Old 03-30-2007, 08:04 PM   #1 (permalink)
suggestions for a bumpy ride
i have a 2007 honda civic si sedan and the suspension is getting to me. Sure i like the handling right now but is there something that i could do to the car to make the ride a bit smoother. Every little bump i can feel myself bounce up and down... any suggestions??
abyjmontes is offline
Old 03-30-2007, 08:13 PM   #2 (permalink)
rickhilbert's Avatar
Sit on a pillow! Not much you can really do. I have yet to see a "good" handling car with a soft suspension.
rickhilbert is offline
Old 03-30-2007, 10:10 PM   #3 (permalink)
Si4Life's Avatar
Whos High Pitch?
buy a lexus LS430
Si4Life is offline
Old 03-30-2007, 10:21 PM   #4 (permalink)
JustaCivic
Guest
Posts: n/a
give your car away :)
Old 03-30-2007, 10:25 PM   #5 (permalink)
Si4Life's Avatar
Whos High Pitch?
^^he can give it to me.
Si4Life is offline
Old 03-30-2007, 10:48 PM   #6 (permalink)
Vince's Avatar
Stephen "Vince" Carter
Check that your tire pressures are set to the spec on the door frame, if they are and you think it's still to bouncy I think you could drop another 1-2lbs, but otherwise your in the wrong car if you don't like the stiff suspension.
Vince is offline
Old 03-30-2007, 11:32 PM   #7 (permalink)
HondaFREAK's Avatar
You can get nitrogen shocks with dampeners that make you feel no road bumps...lots of $$ though
just to let you know, my tire pressure from the factory was 37 in the fronts, 38 in the rears....the recommended PSI is 32...might wanna check it.
HondaFREAK is offline
Old 03-31-2007, 01:26 AM   #8 (permalink)
Liu
Liu's Avatar
That depends on which tires you get right? I know mine say 40 on the wheels, are they recommended 32? I have the sticky summer tires. I think mine are all at 35 right now, feels great, I like it bumpy.
Liu is offline
Old 03-31-2007, 01:48 AM   #9 (permalink)
HondaFREAK's Avatar
I guess it depends on the tire, but the sticker on the door frame says 32psi cold
Old 03-31-2007, 07:33 AM   #10 (permalink)
Vince's Avatar
He's reading the max pressure printed on the tire I think, which tire manufacturers stopped putting anything but the maximum pressure on the tire so many years ago that I can't remember back that far.
The tire pressure settings are in two locations: The door jamb, and the manual.
Vince is offline
Old 03-31-2007, 07:33 AM   #11 (permalink)
Vince's Avatar
see post #10
Vince is offline
Dumb Laws C2i0v0i1c Water Cooler 56 03-19-2008 03:02 PM
Cedar Point Selling Demon Drop Ride! - Ohio peeps get in. webby Water Cooler 8 07-31-2007 05:18 PM
anyone notice bumpy ride in lx sedan? or coupe? datbacker59 Civic Coupe And Sedan 10 03-30-2007 10:16 AM
New to this forum Here are some pics of my ride ... Any suggestions? ken42o Introduction & Pictures 14 02-24-2007 01:37 PM
Vacationing in Germany...suggestions? cojaro Water Cooler 11 02-01-2007 07:42 PM
