Stainless Steel Brake Lines on '07 Si Sedan
Has anyone beside me attempted to have these installed?
I ordered a set from Tai at CorSport and they are a quality part, for sure. The front set of lines will install without a problem; the rear set is a different story. It seems that the stock brake lines are welded to the bracket inside the rear wheel well, and the bracket is welded to the body. The thin metal brake line that emanates from the ABS unit will disconnect, but not the stock rubber brake line. Looks like a cutting torch and/or metal fabrication skills may be needed to replace the brake line. Any input from someone who has tackled this will be appreciated. |
for the rears, i cut the factory line off and slid the new one in. if not, just zip tie around the abs wire where it mounts.. don't tie it to the wire itself, but the mount incase it snags you won't rip a 30-40 dollar wire.
- Mark 2008 Honda Civic SI (stock) 2006 Honda Civic EX (sold) |
| Review: EBC GreenStuff Pads, BDI Rotors, CorSport Brake Lines, ATE fluid | unplugged | Suspension and Brakes | 57 | 02-03-2008 02:08 AM |
| Minor Brake Upgrading | 604_ep3 | Suspension and Brakes | 5 | 02-26-2007 01:13 AM |
| Brakes (06' Si) Parts-list: | Torredo | Suspension and Brakes | 3 | 12-07-2006 02:59 AM |
| Rotora Stainless steel braided brake line | BattleEndless | BattleEndless Performance | 2 | 09-28-2006 06:25 PM |
| stainless brake lines? | BLU BY U | Suspension and Brakes | 30 | 09-21-2006 09:10 PM |
