Old 04-18-2007, 11:10 PM   #1 (permalink)
Caper's Avatar
Installing Springs... Help
I am feeling really stupid and frustrated right now... I am trying to get the top nut off of the assembly to put the sportlines on but I cannot seem to get it off. I know you have to use an allen key in the top, but if you use that in the top then how are you supposed to turn the nuts as well cause you can't get a wrench in there and you can't put a socket and rachet over the allen key... Am I missing something? Is this easier to do when the strut is in the car perhaps?
Thanks for all the help!
Update:
Heres is a diagram of what I am talking about...
Caper is offline   Reply With Quote
Old 04-18-2007, 11:17 PM   #2 (permalink)
jballer187's Avatar
Jonny
subscribed. Doing this on the weekend myself.
jballer187 is offline   Reply With Quote
Old 04-18-2007, 11:35 PM   #3 (permalink)
Black_civic_Si's Avatar
If you are talking about the back struts, you would have to use a allen key with a hand wrench, not a socket wrench. The best hand wrench is the Sears Craftsman Locking Flex Ratcheting Wrench. Here a link a of the tools http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Black_civic_Si is offline   Reply With Quote
Old 04-19-2007, 06:15 AM   #4 (permalink)
Caper's Avatar
The back dosen't have struts... I have already had the whole suspension apart as I have installed coilovers... I am trying to take the the front strut assembly apart, the rest I can do. Just those two nuts on top of the front struts, not too sure. It would be no problem if I could get a wrench in there but no dice.
Old 04-19-2007, 09:17 AM   #5 (permalink)
Caper's Avatar
Update with picture about what I am talking about...
Old 04-19-2007, 10:00 AM   #6 (permalink)
bhoy's Avatar
Marv
use a 6pt. offset box wrench.
bhoy is offline   Reply With Quote
Old 04-19-2007, 10:09 AM   #7 (permalink)
Caper's Avatar
See like I said... I knew I was missing something!! That's the one thing I don't have... Parts store here I come.
Old 04-19-2007, 10:14 AM   #8 (permalink)
GGMIKEY
Mikey6p's Avatar
Mukey
Both times I have installed springs....it came out without dealing with the allen key. I just removed the nut with a regular socket.
Originally Posted by xrs54 View Post
Wow, grocery store managers ftw!
Mikey6p is offline   Reply With Quote
Old 04-19-2007, 10:17 AM   #9 (permalink)
Caper's Avatar
Was the strut in or out of the car? Because if you try doing it when it's out of the car the strut rod/mount just turn with it, at least that is what is hapenning to me...
Old 04-19-2007, 10:26 AM   #10 (permalink)
GGMIKEY
Mikey6p's Avatar
Mukey
Out of the car...perhaps i just got lucky.
Old 04-19-2007, 11:03 AM   #11 (permalink)
audiophile's Avatar
Ben
You're supposed to back the nut off the strut while it's on the car until the nut is about 1/3 of the way off the bolt.
I actually took a cheap-o cargo strap, pulled up the rubber part that covers the shaft and wrapped the strap around the strut shaft through the spring opening, Twist it pretty goodand tight and hold it real tight with a set of channel-locks. Vise grips would work well too. I only did this b/c I didn't have any offset box wrenches. The nut backed off real easily.
Shadetree FTW!
audiophile is offline   Reply With Quote
Old 04-19-2007, 11:47 PM   #12 (permalink)
a really good investment is a air compressor, that is what i use to install my coil over kit. Also save you alot of time.
Old 04-20-2007, 12:05 AM   #13 (permalink)
slik1017's Avatar
lift up the black rubber thing and that part that spins inside when you turn the bolt, clamp that down. I don't know how to better explain it but thats what i did. ( pic stolen from DIY thread)
slik1017 is offline   Reply With Quote
Old 04-20-2007, 12:40 AM   #14 (permalink)
Louder than 4 F404-GE-400
Paul
Shadetree FTW!
Shadetrees Kick ASS. I've solved many a problems fallowing the shadetree code. Use what you got. Only in this case, i had one offset wrench in the tool box and it just happened to be the right size. Lucky me.
Old 04-20-2007, 03:20 AM   #15 (permalink)
audiophile's Avatar
Ben
That's what I was going to do, but I figured using the strap wouldn't cause any damage to the shaft. Would using a clamp or vise grips damage the shaft?
Old 04-20-2007, 08:02 AM   #16 (permalink)
slik1017's Avatar
I used a vice grip and it didnt cause any damage. Or atleast not that i know of hahah. I couln't figure out any other way
Old 04-20-2007, 08:40 AM   #17 (permalink)
Caper's Avatar
Thanks Guys all the help is much appreciated! Last night I went out and bought an offset wrench... still wouldn't fit in there. Anyway I took my coilovers off and put my stock suspension back in for the weekend. I didn't have time to mess around with it last night as I was running out of daylight... finished it in the dark with a trouble light in my driveway. I'll tackle it again on Monday... Those stock coil springs are a #$#$%#@ to get back in (Couldn't get sway bar links off...) thank god for spring compressor.
Yes an air compressor would be awesome but I live 2000km away from where the one I own is and can't justify buying another one.
On the bright side, after a few hours the girl from across the road (pretty hot) came over and was wondering what I was doing all afternoon. Of course she had no idea what I was talking about but she invited me over sometime and said that I was crazy for working on the car all night.
Old 04-20-2007, 09:09 AM   #18 (permalink)
PoLiShPrInCe's Avatar
oh man... im doing mine on sun... hope i dont have probs
PoLiShPrInCe is offline   Reply With Quote
Old 04-20-2007, 10:02 AM   #19 (permalink)
Caper's Avatar
Which springs did you get?
Old 04-20-2007, 10:14 AM   #20 (permalink)
tein s-techs.... i bought them around christmas... time to install
People with lowering springs... How are you stock struts holding up? DumbasSi Suspension and Brakes 41 09-02-2007 09:43 AM
do you really have to cut the bump stop when installing springs? Civic Pride Suspension and Brakes 25 04-11-2007 09:14 PM
Suggested struts to go with Comptech springs? Toxis Suspension and Brakes 6 10-14-2006 02:07 PM
Any Springs will fit? hoanger Suspension and Brakes 11 06-07-2006 12:15 AM
Question on Installing Springs? larryd Suspension and Brakes 3 05-06-2006 04:21 PM
