Tracking my car - Page 2 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Suspension and Brakes
Old 10-02-2012, 12:26 AM   #21 (permalink)
SMNG's Avatar
Sean
Originally Posted by hadalian View Post
I have been using Hawk HP 10 for brake pads they melt the rubber boots on the caliper and boil fluid in a few laps so it gets exciting when the pedal goes to the floor at the end of the braking zone. I have heard that the TSX Conversion does the trick but havent had any experience with it. As for the suspension the car rolls to much for me. I would like it not to dive as much and stay better planted in the turns. At Watkins Glen there is no way I can keep the car in the VTEC coming out of the toe of the boot. It just drops off I was thinking I need to widen the rpm band that it operated in. At Limerock there is a crazy thing happens the steering gets light at the top of the downhill and the electronic assist shuts off and it is like no power steering at all at the bottom of the hill.
I run in the instructor group so the car is getting a work out but like I said earlier I am looking to go in the right direction from people that have done this and not trial and error on my own.
Thanks for the suggestions does anyone run Michelin sport cup tires?
Hey man, I just came back from Watkins Glen with my stock 08 FA5, using Hawk HP Plus F/R and the rubber boots on my calipers are done! my front right caliper keeps getting ceased...btw I also went to Limerock this summer with same set up. I changed my fluids, brake lines, clutch, tranny, engine. Recently bought a spare front caliper and will keep re-building them every year.
Bottom line our front calipers are working really hard! my rears are barely worn. I would love to upgrade to bigger but want to stay in stock class. I'm sure changing them to bigger would help us drastically. If upgrade is an option might as well get 4 piston calipers or even 2 piston and then I wont mind changing classes. Think about it, the 08 civic type r comes with stock 4 piston Brembos for a reason don't you think.
Haha same here dude, toe is tough on our cars, we need torque there. Third gear at turn 7 is the only way. I still don't know how to heal-toe so that turn was screwing with me both days. That track is AMAZING!! wow! can't wait for next year. Limerock meh! maybe i'll go back to it someday.
Pilot cups are very consistent thats all I keep hearing, sorry haven't own them. Too bad Pilots are over priced.. ;-P
For power and rpm changes get flash pro, promise that will fix your issues for now.
SMNG is offline   Reply With Quote
Old 10-02-2012, 04:15 AM   #22 (permalink)
cambodianricer's Avatar
JLee
I got tired of having to rebuild the stock calipers so I upgraded to the TL-S Brembos
cambodianricer is offline   Reply With Quote
Old 10-03-2012, 01:22 AM   #23 (permalink)
jdizzle37's Avatar
J.D.
I'll share my experiences with the combination of parts that I feel are worthwhile for a daily driven Si that also sees frequent mountain drives and track days.
First and foremost, handling is the area that has made make the biggest and most enjoyable difference for me. I will discuss each area that I prioritize.
Traction: Tires & Motor Mounts
Your tires will make the biggest difference in handling even on stock cars. The Si is equipped with Maximum Performance tires and switching to an Extreme Performance summer tire and higher will make even a tragic suspension quick. The reason is simple: more traction. I really like the Hankook RS-3's in 225/45/17. They're a little wider and have unbelievable grip for the money. Despite the 140 treadwear, they have lasted quite a while and still going strong.
Motor mounts are often over-looked but have been a major help in maintaining traction for this car. Boomba seems to be popular but I favor the Innovative mounts as the Innovative passenger side mount is a much more effective design. The trouble with front wheel drive cars is that the power transfer to the wheels and the steering is all ran on the front axle. Additionally, whenever you're accelerating, weight transfers to the rear lifting the front of the car and creating a larger imbalance of weight transfer during shifting, consequently affecting traction.You'll be surprised how much traction is maintained when using these things and how still the engine remains even during high load.
Brakes: Stainless-steel Lines, Brake Fluid, Pads & Rotors.
