Old 04-13-2007, 08:44 PM   #1 (permalink)
Mattzilla's Avatar
Matt
Lowering and noises?
So I've been reading up on which springs to buy, and it seems like a lot of people have problems with their springs making noises. Noises drive me NUTS.
Is there any set of springs out there that WON'T make creaking noises and whatnot?
Mattzilla is offline   Reply With Quote
Old 04-13-2007, 08:45 PM   #2 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
my s-techs dont make noise.
Originally Posted by Mikey6p View Post
Cock sauce is good too.
http://killyourself1.myminicity.com/ind build my city.
Zeuceone is online now   Reply With Quote
Old 04-15-2007, 02:19 AM   #3 (permalink)
sikassdrummer's Avatar
Chris
I have an 07 ex coupe and have tein s tech as well and no noise.I honestley think that the people with noise either installed the front's wrong or didn' retain the factory lower rubber,s and they also have assigned sides they have a l and a r on the spring's so you know what side to put them on and make sure you allign the car as well.
sikassdrummer is offline   Reply With Quote
Old 04-15-2007, 02:46 AM   #4 (permalink)
Early versions of stechs front springs for the si were incorrectly labeled. The front left spring had R on it and the the front right spring had an L on it. The rotation of the tein coils are suppose to be the same as the oem coils. I noticed this when I got mine almost a year ago. I made a phone call to tein and verified that yes the coils were incorrectly labeled. I have had no issues with my stechs since I installed them. I am not sure if mixing up the left and right springs on the front could cause problems but if you have issues it might be something to look into. As far as the rear springs go I had a slight tick sound coming from the left rear suspension. I found out that when I installed the spc camber arms that you are suppose to completely torque down the rear arm while the suspenion is under load (on the ground), after I did this the tick noise stopped.
shawn
sbmon is offline   Reply With Quote
Old 12-02-2007, 08:41 PM   #5 (permalink)
FG2uner's Avatar
Mark
i had my tein s techs professionally installed and they still make noise. any advice?
FG2uner is offline   Reply With Quote
Old 12-02-2007, 09:55 PM   #6 (permalink)
B-Series For Life!
Stein's Avatar
My Comptech springs made a couple noises in the rear when I first installed them. Pulled it apart it again and reseated the bottom rubber part that the spring rests on and the noise went away... I think that was the problem.
Stein is offline   Reply With Quote
Old 12-02-2007, 10:08 PM   #7 (permalink)
cation's Avatar
spring noise = install error
cation is offline   Reply With Quote
Old 12-02-2007, 10:22 PM   #8 (permalink)
You'll only die tired
Redleg06Si's Avatar
Joe
Pro kit.....and no noises....be sure you install them properly
Post Whore #2 (Da Deuce)
<INJEN> <GREDDY> <P2R><Eibach><DCSports><TSW>
Originally Posted by akai6 View Post
Although I guess you could be the Male total Package
Redleg06Si is offline   Reply With Quote
Old 12-02-2007, 10:34 PM   #9 (permalink)
FG2uner's Avatar
Mark
i know this might be a dumb answer and not related to the topic, but i am new on this website and i cant figure out how to post a thread, any advice. sorry for the stupidity.
Old 12-03-2007, 02:38 AM   #10 (permalink)
Hollyw00d's Avatar
Steven
the neuspeed sport springs the 2 inch ones i wanted to get them for my fa5 can i use the stock shocks i just want the drop the car is just to look nice its not my drag car i cant stand the car being so high i just want to dump it without spending 1200 bucks on suspension. can anyone suggest a setup for me thats cheap i want a 2 inch drop.
Hollyw00d is offline   Reply With Quote
Old 12-03-2007, 03:04 AM   #11 (permalink)
krazyguy187's Avatar
lyonel
were you talking about the sleeves? the brown rubber ones? how did you do it? i think this could help a lot
krazyguy187 is offline   Reply With Quote
