Rear Camber Kit - 8th Generation Honda Civic Forum
LinkBack (4) Thread Tools Display Modes
Old 03-13-2007, 08:09 PM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
06blaksi's Avatar
Rear Camber Kit
This is very simple. On a scale of 1-10 with 10 being the hardest, I give it a 2.
First, buy your camber kit. I bought the Skunk2
Next, have a friend who owns a lift Comes in handy when trying to get road salt off from underneath the car and when I get all my underbraces
After removing the wheel, you can remove the bolt holding the current arm to the spindle 14mm
Next remove the 2 14mm bolts holding the opposite end of the arm. You'll need a swivel and/or some finessing to get the back bolt on the passenger side since the exhaust is in the way. There is a bracket also attached to the passenger side arm. You won't need this.
Set the new arms next to the old ones and adjust the end on your new arm so it is the same length as the old one. Install them the same way they came off and you're done. My batteries went dead in the camera so I don't have install pics. If anyone has any, let me know and I'll post them. It's pretty straight forward and you can message me if you have any trouble
Here are some after the install
06blaksi is offline
Old 03-13-2007, 08:11 PM   #2 (permalink)
ayenoc's Avatar
Albert
+rep... good write up.
ayenoc is offline   Reply With Quote
Old 03-13-2007, 08:37 PM   #3 (permalink)
eugenekim.net's Avatar
thank you very much for this... it will come in handy soon
Old 03-14-2007, 12:22 AM   #4 (permalink)
60103's Avatar
Ken
06blaksi when you set them to the same length it doesnt change the camber does it?
Some Pics I took while doing the install 2nite.
60103 is offline   Reply With Quote
Old 03-14-2007, 07:47 AM   #5 (permalink)
06blaksi's Avatar
The camber stays the same I believe. I had to take mine for an alignment anyway so I wasn't too worried if it was when I was done. Thanks for the pics!!
Old 03-14-2007, 08:17 AM   #6 (permalink)
MrEmO's Avatar
great DIY! it'll help me in the near future
MrEmO is offline   Reply With Quote
Old 03-14-2007, 09:49 AM   #7 (permalink)
very nice dude... rep
FG*SQUAD Nick is offline   Reply With Quote
Old 03-14-2007, 10:09 AM   #8 (permalink)
subee13's Avatar
Car is clean and sexy man.
subee13 is offline   Reply With Quote
Old 03-14-2007, 10:12 AM   #9 (permalink)
Chase's Avatar
Chase
Will pretty much any alignment shop adjust the aftermarket camber kits if neccessary?
Chase is offline   Reply With Quote
Old 03-14-2007, 10:35 AM   #10 (permalink)
06blaksi's Avatar
They should but when I took mine in it didn't need anymore adjusting
Old 03-15-2007, 09:38 PM   #11 (permalink)
Sirbelch's Avatar
Paul
Hey, 06blaksi, I think you are supposed to take off the brown plastic on your tein springs. I took them off my SS springs.
Old 03-15-2007, 09:44 PM   #12 (permalink)
Here is another post to complement the DIY.
blue1 is offline   Reply With Quote
Old 04-03-2007, 12:37 PM   #13 (permalink)
berlinas2k2's Avatar
254whp on 75
Very Nice writup/ I will need this soon!
berlinas2k2 is offline   Reply With Quote
Old 04-16-2007, 09:47 PM   #14 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
Subscribed 'cause this will come in handy for me. +repped
Old 04-16-2007, 10:08 PM   #15 (permalink)
CrackThatTec45's Avatar
very nice man, great write up!! Do yours squeek at all? i was in a rush and didnt really grease the bolt that goes through. I feel that i should probably take that back & grease her up
CrackThatTec45 is offline   Reply With Quote
Old 04-16-2007, 10:16 PM   #16 (permalink)
Coop's Avatar
Coop
i think the plastic/rubber piece on the springs is to help prevent squeeks
Coop is offline   Reply With Quote
Old 04-16-2007, 10:25 PM   #17 (permalink)
you talking about the actual sping seat in the rear or the camber kit?....didnt start squeeking until i installed the skunk2
Old 04-16-2007, 10:36 PM   #18 (permalink)
sikassdrummer's Avatar
Chris
You forgot to mention to get accurate camber and toe you have to constantley remove the wheel,then remove the bolt that goes through the hub/spindle.It's a pain in the ass. took me five times for the first side then 2 on the second .Once you do the first side set it an-.75 then when you do the other side and set it the counterballance weight of the car will make it about -.85 all around which worked perfect for me and it handles great.
It's nice to see the wheels almost straight.
Installing the upper rear controll arms is easy /I have skunk 2 which is much better you can fine tune it in milimeters. but again you do need to set you allignment after that .It took me a total of 2 hours and thats with a good allignment machine
sikassdrummer is offline   Reply With Quote
Old 04-16-2007, 10:42 PM   #19 (permalink)
whos_1st's Avatar
x2
whos_1st is offline   Reply With Quote
Old 04-16-2007, 11:25 PM   #20 (permalink)
Coop's Avatar
Coop
on the actual spring at the tips
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/32040-rear-camber-kit.html
DIY: FG2 Coilover and SPC front/rear camber kits Install This thread Refback 08-16-2011 03:56 AM
07 civic rear upper control arm - Honda Civic Forum This thread Refback 06-27-2011 10:08 PM
2006 CIVIC SEDAN how to Install Camber Kit - Honda Forum / Acura Forum - SuperHonda.com This thread Refback 02-25-2008 09:03 AM
2006 CIVIC SEDAN how to Install Camber Kit - Honda Acura Forum This thread Refback 12-30-2007 01:12 AM
Megan H-Brace and lower rear brace Review 604_ep3 Suspension and Brakes 42 09-25-2009 06:22 PM
s tech tein spring, need a rear camber kit? ronjancivicsi Suspension and Brakes 4 04-06-2007 11:25 PM
Comptech vs SPC camber kit....need pics 06Fg2 Suspension and Brakes 8 12-07-2006 11:18 PM
Camber Kit Install baddceo Civic SI 4 11-18-2006 07:39 PM
