feel the brakes on the sedan get into the ABS extremely early. I'll try to ease up on the brake pedal a bit, I guess... hope I don't end up overshooting a corner.
Tires.. I may have to consider the ones mentioned when it comes time to change. As it is, the MXs only have about 1k on them now.
Old 04-26-2007, 02:17 AM   #25 (permalink)
^^youre not the only one. im experiencing the exact same problem with my Si (coupe) and was wondering if something was wrong with my braking system.
normal braking and the ABS will come on; more so in the middle of going over a more-than-normal undulated surface. ive occasionally heard a very audible metal-claterring sound during these incidents as well. anyone know what that could be?
junsu is offline   Reply With Quote
Old 04-26-2007, 02:56 AM   #26 (permalink)
Elitist Si Driver..
Chase's Avatar
Chase
My Step Dad, An ASE certified Mechanic.. Thinks that the brakes are really really grabby to begin with and the ABS is compensating for the strength on the brakes.
Chase is online now   Reply With Quote
Old 04-26-2007, 03:11 AM   #27 (permalink)
Skylinegtr06's Avatar
edwyn(male)
^are strong brakes bad?
Old 04-26-2007, 03:19 AM   #28 (permalink)
Elitist Si Driver..
Chase's Avatar
Chase
No.... but the ABS appears to be working overtime... Which isn't neccesarily a bad thing...
Old 04-26-2007, 04:07 AM   #29 (permalink)
kkim388's Avatar
I noticed the stock brake pads are "abrupt" with little progressive feeling. After I switched to axxis ultimates, the brakes have a nice progressive feel with more clamping power when you really stand on the brakes with better fade resistance too. Nice street pad upgrade.
Old 04-26-2007, 12:21 PM   #30 (permalink)
CZ-75's Avatar
Brian
http://www.geocities.com/nosro/abs_f...%20aftermarket
big brake kit.
What happens if I install aftermarket tires, wheels, brake linings, calipers, springs, . . . ?
It is anybody's guess. Tires and brake linings are fairly safe items to experiment with. Having said this, I will point out that I am familiar with at least one case where the installation of high performance tires (where smooth-riding all-season tires were original equipment) resulted in a reaction with the suspension that ABS had not been tuned to anticipate. In this case, the installation of high performance tires resulted in significantly longer stopping distances because the extra tire traction was causing the front suspension to literally bounce off the jounce bumpers repeatedly, causing very violent changes in tire grip that ABS was not expecting. From a strictly ABS standpoint, it is best to stick with a tire, wheel, or brake lining that is similar in characteristic to the original equipment parts, or at least similar to any of the parts that are available as an option on that vehicle.
Toying with the hydraulic system is slightly riskier. (This would include parts such as the master cylinder, calipers, and brake lines.) If you change the hydraulic characteristics of the brake system, you may reduce the efficiency that ABS operates with. For example, ABS may deteriorate from a 95% utilization of peak tire adhesion to a 90% utilization of peak adhesion. This is due to the fact that ABS is tuned to the hydraulic characteristics of the original brake system, as noted above. Another way to think of this is that ABS, like any other control system, performs some amount of prediction or anticipation to maximize performance. If you change the hydraulic characteristics of the brake system, you render the predictions or anticipations of the system less than ideal. That means ABS will need to react and adapt to the change. Reacting and adapting takes some time and this translates to lowered efficiency.
There are many variables that go into characterizing the hydraulics of a brake system and some are not always obvious. For example, if you install larger race-specifications calipers, you may assume that your new calipers will consume more fluid. This is not necessarily the case. It is true that larger pistons in your caliper will result in greater fluid consumption, but these race-specification calipers are probably also much stiffer than the stock OEM calipers. This stiffness actually reduces overall fluid consumptions. Also counter to your intuition, large race-specification calipers may have multiple small pistons than result in an overall volume displacement that is smaller than the single large piston in your original calipers.
