Old 08-15-2007, 08:29 PM   #61 (permalink)
Subaru71's Avatar
dSLR Squad #32
just did this today, very straightforward, great DIY
Subaru71 is offline   Reply With Quote
Old 08-19-2007, 12:25 AM   #62 (permalink)
ortivt6's Avatar
Ant
a pic of mines...
ortivt6 is offline   Reply With Quote
Old 09-17-2007, 08:53 PM   #63 (permalink)
TonyFG2's Avatar
Tony
subscribed. gonna need this soon.
TonyFG2 is offline   Reply With Quote
Old 09-20-2007, 05:30 PM   #64 (permalink)
ortivt6's Avatar
Ant
Let me know if u need more info... the skunk2 are the best in fit and designed... way better than OEM!!!
Old 10-19-2007, 12:54 PM   #65 (permalink)
So,
if I do the HFP sus/kit the rear camber kit is a must but the front also?
Or why not since the front will be apart anyway..
Anyone "not" do the front camber kit with the HFP sus/kit?
Thanks
RaGu07ex is offline   Reply With Quote
Old 10-19-2007, 12:56 PM   #66 (permalink)
Oh and this is for my 07 EX/Coupe
Old 10-26-2007, 04:16 AM   #67 (permalink)
Guys, be careful on the Skunk 2 rear kit, currently they have an issue with the bushing is smaller and the result is there's a play after driven for a while the bushing gets weak.
Skunk will replace the bushing as well the pin that goes in, both pieces are redesign and fit snug.
I will recommend to sent it to Skunk or to call them before install them. Save your self time and alignment money.
xevo8 is offline   Reply With Quote
Old 10-26-2007, 04:23 AM   #68 (permalink)
eugenekim.net's Avatar
captain obvious
when did they redesign it? maybe i should call them i stop by their shop...
Old 10-26-2007, 04:24 AM   #69 (permalink)
captain obvious
good to know btw, thank you
Old 10-27-2007, 04:09 PM   #70 (permalink)
ortivt6's Avatar
Ant
Wow I had mines since july n never had any issues... n trust me I drive hard on turns on my car where people ffeak out thinking am going to hit them.... lol but I will keep that in mind if anything happens to them... but I love them and they do their job PERFECT!!!
Old 11-06-2007, 01:48 PM   #71 (permalink)
Great post, nice car
broda1115 is offline   Reply With Quote
Old 11-07-2007, 01:12 AM   #72 (permalink)
ortivt6's Avatar
Ant
Old 11-12-2007, 01:24 AM   #73 (permalink)
jvtec15's Avatar
does this get the camber to positive, because i just installed skunk2 lowering springs and i noticed my rear tires were slanted?
jvtec15 is offline   Reply With Quote
Old 11-14-2007, 01:34 AM   #74 (permalink)
chiguywithsi's Avatar
jay
yea
chiguywithsi is offline   Reply With Quote
Old 11-14-2007, 08:14 PM   #75 (permalink)
civicRfun's Avatar
Pete
I can see the need to adjust camber if you lower the geometry, but
If you put on lowering spings -and you leave the stock shocks on, aren't you compressing the shock too much and causing a harsher ride?
civicRfun is offline   Reply With Quote
Old 11-15-2007, 01:14 AM   #76 (permalink)
ortivt6's Avatar
Ant
yes it does... u can adjust it up too +-3 degree.... meaning if u drop it 3 inches it will get it back to factory specs....
Old 11-15-2007, 01:15 AM   #77 (permalink)
ortivt6's Avatar
Ant
yes u are... thats why u should go with the tein basic...
Old 11-15-2007, 07:35 PM   #78 (permalink)
aka 900 $ ??
ive got the springs sittin in a box behind me gonna put on soon but i think ill wear out the stock shocks a good bit before i spend a grand for new ones heh
bmnorm2 is offline   Reply With Quote
Old 11-22-2007, 07:08 PM   #79 (permalink)
ortivt6's Avatar
Ant
If u get the springs only, after a while ur gonna need to replace the shocks... so why not get the whole set up oh and be able to adjust it to any height...
Old 11-22-2007, 10:20 PM   #80 (permalink)
hoanger's Avatar
Jason
well if you've got the springs, you can put em on with your stock struts.. like a lot of people do, so you're not the only one.
If you're only in it for the drop and no extreme performance or track time is needed, then springs are a good alternative. However, as long as you are aware that your stock struts will blow some day and you intend to replace them when they are, then I see no problem.
However, if you don't you will get the bounciest, crappiest ride ever.
Theres a riced out accord here whos lowered and every little bump he hits makes him bounce.. its ridiculous.
hoanger is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/32040-rear-camber-kit.html
2006 CIVIC SEDAN how to Install Camber Kit - Honda Forum / Acura Forum - SuperHonda.com This thread Refback 02-25-2008 09:03 AM
2006 CIVIC SEDAN how to Install Camber Kit - Honda Acura Forum This thread Refback 12-30-2007 01:12 AM
s tech tein spring, need a rear camber kit? ronjancivicsi Suspension and Brakes 4 04-06-2007 11:25 PM
Megan H-Brace and lower rear brace Review 604_ep3 Suspension and Brakes 38 03-21-2007 02:32 AM
Comptech vs SPC camber kit....need pics 06Fg2 Suspension and Brakes 8 12-07-2006 11:18 PM
Camber Kit Install baddceo Civic SI 4 11-18-2006 07:39 PM
