Old 04-20-2007, 04:40 PM   #21 (permalink)
Tim
yeah puttin on my sportlines on sunday as well..
SiTim is offline   Reply With Quote
Old 04-23-2007, 02:16 PM   #22 (permalink)
xCHICOx's Avatar
Chico
I had a rough time myself trying to take that nut off until I put the strut back on the car.
xCHICOx is offline   Reply With Quote
Old 04-24-2007, 02:50 PM   #23 (permalink)
hondaonchrome's Avatar
Lonny
I just had the same problem saturday and i had to go buy the box wrenches at sears, you will need a 17mm box wrench but that is not the only thing you are going to need then when i bought the wrench i got back home and it still wouldnt get down deep enough to get a good bite on the nut so i had to use a grinder and grind down the box wrench enough to get the wrench down deep enough to get a good bite and then it was a peice of cake to get off.I will take a pic of the wrench you will need to get it off and i will take a pic of the grind that i had to take off.
hondaonchrome is offline   Reply With Quote
Old 04-24-2007, 03:12 PM   #24 (permalink)
Lonny
here are some pics, I did tein s-techs.If you need better pics just let me know,And the wrench at sears is 16.50 but i bought the whole set just incase if i ever needed them in another size(whole set 41.99)
Old 04-24-2007, 04:24 PM   #25 (permalink)
audiophile's Avatar
Ben
Nice bike
Keep us updated if your springs ever start creaking. Mine started about 2 weeks after installation, did so for about a month, and has since quit...
audiophile is offline   Reply With Quote
Old 04-25-2007, 09:07 AM   #26 (permalink)
Caper's Avatar
Got the springs on... No problems with the installation, took about 3 hours. It is easy to get the top nut off when the strut is in the car...
Caper is offline   Reply With Quote
Old 04-25-2007, 10:01 AM   #27 (permalink)
did you take the whole nut off or just loosen it? i'm waiting for my camber kit to come in and want to have a smooth install.
jkocr2 is offline   Reply With Quote
Old 04-25-2007, 01:14 PM   #28 (permalink)
Caper's Avatar
Just loosen it, as there is a lot of pressure there with the stock coil spring. Once you get it off you should use a spring compressor so the top dosen't go flying off. You can do it without a spring compressor but I wouldn't recommend it, you can rent them or loan them at auto parts store usually.
Old 04-25-2007, 01:23 PM   #29 (permalink)
Lonny
Originally Posted by audiophile
Nice bike
Thanks, Thats my weekend rider.....
People with lowering springs... How are you stock struts holding up? DumbasSi Suspension and Brakes 41 09-02-2007 10:43 AM
do you really have to cut the bump stop when installing springs? Civic Pride Suspension and Brakes 25 04-11-2007 10:14 PM
Suggested struts to go with Comptech springs? Toxis Suspension and Brakes 6 10-14-2006 03:07 PM
Any Springs will fit? hoanger Suspension and Brakes 11 06-07-2006 01:15 AM
Question on Installing Springs? larryd Suspension and Brakes 3 05-06-2006 05:21 PM