A driving enthusiast may point out how a certain magazine tested a particular vehicle, after installing big brake calipers and rotors, that stopped 10% shorter than the stock car. The problem here is that these changes are almost always made along with a change from all-season tires to high performance tires or some other significant change. As I have noted above, engineers spend years tuning the ABS hydraulic controller to work well with the hydraulic characteristics of the brake system. It is true that your final braking performance may be superior (less brake fade, for example), but speaking strictly from an ABS perspective, it is a crap shoot.
More recently, the June 2001 issue of Car and Driver magazine featured a Roush modified Mustang, featuring race-specification brakes and suspension, and extremely low profile tires. They found the stopping distance to be surprisingly long given the quality of the parts. They attributed this disappointment to the fact that the ABS was not originally designed for such components - my assessment exactly.
In contrast, the September 2002 issue of Car and Driver magazine (they seem to appreciate brakes more than any other car magazine) featured a comparison of four aftermarket big-brake kits for the Subaru WRX. They expected the big-brake kits to show their mettle during their brake fade test, but they did not expect any stopping distance improvements with cold or merely warm brakes. After all, if the brakes can invoke ABS control, the vehicle must be tire-limited rather than brake-limited. However, with every big-brake kit, they found improvements in stopping distance even with cold brakes. There are many possible reasons why this is the case. My best assessment is that, according to my experience driving a Subaru WRX, the ABS was tuned to be very conservative in order to extract stability (resist spinning or oversteer) on ice, resulting in the trade-off of reduced asphalt performance. This is a classic compromise for ABS engineers. Installation of the big-brake kits may have fooled the Subaru ABS into a more aggressive ABS control (for example, with a shorter time between slip cycles) whereas the engineers had intended a more conservative ABS control (to improve resistance to spinning out). Put another way, I believe that the Subaru WRX with one of the big-brake kits featured in this article may have significantly reduced ability to resist spinning out on ice.
I know that StopTech makes aftermarket calipers that are custom tailored to each application by modifying the piston size to closely match total piston area of the stock vehicle. This is smart and shows due care. There may be others, but I have not researched this matter. (I own Stoptech products, but I have no relationship with them.) Some other aftermarket caliper manufacturers take a single design (with one piston size) and use it for everything from a sub-compact to a large sedan. In such cases, your results will depend on being lucky enough to have the one available piston size match your stock piston area.
Suspension modifications are another interesting area. Engineers spend considerable time tuning ABS performance while in an actual prototype vehicle. This means they are working with the entire vehicle - the entire vehicle includes the suspension. In fact, engineers will often find themselves working against the suspension. When you mash the brake pedal, the vehicle begins pitching as weight is transferred away from the rear tires and towards the front tires. This pitching can create difficulties in extracting the last 10 feet of stopping distance. ABS software is sometimes made to anticipate the pitching and to modify the manner in which brake force is modulated. Therefore, if you modify the suspension, you may be reducing the efficacy of ABS.
CZ-75 is offline   Reply With Quote
Old 04-27-2007, 01:31 AM   #31 (permalink)
vtloki's Avatar
Jeffery
I have a similar problem with my 07 SI sedan. I notice it the most when I am braking in Washington DC, and roll over a pot hole while braking. I might only be going like 20mph, and braking in a straight line, but once I hit the pot holes, the abs kicks in. It catches me off gaurd, and is a little annoying. but I get over it.
I haven't noticed the problem while braking in a corner...
vtloki is offline   Reply With Quote
Old 04-27-2007, 03:21 AM   #32 (permalink)
Jardiniboy's Avatar
Jasten
Seriously tires are the MOST important mod on your car PERIOD.
big brake kit. sickyute Suspension and Brakes 150 10-26-2007 06:12 PM
Issues with ABS Light? blackterror Suspension and Brakes 0 02-01-2007 05:49 PM
ABS kicking in on 2006-2007 Civic SI Jacques79 Civic SI 10 01-27-2007 03:06 AM
Random abs light or is the bodyshop hiding something? gbae007 Mechanical Problems & Technical Chat 2 11-03-2006 01:02 PM
ABS Behavior? DSchrag Mechanical Problems & Technical Chat 4 06-19-2006 06:37 PM
