#41 (permalink) | |
One that is "pre-built" and pre-assembled by one company...So basically you hoping that that one company tested and did their homework and gotten the Right Valving and Spring rates.... and you have to figure in what they wanted that coilover application was for, probably the average driver...So you will never be able to tune them to what you want exactly or how you drive personally... So can seperate springs, shocks, thereaded collars be as fast or comfortable as a "pre-built" setup? The question should be "can an OTS "coilover" ever reach the performance of a Properly selected Spring + damper setup?"... Probably not but they'll come close, and they are a whole lot more convienaint....Just like a home stero, sure the mini system is nice and its good, but seperate components are always gonna win...But witht he mini system you don't have to think about it all, like a suspension, who cars what spring rates or shock valving you have...Its a complete package setup for EVERYONE!! Its really about how much time you want to spend on your suspension and most just want to slap it on and go...Thats fine, for those that care, spend the time and do it RIGHT... |
#42 (permalink) |
Louder than 4 F404-GE-400
After owning tein ss and tein flex I am done with OTS coilovers. OTS coilovers are designed for a wide range of people. I have found out that I am not that wide range. None of the OTS coilovers have spring rates that promote oversteer which is what a fwd care needs to handle well. Sure the limits are high with flexes but they still push at those limits. The only way you could get Flexes to rotate is to get custom spring rates which negates the OTS status that Flexes have and take you to the level of custom suspensions which is where the racers live.
You know what the sun's all about when the light go out. |
#48 (permalink) |
with the ground control sleves... do they by any chance pop out (springs) while racing / driving / pot holes ects?
Also, do i need to modify my stock shocks? and when i get koni yellows do I need to reuse any part of my stock suspension.. I remember I had to do this on my EM2 .. which is why I went with buddy clubs on the ep3 and evo i had |
#53 (permalink) | |
well you dont have to jump, all you have to do while turning in go in tripod mode for the wheel to droop some... and if the spring fall, you are out of luck... I have not taken at look at my suspension yet (just got the car) but in the rear, how can a prebuilt coil over prevent the spring from falling? I am under the impression that the spring just sits there correct? with any system wit full droop (on a light or jack) (flat tire replacement on the side of the road) wouldn the springs just be loose and pop out? |
#54 (permalink) | |
Hitting the 3 wheel motion would suck.
| Buddy Club | GreySi07 | Bolt-Ons And All-Motor | 17 | 03-22-2007 09:02 AM |
| Buddy Club Exhaust OR Canon Powershot S3is... | Skyline4life | Water Cooler | 11 | 12-02-2006 01:13 AM |
| Buddy Club Wheels | BattleEndless | BattleEndless Performance | 12 | 11-10-2006 01:36 AM |
| an update from buddy Club (v. I think there starting to hate me) | Skyline4life | Bolt-Ons And All-Motor | 2 | 10-22-2006 12:06 AM |
