Old 04-15-2007, 08:16 AM   #1 (permalink)
S2000 Rotors Fit the Si?
I am driving a non-Si, but is using Si stock front calipers and rotors on my ride.
I am now thinking of replacing the Si stock rotors with those from Racing Brake. The front rotor made by Racing Brake for Si uses this material called Alloyed Gray Iron and weighs 15 lbs each. On the other hand, the front rotor made by Racing Brake for S2000 uses Racing Formula Alloyed Gray Iron, heat treated and weighs 14.1 lbs each. In terms of dimension, they are both the same : 300 x 25mm (11.8" x 0.9").
The front rotor made by Racing Brake for S2000 is clearly more superior than the Si's in term of material and weight. If the S2000 front rotor can fit the Si, it will fit my ride too. Can any kind souls advise me if the S2000 front rotor will fit on the Si ? Many thanks.
ipod is offline   Reply With Quote
Old 04-15-2007, 03:32 PM   #2 (permalink)
I-NTEC's Avatar
yes and the only difference from the factory is the s2k's are heat treated better
I-NTEC is offline   Reply With Quote
Old 04-18-2007, 02:50 AM   #3 (permalink)
OneSi's Avatar
so if the S2000 rotor fits our Si's, that must mean a big brake upgrade for the s2000 must fit as well correct? because the rotor would have to be located in the same area for out stock caliper to work, therefor a caliper relocator kit with a rotor should work as well?
from what i understand too the rsx front big rotor kit fits as well from club rsx. so the options just widend did they?
OneSi is offline   Reply With Quote
2007 Honda Fit webby Garage 27 07-19-2008 01:48 PM
Used S2000 or a new Honda Fit??? tronvex Garage 90 01-10-2008 05:12 PM
Coming to a Track Near You: Club Racer-Inspired 2008 Honda S2000 CR webby Honda Industry News 40 08-20-2007 12:56 AM
Do RSX Type-S Rotors Fit? Mikagami Suspension and Brakes 2 11-08-2006 10:40 AM
honda fit - 5 star crash testing results webby Garage 2 06-22-2006 06:11 PM