All of these elements will contribute to stopping more effectively but these components don't affect your ability to slow down quickly (tires do that). These parts will affect your ability to stop consistently. Stainless steel lines make a huge difference in pedal firmness and consistency. I use Stop-tech.
Brake fluid should be matched to a pad with similar operating temperatures. My experience so far has been DOT-4 fluid is sufficient for dual-purpose cars. I have used Motul RBF-600 and Amsoil DOT-4. I like both and although Motul has a slightly higher boiling temperature, I have found that Amsoil is better at keeping moisture in suspension when the fluid does boil. Basically, you'll be bleeding the Amosil fluid a lot less. With Motul, I had to bleed the brakes after every track weekend. With Amsoil, I have been able to go 3-4 weekends before needing to bleed.
My picks for brake pads are Hawk HPS' for street and mountains and Hawk HP+'s for the fronts only during road racing. I burnt through the HPS' my first time on the Streets of Willow track pretty quickly. I used the the HP+'s this last time and they did phenomenal. An additional bonus is that the HP+'s are also sufficient for getting you to and from the track. Some people like using them for daily driving but I find them too noisy.
My experience with rotors have entailed using Stop-tech slotted and Brembo blanks. Out of all of them, I like the Brembo blanks the best. Stop-tech was alright the first go at Streets of Willow, but I felt they were unnecessary. I have since switched to Brembo blanks and they have done great. A premium blank rotor does surprisingly well even during road racing. I have used the same rotors now for 2 years now and they don't have any abnormal wear. Still strong!
Alignment: Camber Bolts & Arms
Alignment also goes a long way on a stock Si. Chris from Redshift Motorsport has a good write-up regarding alignment and tire pressure that you can read about here. I personally use SPC, but you'll want bolts and arms with good adjustability. I would shoot for parts that can achieve -3 of camber.
Suspension: Rear Sway-bar, Springs & Dampeners
The best bang for the buck suspension mod is hands-down the Progress rear sway-bar. Makes the car rotate way the hell better. Honestly, this damn thing should be on the Si from the factory!
I have used a couple different springs ranging from OEM, HFP, Eibach Pro-kit and Neuspeed Sports. Out of all of those, the Neuspeed Sports are the best in handling. The drop is reasonable and performance is top-notch. The main reason is that the rear springs are progressive and crazy stiff in the right spot to facilitate more oversteer (or reducing understeer). When using these, you must get upgraded dampeners.
Currently, I am using the Koni Sports with the Neuspeed springs. This is a fantastic combo but the Koni's alone are fantastic. I used the Eibach's with these as well. The Koni's are rebound adjustable (compression is fixed) and can be fine-tuned to any spring. Ride quality varies based on tuning and springs. I currently run all 4 dampeners a half-turn firm from full soft and have found this to have better traction and comfort than the HFP spring and dampener combo.
Power: Basic bolt-ons, FlashPro tune
I feel power should be the last thing addressed on this particular car because the improvement on handling has made the biggest improvement in the driving experience. Even with factory power, the handling upgrades will make for a tremendously more enjoyable experience. When you're accustomed to driving the car with a more balanced and consistent handling setup, you can increase the power and go faster.
My current mods include a custom air intake (almost identical to the T1R intake), the Vibrant race header with high-flow cat and cat-back exhaust, Skunk2 Stage 1 cams and a FlashPro dyno tune. This setup is sufficient for my dual purpose needs but there are much better parts out there now from when I first pieced together my power mods.
The main thing to achieve in a track car is a BROAD power band with a flat torque curve. High-rev limits, top-end power and high horsepower numbers are better suited for a drag racing car. I actually feel those type of mods make it more difficult in the Si because the car already has a power bias toward the top of the rev range and the stock, close-ratio gearing already force you to work harder to keep the revs up. At least with a broader power range you'll be able to roll on the throttle in a more controlled manner, improving lap times.
Camshafts can do wonders in the shifting the power curve with appropriate supporting mods. I would suggest researching dyno charts in the Cams/Internals threads and look for setups with broad torque curves.
