Old 04-06-2007, 04:34 PM   #1 (permalink)
unplugged's Avatar
Front Spring Install / Noise problem found
I don't know about other springs, but the Progress springs seem to be wider than the OEM ones. I'm not sure if the coils are wider for the Si than the EX, but on my EX, the coil are hitting the vehicles body when mounted. If you look up into the wheel well where the top mount slides into the frame, you can see the spring has zero clearance causing it to hit the frame when going over bumps.
- Mark
2008 Honda Civic SI (stock)
2006 Honda Civic EX (sold)
unplugged is offline   Reply With Quote
U.S. & Canadian Tint Laws jc21 Inside and Out 40 11-02-2008 10:44 PM
Grace: 2006 Honda Civic Si ASM PWRDByAdobo Introduction & Pictures 67 01-24-2008 08:24 PM
Honda Dealer found problem with rough idle bmw325 Mechanical Problems & Technical Chat 14 07-28-2006 05:37 PM
