#1 (permalink)
oem Civic Si front brakes on my LX!! -impressions...(pics)
Brakes came off a new Si, the guy said they had only 5 miles on them.
Well I'm not sure if I'm the first one to do this but I must say that I am very pleased with the result, and I would recomend this to any one. I found these oem Si brakes and I mean calipers, rotors, brake pads and brake lines. I got them for dirt cheap at the Tein Garage sale. - This is an upgrade from 10.3" rotors to 11.8" rotors. Calipers seem to be the same. Maybe the Si calipers have larger pistons, otherwise the brake pads on the Si are actually smaller than the ones on the R18 civic. Pros: Braking is by far better, than what it was before. No fade what so ever. I figure because the Si is aproximately 200 lbs. heavier and it is more nose heavy (by 1%) installing the Si brakes on the R18 Civic is like getting a big brake kit on the Si, like 13" or slightly less. -They fill in the wheel gap better. Cons: The Si rotors are 6lbs. heavier. And the calipers seem to weigh around a pound more. So all together you increase the weight by 6-7lbs. The car does feel slightly slower the first two three gears, but it makes up for it in braking. Impression: These si brakes on my LX really inspire confidence. In the end I say if the opportunity comes up and if its cheap GO FOR IT! You will love these brakes. My friend drives an 03 Lexus IS300 and he says my car brakes like his now. Before: ![]() - After: ![]() ![]() ![]() The difference is more obvious in person. And my stock brakes, not sure what I'm going to do with them. ![]() Last edited by Andrei'sCivic; 08-11-2007 at 09:04 PM. |
#6 (permalink) | |
#7 (permalink) | |
Oem steel wheel with the 205/50/16 Bridgestone Turenza tire weighed 39lbs. My Volk TE37 with 225/40/18 Toyo Proxies weighs 37.5lbs. + 6-7lbs. from the Si brakes. |
#15 (permalink) |
lost the mod bug
Nice
anyone do a LX rear drums to rotors/brakes conversion yet? or know how to? This was one thing i needed from the EX model Last edited by Exeon; 04-12-2007 at 01:05 PM. |
#17 (permalink) |
Resident Si Sedan Hater
Hate to say this, but your braking distance will be longer with that mod.
First off, it will feel like it's braking better, because of the stronger brake torque up front, which gives an initially stronger bite. BUT 1) The ABS computer will detect that the car is decelerating too rapidly, and will continually modulate (in other words weaken) the braking force. When the ABS cuts out for a moment, it again detects that the car is decelerating too fast, and compensate again. This happens continuously over your braking, and it stretches out the braking distance of your car. The ABS computer was programmed to expect a certain deceleration rate, calculated by the stock LX brake torque. Since you've increased brake torque up front by adding bigger rotors, the ABS will be overcompensating. 2) You've significantly increased the brake bias up front, which reduces the overall efficiency of your braking. The reason being that Honda engineers specifically chose the front and rear brake rotors sizes to work with each other. You can't simply add stronger brakes up front and expect better braking, as it throws off the brake balance with respect to the rear. A more front-heavy brake bias means that the front brakes are doing more work than needed, and the rear brakes are doing less than they should. Hence, irrespective of ABS, your braking distance would increase. The only benefit for this new setup would be less brake fade, but that comes at cost of greater braking distance. |
#18 (permalink) | |
I don't know about that... I will tell you that the car definetly feels like it stops quicker exspecially at much higher speeds. I believe that the car reaches 0mph quicker than before. ABS definetly doesn't kick in as early or as often (since it doesn't need to) I did think about getting rear rotors from the Si or an Acura which has 11.1" rotors. Or if some crazy thing allowed me to use my front brakes in the back. I heard that changing rear drums to discs is quite involved, lots of work, parts. |
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/35713-oem-civic-si-front-brakes-my-lx-impressions-pics.html
| เปลี่ยนชุดเบรคหน้าดีหรือไม่? - Civic FD Thailand Community | This thread | Refback | 02-15-2008 09:13 AM | |
| เปลี่ยนชุดเบรคหน้าดีหรือไม่? - Civic FD Thailand Community | This thread | Refback | 02-14-2008 06:58 AM | |
| เปลี่ยนชุดเบรคหน้าดีหรือไม่? - Civic FD Thailand Community | This thread | Refback | 01-30-2008 08:37 AM | |