Finally, a quality FlashPro tune will make it all work beautifully and reliably!
Summary of Parts:
Tires: Extreme Performance Summer Tires (Personal fav: Hankook RS-3)
Motor Mounts: Innovative Performance 75A
Stainless-steel Lines: Stop-Tech, Goodridge or Cor-Sport
Brake Fluid: Amsoil DOT-4 or Motul RBF-600 if you don't mind bleeding more often
Pads: Hawk HPS for Street/Mountain; Hawk HP+ (fronts only) for track days
Camber Bolts/Arms: SPC (see Redshift article for alignment needs)
Rear-sway Bar: Progress Technology
Springs: Neuspeed Sports
Dampeners: Koni Sports
Power: FlashPro tune with whatever combination that will achieve a broad power band and a flat torque curve. If you are receptive to using camshafts, base your specific supporting mods around the cams that will achieve a broad power band.
*One special note I would like to mention is fluids. Quality fluids will ensure maximum performance, protection and longevity in a dual-purpose car. I use all Amsoil products for this reason. I already expressed my love for the DOT-4 brake fluid (which I use for clutch fluid as well) and I use the Signature Series 5W-30 motor oil for all my daily driving, mountain drives and some track days depending on the projected temperatures at the track. If it's in the winter season or 90 and below I will stick, with that motor oil. If it's going to be hotter than that, I use the Dominator Racing 10W-30 motor oil. In both cases, I also use their oil filter. I also use the Manual Synchromesh Transmission fluid which is great even for street-only cars. Smoothes out shifting big time. Additionally, I use OEM coolant mixed with the Dominator Coolant Booster. Very effective at transferring heat away even in the stock radiator. The car can warm up faster too.
Finally, I use the Dominator Octane Booster as a safety precaution. My car is tuned on 91-octane pump gas but it's never a bad idea to add quality octane booster to make the engine more knock-resistent since you'll be spending a lot of your time at wide-open throttle, high-end of the rev range, and constantly switching from medium to high engine loads all in hot-ass 100 degree plus weather.
Amsoil products are more expensive but they also are much higher quality than a lot of the other stuff out there and last a hell of a lot longer too, making them a cost-effective option for the long run; especially with the Signature Series motor oil which can be changed every 25,000 miles or once a year. I wouldn't suggest waiting that long in a high-performance, street-driven and tracked car, but I have been using that motor oil and changing it every 12,000 miles for the past 4 years and have had no issues. In fact, I recently inspected the cams and they are in great shape with no signs of premature or abnormal wear.
It's long post but I hope this is helpful to you and anyone who reads this.
Cheers!
jdizzle37 is offline   Reply With Quote
Old 10-03-2012, 04:17 AM   #24 (permalink)
JLee
Good write up, but there's a few items that do differently.
The 225 RS3 are perfect for the stock rims, I did my first couple of track days with them.
The Hawk HP+ is a good beginner pad BUT one may out drive them very early on. A good choice would be the Project Mu Club Racer.
If you are race enough, you should be bleeding your brake fluid often.
I'm using two sets of camber bolts and I'm able to get -3.5 to -4 degrees of camber up front
Old 10-03-2012, 10:18 AM   #25 (permalink)
jdizzle37's Avatar
J.D.
You're right on these points camodianracer.
- I should've specified that I like the 225 RS-3's on stock wheels. To the OP, I like the RS-3's in general although the size you use will depend on your wheels.
- I have heard great things about the Project Mu Club and Carbotech pads as well.
- I think if you're really heating up your brake fluid enough that yes they should be bleed frequently. At the same time, getting the fluid to boil will happen based on temperatures the brakes see due to pads, rotors and driving style. For my style of driving, I tend to brake early and not as hard when coming into turns so I'm not as hard on the brakes as others. That's why, while using the Amsoil DOT-4 anyway, the pedal continued to feel firm even after a weekend. I didn't start noticing a spongy feeling until the the third or fourth weekend with Amsoil but it was really noticeable by the end of a single weekend with the RBF-600.
