Originally Posted by 06RREX
I am looking at the new HFP brakes on my EX. In order to do that, I should ONLY need the Si calipers. So my brake setup would be entirely new with the HFP kit. I would have invested appx. 800 dollars in a brake setup. Bigger and slotted rotors, Bigger calipers, bigger everything it seems. So, after reading this thread I am under the impression that I would invest 800 dollars in a braking system that is actually WORSE than before, due to the ABS? If I changed EVERYTHING (like I am planning to do) with my brakes, (Not just the front like Andrei'sCivic did) would it be better?
So questions are:
1. Would my braking system (stopping distance and that stuff) get worse with the new brake setup?
2. I would be changing all 4 brakes, not just the front two, so shouldnt that make up the difference between the two? (Andrei'sCivic only changed the front two)
3. How would my braking effectiveness differ between lighter braking (non-ABS braking) and heavy braking (ABS engaged)
I still need these 3 Q's answered! Any help??
1) Well if you swap everything, the braking distance would be better (that is, if Si's braking distance is better than EX--which I presume it is)
2) Not only would you need to change all four brakes, but you'd probably need to change the brake master cylinder, if it's different on the Si.
3) Braking effectiveness differ between Si and non-Si? Not sure what you're comparing here. When I talk about braking effectiveness, I mean at the limit. In light braking, performance stays the same--the only difference is how much pedal distance and feel.