Old 10-03-2012, 10:48 AM   #26 (permalink)
testify's Avatar
Incredibly dangerous.
You NEVER put an aftermarket camber bolt in the top hole, EVER!
Aftermarket bolts are inherently weaker than OEM bolts due to their design, and sometimes due to quality.
If a camber bolt fails in the bottom hole, no big deal, the wheel goes inward, stays relatively where it should, tire hits the strut, no harm, no foul.
If you put the bolt in the top hole, and it fails (and I've seen this happen), the tire and wheel will be able to go outward, through the fender. It can end up peeling back 90deg, bend and break very expensive steering and suspension parts, lose all ability to direct the car with steering, and potential cause a horrific accident.
So, if you at all care about yourself, or the other innocent people on the street and the track, you will NEVER put a cam bolt in the top hole on a MacPherson strut car.
testify is offline   Reply With Quote
Old 11-27-2012, 04:25 PM   #27 (permalink)
Below is a conversation I had with Lee Niffenegger Honda R&D engineer, helped developed the 2006 Honda Civic Si. When he was racing a Showroom Stock Si in SCCA. I asked him in the end of 2008 for suggestions for the brake issues I was having.
Civic is tough on brakes... we run Cobalt XR2s on the front, XR3's on the rear. The only Hawk brake that would stop the car was the DTC70, but they were really hard on rotors and the wear rate was quite high.
We used a full H&R coilover damper not just springs on the other cars. The only brake cooling on the SSB car is the little scoop that hangs off the plastic inner fender. There is no air inlet on the front fascia. No cooling is allowed in SS.
I will most likely run the car again at the Runoffs, but the extent I will run during the season is up in the air.
hadalian is offline   Reply With Quote
Old 11-27-2012, 06:04 PM   #28 (permalink)
Brakes are the biggest issue for me, even the hottest race pads will overheat on this car. Fluid will boil, caliper dust boots will melt and wheel weights will fall off if you don't take an easy cooldown lap and even some slow driving in the paddock, and it will still happen after a couple of days on track whatever you do.
If you stick with stock brakes expect to use a set of pads in 1 day once you get up to speed and you will still get pad fade by the afternoon no matter what compound you use. I have tried CL5+, XP12, DS1.11...
1. If I was to do this season again I would upgrade to TSX calipers and discs at the start just to save money on pads. ATE fluid is probably good enough for the price and how close it is to the higher temp fluids. Use blank (not slotted or drilled) rotors.
2. Not much mention of alignment in this thread. You need front camber to make your tires last and improve the balance.
3. Then tires/2nd set of wheels. You will overheat stock front tires.
4. Make sure the maintenance is up to date: a good synthetic oil, MTF fluid, coolant (if it is old), air filter, plugs.
Those 4 are the minimum you need to drive it hard. After that there's:
Harry's laptimer with a recent iphone and stable mount gets great quality vids. Add external bluetooth obd & gps dongles for a very nice learning tool.
Flashpro so you can set vtec earlier for more mid-range tq and get rid of rev hang. As a bonus you can use it to datalog water temps, revs & speed, knock (to make sure you're not killing your engine).
Suspension so you can improve the balance and grip.
Radiator to lower water temps.
Finally: power mods (along with oil cooling to cope).
bludragon is offline   Reply With Quote
Old 11-27-2012, 06:29 PM   #29 (permalink)
JLee
For coolant I use distilled water and Redline Water Wetter.
Si tracking? ryancollins2006 Civic SI 6 06-23-2009 08:01 AM
First time tracking jwlee7 Autocross & Sanctioned Drag Racing 30 12-26-2008 02:54 AM
So I finally went tracking with my car.... finallymanual Ontario 15 07-09-2008 05:02 PM
no tracking with the new GT-R 06si Garage 50 04-11-2008 03:12 PM
Tracking my car Skylinegtr06 Autocross & Sanctioned Drag Racing 25 12-30-2007 10:21 AM
